Cooling the intercooler
08-10-2008, 11:47 AM | #1 |
///M Uber Alles
333
Rep 1,601
I found that spritzing cold water on the IC (through the grill) b4 a 1/4 mile run seems to help. I see people throwing ice on their superchargers between runs but I haven't seen anyone wetting their FMIC like this.
What do you guys think, performance or placebo? |
08-10-2008, 01:48 PM | #2 |
Rep 1,654
Drives: AW M3
re
get that office cleaner dust spray... turn the can upside down and spray it on your intercooler before a 1/4 run... will only last a minute or two but is said to work
08-10-2008, 05:40 PM | #3 |
Rep 1,288
Drives: 135i
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
08-11-2008, 10:57 AM | #4 | |
///M Uber Alles
333
Rep 1,601
08-11-2008, 11:55 AM | #5 |
Rep 10,509
I used to place ice on the top mount intercooler in my WRX in between HPDE sessions, mostly to try and fight off the heat soak as long as possible.
Personally, I think the 'gain' is really just preventing power loss from heat (in the case of the WRX, the ECU would pull timing as the IC got heat soaked to prevent detonation) |
08-11-2008, 03:11 PM | #6 |
Rep 67
Ask and ye shall receive.
I've installed a misting system on my 335i for road course usage. It involves the Arizona Mist "cooling system" along with a 150psi Shurflo pump (same one used on meth injection systems). It is not an easy project. There is nary a place to mount the pump so I had to make a metal bracket and install it on the driver's side bumper. Basically where the oil cooler would be, if there was one on the driver's side. Then the reservoir was just jammed in the engine compartment and zip tied. It is activated via pushbutton right now. I wanted to test it before getting too fancy. Two nozzles on the IC, four on the radiator and one on the oil cooler. You can calculate water usage by the nozzle specs and I sized the water tank to accommodate a 30 minute session, assuming 30% use. The test involved running a 20 minute track session with half of the session without spray followed by 1/2 with spray. The misting lowered the intake air temps by about 15-20 degrees. Coolant dropped by about 10 degrees and oil dropped by less. This was all done with misting on the straights. The key is that you need to make sure that you aren't dousing the IC. Ever notice how it's quick to get water to boil but takes a while to evaporate it all? That's because it takes a ton more energy to convert water into steam. If you are just dumping water on the IC and it just runs off, the system will be less effective AND you will piss off your trackmates. You want it to MIST and instantly evaporate. Water's latent heat of evaporation (amount of heat to evaporate known quantity of water) is one of the highest out there. So it works...but it ain't easy. |
08-11-2008, 04:22 PM | #7 |
Rep 10,509
08-11-2008, 08:39 PM | #9 | |
Rep 10,509
I wanted to know if timing as ADDED as a result of this cooling. I'm trying to validate my hypothesis that "the 'gain' (of cooling the IC)is really just preventing power loss from heat " |
08-11-2008, 09:26 PM | #10 | |
Rep 67
Because of that, it was mitigating the timing retard. In other words, not dialing back timing as much. If the IC makes it cooler than stock, perhaps it'll advance timing beyond the baseline. But I surmise it just mitigates temp rise like my spray system, therefore just mitigates timing retard. Not sure I understand your question. |
08-12-2008, 01:07 PM | #12 |
pew pew
166
Rep 6,781
Anybody with the cold weather package thought about retrofitting the headlight washers as IC / oil cooler misters? Would require a momentary switch of some sort to activate them and not the windshield washer, but I can't imagine that being a gigantic feat of engineering...
I always wanted to tackle that project but I don't do enough 1/4 mile or HPDE stuff to really give it a go.
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
08-12-2008, 02:41 PM | #13 | |
Rep 1,714
