06-18-2019, 06:57 PM | #2 |
Rep 5,409
07-10-2019, 11:54 PM | #4 |
Rep 5,409
It's time for me to abandon ESys as I'm too computer illiterate to figure out how to make it work. I'm totally confused on which is the better option, Bimmercode or Carly. I looked at GAT, but the adapter is, IMHO, quite over priced at $200.
My main goal is to code a couple things my recent dealer visit uncoded; the compass, reverse camera at any speed. I also want to code the (I forget what it's called) headlight beam narrowing at freeway speeds. So…. PLEASE HELP me decide!! |
07-11-2019, 05:40 AM | #5 | |
Rep 39
07-17-2019, 09:38 PM | #6 |
Rep 5,409
I chose BimmerCode for various reasons and here is what I've learned coding with BimmerCode…
Expert mode has all the available coding as does ESys. I couldn't find the compass setting in the basic modules, but I found it easy enough in the expert setting. I tried coding 5 blinks instead of the stock 3, but that didn't work; I think we already knew that. I also coded warm and cold temp monitoring... that was a failure as I got all kinds of failure alerts so I went back to not monitored. Coding off my phone is infinitely easier than dragging my laptop around. I didn't try Carly as the price of admission is too high (IMHO) and the yearly fee is too much for me (not the cost, just the fact that they charge yearly). So far I couldn't be happier and if I need to get into diagnostics I'll just get BimmerLink. |
07-18-2019, 01:34 AM | #7 |
Rep 22
Does Bimmercode reset the service alert, brake pads etc within Idrive ?
Thanks
Dec 2016, BMW 520d M-Sport Auto
M-Sport Plus Package Professional Navigation Multi-Media Split/Fold Rear Seats Space Grey, Oyster Leather |
07-18-2019, 10:18 AM | #8 |
Rep 5,409
02-07-2020, 07:33 AM | #11 |
Rep 39
02-14-2020, 01:00 PM | #12 | |
Rep 262
It will walk you through the steps. I did my brakes this last summer, it was beyond easy to do.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
