"A" Column cover removal
08-11-2008, 10:35 AM | #1 |
Rep 623
Drives: F10 530d M Sport, E87 118d M
Hi
DO any of you know how to remove what I believe is called the "A" column trim cover i.e. the trim covering the right and left windscreen pillars with the "Airbag" badge on. I want to conceal some wiring behind the trim (the aerial wire from the Pure Highway DAB unit). Thanks Tony
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
08-11-2008, 12:35 PM | #2 | |
Rep 333
Drives: E89 Z4 35i
Garage List 2003 Radical SR3 Su ... [0.00]
2005 E53 X5 3.0D [0.00] 2007 E92 335D M Spo ... [0.00] 2004 E85 Z4 3.0i SE [8.00] |
35i - DCT - Most of the toys - Smart top roof module - GLF.
www.onboardvision.co.uk www.gtvr.co.uk www.vehicle-launch-incar-video.co.uk |
08-11-2008, 04:38 PM | #3 |
Rep 623
Thanks. I PMd a guy in the US who had replaced his headlining and all related interior trim with anthracite trim.
The answer is to remove the "airbag" badge and then remove the torx screw underneath. Apparently the trim then just pulls off.
08-12-2008, 09:28 AM | #4 |
Rep 2,047
Be careful fitting them again as its very easy to break the plastic clips. It does all come off quite easily. Have a look at the threads in the DIY section.
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport |
08-13-2008, 05:05 PM | #5 |
Rep 623
OK - will bear in mind - thanks
Tony
09-17-2009, 06:49 AM | #7 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
+1 - thats exactly what I did on my E93 when fitting the car phone kit - a lot easier than trying to remove the trim and can't cause any damage!
09-17-2009, 04:52 PM | #8 |
Rep 2,047
Yes. Its easy to do and easy to remove and refit the trim.
2023 G21 M340i LCI
09-17-2009, 05:15 PM | #9 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Slip the door seal rubber out of that way, install cabling and refit, that's the way to do it.
09-18-2009, 02:00 AM | #10 |
Rep 41
09-18-2009, 12:59 PM | #11 |
Rep 41
Richard.. any tips on putting the A pillar trim back in place? The reason i took it apart is the garage had put it back on all jacked up.. in fact the plastic edges that stick out werent in the appropriate grooves... I guess tomorrow I'll fiddle with it to try and stick it back in there... its kind of a pain in the b#tt!
