06-28-2019, 02:43 AM | #1 |
Rep 557
Bleeding brakes RHD car
I'll shortly be changing from oem brake fluid to some racing fluid in preparation for track days. I obviously have a RHD car and just noticed that the ABS unit is on left side (my passenger), same as LHD cars. The reservoir is of course on the right side with the 2 lines running across the firewall to the ABS unit, otherwise I would assume all the brake lines outwards from the ABS unit are identical for both LHD & RHD cars.
As such am I right in assuming the procedure/order of wheels for bleeding my RHD car will be the same as LHD cars? |
06-28-2019, 04:55 AM | #2 |
Rep 1,823
Yes, order would be the same since the distribution of fluid to individual wheels happens after the ABS unit. Good luck! I just did this with mine using Castrol SRF.
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" |
06-28-2019, 08:38 AM | #3 |
Rep 685
Make sure you also flush the ABS unit. I had my shop do the first flush from oem fluid to SRF, and I now do my own flush 2x year.
07-03-2019, 06:37 PM | #4 |
Rep 1,337
Generally you always start from the furthest corner to the shortest corner from the abs unit.
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
07-10-2019, 09:37 AM | #5 |
Rep 744
07-10-2019, 02:01 PM | #6 |
Rep 685
I plan to do it once a year. Since I don't think any air would generally enter it anyway, I just do a full manual flush once mid season. I compensate for this also by using the Castrol SRF, which has the highest wet boiling point.
07-11-2019, 08:40 AM | #7 |
Rep 744
What do you mean manual flush? like pumping the brakes?
My point is that you can flush the lines but not he ABS unit, if you then cycle the ABS unit you get "old" fluid in your lines. I have heard that pressure bleeding forces all of the valves in the ABS unit open flushing it at the same time. I have also heard that you need to cycle the ABS unit using some BMW software/diagnostics in order to flush the ABS unit properly. Just trying to find out what is true |
07-11-2019, 05:15 PM | #8 | |
Rep 396
I think the need to do this is over-rated. What matters is what fluid is in contact with the back of the pistons inside the brake calipers. This is what boils under heavy use and leads to vapour in the lines and a soft pedal. Brake fluid is not a recirculating system. There’s no return line from the caliper. So boiling fluid and vapour inside the caliper doesn’t end up in the ABS unit, or the master cylinder and it isn’t conductive enough to transfer the heat along a considerable length of brake line. In a perfect world, the entire system would be full with clean, fresh SRF. But for all practical purposes, as long as that’s what is coming out of your caliper bleed nipples and there isn’t air trapped in the system further upstream (which would be soft all the time, not just when hot), you will be fine. |
GasBurnlife(landapanda)576.00 Bosozoku695.00 |
07-11-2019, 07:00 PM | #9 |
Rep 1,337
Go with what Caduceus said.
Otherwise here is the book detail https://www.newtis.info/tisv2/a/en/f...-lines/E26nU3b
07-12-2019, 10:20 AM | #10 |
Rep 1,823
Actually there are higher dry boiling point fluids out there. Motul RBF 660 has a dry boiling point of over 650F, about 50 higher than Castrol. The biggest appeal of SRF is that it’s wet boiling point is almost as high as it’s dry boiling point. Most other fluids boil 250 sooner when they absorb air moisture.
07-12-2019, 10:30 AM | #11 | |
Rep 1,823
GasBurnlife(landapanda)576.00 |
07-18-2019, 03:47 AM | #12 |
Rep 744
Guys thanks a lot for the info!
Intuitively I figured this was the case but with brakes I would rather be overly cautions. I used RBF 600 in my RS and never got any fade. Its cheaper than RBF 660 but has very similar specs. 312C vs 328C dry boiling point and 204C vs 204C wet boiling point. https://d23zpyj32c5wn3.cloudfront.ne...pdf?1492016152 https://d23zpyj32c5wn3.cloudfront.ne...pdf?1492016152 I will use my Gunson pressure bleeder to do the brakes BTW its the inside nipple first and then the outside one for the front calipers? |
07-19-2019, 09:37 AM | #14 | |
Rep 557
A normal maintenance full flush is here and doesn't involve anything special for the ABS system though they use a pressure bleeding system and not the old 2 person method: https://www.newtis.info/tisv2/a/en/f...ion/1VnXDR6doh NOTE also that for the callipers with 2 valves (nipples) the manual says the 'outer' valve is done first followed by the 'inner' valve. |
07-19-2019, 09:41 AM | #15 | |
Rep 557
