07-02-2019, 09:33 PM | #1 |
Rep 219
Drives: '19 G20 330i & '19 G01 X3
Fuse assignments on the G20?
BMW Driver's Guide for the 2019 G20 points you to this website to get the fuse assignment plan:
https://www.bmw.ie/en/topics/owners/fusecard.html Admittedly, I've not YET looked in my trunk to see if there is a card in the fusebox, but I can't get it from my VIN on this site. Nor can I pull one for our 2019 X3 as well. |
08-01-2019, 01:13 AM | #2 |
Rep 219
I finally got around to digging for this in the trunk where the fuses are. This is for the G20 330i. Hopefully it helps someone. Both PDF and the individual pages are scanned here.
-- Matt |
Eagle Creek139.00 ProfoundTwitch7.50 IndotagSwizz524.50 bcoz80.50 Seaford1152.00 euro_syd1.50 vadimo311.50 johnbraddoe7.50 |
08-01-2019, 01:48 PM | #3 |
Part of the bimmer family!
139
Rep 293
Drives: BMWG20; BMW E90
My dear that's a lot of fuses! Also many fuses connected to the sams function, up to 6 at a time. Never seen that before.
“You can put wings on a pig, but that doesn't make it an eagle.”
09-07-2019, 02:02 AM | #4 |
The Wolf
252
Rep 989
Drives: stuff
Just took delivery of a m340i, the charging pad nor the 12v receptical in front of it work. I assume there is a fuse under the cowl cover in the engine bay, does anyone know which one from the diagram?
09-22-2019, 09:43 PM | #6 | |
Rep 4
https://bao.bmwgroup.com/bao-rd/#/bm...63529915.20790 |
09-25-2019, 12:05 PM | #9 |
Rep 395
09-25-2019, 02:09 PM | #10 |
Rep 4
I just had good luck using fuse F59 in the passenger side footwell fusebox. It's switched so it turns off a few minutes after car shuts off.
If you have a dashcam with parking mode you'd be better off using F25 or F36 as they get constant power. (beware battery drain) |
DNB_Perth15.00 |
09-28-2019, 12:56 PM | #11 | |
Rep 751
There are apparently 4 fuse boxes in the g20.
1. The main fuse box is in the trunk, behind the right wheel arch (passenger side for LHD). There is an access panel. 2 & 3. There are 2 more interior fuse boxes, each of which can be found at the base of the A-pillars in the front passenger foot well areas. Quote:
4. In the engine compartment. I believe it's to the right of the motor (when facing the engine), but have not confirmed yet. Note: there are several smaller power distribution blocks throughout the car with fuses, but I personally wouldn't use those or the engine bay one for most of my electronic needs |
VipinLJ1949.00 |
10-14-2019, 12:13 PM | #12 | |
Rep 395
However I think you are right and #36 is always on since I did not see the camera go off after 12 hours. Will try 59 and see if that does the trick. |
11-02-2019, 02:10 AM | #14 | |
Rep 84
Have you found it? |
11-16-2019, 09:20 PM | #15 | |
Rep 1
Drives: BMW E46 330Ci
Check the right side of the rear luggage compartment(trunk) for the fuse box. The fuse for the 12v socket is a 20 amp fuse and is No. F273 (as seen on the above diagram) |
11-18-2019, 01:31 AM | #16 |
Rep 84
I've replaced it succesfully, it is actually located at the passenger's feet on front right under a panel. That's were one of the fuse boxes is.
01-03-2020, 04:13 AM | #17 |
Rep 395
01-24-2020, 09:14 AM | #18 |
Rep 84
F46 is the one I've replaced, I actually found F273 thinking it was the one I blew. F273 is located in the trunk on the right side. There is a paper located in the trunk fuse box like the image to guide you. Let me know if you found it.
sd_dracula141.00 |
02-10-2020, 10:48 AM | #19 |
Rep 3
On the G20 bmw
The 12v accessory socket doesn’t take all types of usb chargers Often the problem is not a fuse It's that the adapter that is inserted isn't a correct fit |
02-11-2020, 09:42 AM | #20 |
Rep 230
Apparently the G20 has two batteries: a lithium battery under the hood, and an AGM battery under the floor of the trunk. I assume one is primarily for starting the engine, and the other serves the massive amount of electronics in the car.
So when people are hardwiring devices that want a constant battery connection (dash cams with parking features), are they taking this into account and deliberately deciding which battery to connect to? I haven't seen any discussion about that so far. I'm wondering if the issue of over-discharging the battery (and getting warnings about it) could be mitigated by connecting to one battery vs. the other? Thoughts? |
02-17-2020, 07:51 PM | #21 | |
Rep 751
03-22-2020, 10:16 AM | #22 |
Rep 1
Fusebox front left location in 330i 2020
I want to remove fuse 129 so I can kill the annoying ASD sounds.
Anyone knows where th front left FB is located? I failtofi d it. Thx in advance |
