07-07-2019, 10:16 PM | #1 |
Rep 124
Using 2 keys in the car at the same time
Sorry if this is already covered somewhere:
I gave my wife her own key, which she keeps in her handbag. When we are both in the car, and I'm driving - how do I set-up so my key is the preferred/detected key? Do I need to set-up my wife's key with the same profile as my key? Also everytime she goes into the garage to get to her own car, my car wakes up with comfort access etc. How should her second key be set-up to fix these problems? |
07-08-2019, 08:11 AM | #2 |
Rep 419
For your car waking up scenario you can check this thread.
https://www.bimmerpost.com/forums/sh...php?p=24988491 Not sure about the key priority as I had to restart/clearing everything when I had my ConnectedDrive issue and I have yet to setups wife's key.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs] |
07-08-2019, 09:30 AM | #3 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
My husband never drives my car, so I’ve never used the second key. I think each key needs to be programmed to the specific driver, but you should be able to unprogram the key, set up the seat the way your wife likes it, and just set that as the second driver seat settings.
I’ll try getting in my car with both keys in hand and see what happens with a second unprogrammed key. On a similar note - I activated my key card via iDrive, and now I’m somewhat afraid to leave it in the car. Which kind of defeats the purpose of having it. I know you can “turn it off” in the settings, leave it in the car, and activate it when you want to use it. My question is: is it safe to leave the key card in the car all of the time? If someone was able to break into the car, I know they would be able to start it because the key card is there, but would the car react to someone breaking into the car by disabling the key card or ignition? |
07-08-2019, 10:14 AM | #4 | |
Rep 2,610
(1) Be attentive to your test. The car will likely react differently to a) driver having both fobs positioned in the driver seat area, vs b) one fob positioned in the driver seat area and another elsewhere in the car. (2) I don't understand your intended use case for the key card? I think you were visualizing leaving a deactivated card inside the car for convenience of activating it at some point when you leave the car and take it with you, correct? But what use is that — you will have already by definition had your fob with you at such activation time and you certainly cannot leave the fob in the car while taking the now-activated key card. In any case a) pretty sure BMW intended the key card to be just another "normal" key that happens to fit in your wallet and is somewhat waterproof, and b) until you've tested every single permutation of your theory of use (from the point of view of a thief or a joyrider), DO NOT LEAVE YOUR KEY CARD INSIDE THE CAR!
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
07-08-2019, 10:16 AM | #5 | |
Rep 419
2019 X5 40i M-Sport
07-08-2019, 10:20 AM | #6 | ||
Rep 419
2019 X5 40i M-Sport
07-08-2019, 10:29 AM | #7 | |
Rep 2,610
Interesting, if obscure, use case and while I haven't tested that, if I was a BMW engineer, I would absolutely make sure that this could not be done as it is a significant security issue. It would allow anyone (not just you), with an inactive key card to activate that card in an otherwise unlocked car, bad idea. PS: I strongly believe BMW issued key cards are bound to your specific car. You cannot order one without a VIN and the delivered card will only work in that specific VIN car, this I've tested (key card hobby project with the dealer). So another security layer there.
07-08-2019, 10:39 AM | #8 | ||
Rep 419
2019 X5 40i M-Sport
07-08-2019, 11:01 AM | #9 | |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
I leave my wallet in my car too. I just use Apple Pay for everything so I only carry my phone into stores. |
07-08-2019, 11:04 AM | #10 | |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
I’m going to start a new thread - interested to hear any stories about cars being broken into or stolen. That should give me some perspective. Thanks so much! |
07-08-2019, 05:55 PM | #11 | ||
Rep 1,236
And if both of you are in the same car, then just choose the correct profile when you get into the car. I don't think there is a way to set one key as the "preferred" key. Quote:
07-08-2019, 07:38 PM | #12 |
Rep 124
no snoop - thanks for your response to my original post.
There is another problem so far as I can see - the car chooses one of the two keys and then displays the associated profile for that key. The way the car chooses which key is somewhat random depending on who approaches the car first. Once one key is selected by the car, I'm not aware of a way to get the car to switch keys or select an alternate profile? Maybe I'm missing something here - but isn't this a common problem for others as well ie: main driver and partner get in the car together, both carrying a key?? |
07-08-2019, 11:27 PM | #13 | |
Rep 419
2019 X5 40i M-Sport
07-09-2019, 12:12 AM | #14 |
Rep 124
Thanks eagle_bmw - yes thats the section of the manual that makes clear the choice of key is largely random and therefore the profile which appears.
I'm surprised this use case is not more common. The only way around this I can see, is to set-up both keys with the same profile (mine) and make the guest profile my wife's. The guest profile is tied to the car, not the key. Anyone have any better solution?? |
07-09-2019, 05:30 AM | #15 |
Rep 2,610
Have your wife carry and rely on the key card rather than the fob key?
07-10-2019, 08:07 PM | #16 |
Rep 23
What about buying a little signal blocking pouch for the unused key that is carried.
https://www.amazon.com/Enjoyee-Block...a-589534549899 |
LexxM31701.50 |
