07-12-2019, 05:21 PM | #1 |
Rep 101
Delivery Checklist?
Hi all,
My M340i xDrive will be delivered in 2 weeks. I am looking to create a checklist to use to accept the car (I have searched the forums and could not find anything). The list would contain things like:
What else should I look for? I know many people have been having trouble with ConnectedDrive, what should I do for that? Should I check the A/C temp? Thanks for your inputs! |
07-12-2019, 05:41 PM | #2 |
Rep 27
Make sure you get two keys and the NFC card key activated?
Good luck with ConnectedDrive--mine is ~80% working today, but that changes day to day. If you have a decent dealer that's not hugely far away you should be able to get anything wrong fixed at a later date when you notice it. |
07-12-2019, 05:57 PM | #3 |
Rep 170
Check the air pressures. The factory over inflates the tires so when they are sitting at the port and on the ship they don't develop flat spots. Dealers are supposed to adjust the pressures as part of the dealer prep but often don't do it
Early this week when I picked up mine all the tire pressures were at like 52psi! |
07-18-2019, 03:55 PM | #5 |
936
Rep 4,327
Drives: M340
-Make sure all the manuals there
-Make sure you have the front license plate bracket (if not installed) -Check under the front bumper for scrapes! I refused delivery of my F10 due to heavy scrapes under the bumper. I was given a loaner and BMW had the bumper refinished. I also ask my dealer not to "prep" the car. They just do a safety check and deliver me the car with all the wrapping and plastic. I'd like to do my own new car detail & etc.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
07-20-2019, 11:36 PM | #6 |
Rep 13
I wished I checked this thread before taking delivery of my 330i xDrive today. I didn't get a NFC card today. Should all G20 with M Sport (includes comfort access) have it at delivery?
07-21-2019, 01:12 AM | #7 |
Rep 101
Hi all,
here is what I have so far, based on some Bimmerpost input and my own thoughts: Item Take pictures inside and out for future reference All options are installed Body panel gaps good Check thoroughly for paint scratches Check wheels for curb rash check thoroughly for upholstery defects 2 keys NFC key card delivered and activated Tire air pressure correct All manuals in glove box Front license plate bracket delivered Check under front bumper for scrapes use thermometer to check A/C temp at vents floor mats delivered full tank of gas Connected drive app installed on phone and working Software is up to date anything else? |
07-21-2019, 02:09 PM | #8 |
Rep 358
Did you check in the cover that holds the manual? My key card is in the small slot in the cover that holds the owners manual.
07-21-2019, 02:12 PM | #9 | |
Rep 13
