BMW M3 and M4 - The Icons
home
Technical Sections Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      06-10-2019, 03:51 PM   #1
ynguldyn
Drives: battery powered tv on wheels
S58 Engine Technical Document
BIMMERPOST
     Featured on BIMMERPOST.com
Enjoy.
S58 Engine Complete Vehicle Technical Document
Also see:
S58 Engine: Specs and First Look
Miko M6660.50
ando2005.00
j1980mac262.50
clee1982797.50
Remonster824.00
Gonven623.50
ra2289307.00
Avaley735.00
      07-16-2019, 08:10 AM   #2
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Thank you!
I wish they will add electric turbo to spool the low RPM.
Maybe next generation
Life is too short...enjoy your life
///M
GOLFFRR10836.50
clee1982797.50
JMon371.00
M 4EVER191.00
KoenG1428.50
      07-16-2019, 08:30 AM   #3
MajorNuke
Drives: 2013 BMW M3 (E92)
Originally Posted by ynguldyn View Post
I read in the document that the 0-100 kmh time is 4.3 seconds!? Does this mean that the g8X m4/m3 are not going to be awd? I'm confused
?The ultimate driving machine?
M3sicko108.00
      07-16-2019, 09:22 AM   #4
mkoesel
Drives: No BMW for now
The column in the chart that lists 0-100 hm/h in 4.3s is clearly labeled "F80/F82" which means it is for the outgoing/current generation models. This information is used only as a basis for comparison to the new X3/X4 M. There is no performance data available for the G8x M3/M4 yet.
GOLFFRR10836.50
clee1982797.50
      07-16-2019, 10:09 AM   #5
GOLFFRR
BimmerPost Supporting Vendor
GOLFFRR's Avatar
10837
Drives: GOLFFRR cart
nice
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      07-16-2019, 10:13 AM   #6
Fhey
Drives: BMW M440i
2023 BMW M440i  [10.00]
I'm not sure if I missed something, but is there any information regarding CO2 emissions for these new engines?
Belgium adds a tax based on the CO2 emissions of the engine, which amounts to around €5k for the F8x.
      07-16-2019, 10:23 AM   #7
CT92F80
CT92F80's Avatar
137
Drives: 2017 F80
Wonder if the crankhub issue has been fixed
ccondo160.50
      07-16-2019, 11:02 AM   #8
t$
Drives: e92 m3 6mt
no water injection?
      07-16-2019, 11:10 AM   #9
mkoesel
Originally Posted by t$ View Post
no water injection?
It's not necessary to hit 500hp with this engine. And the last thing people want is another maintenance item to think about, even just filling up a tank with water.
Perhaps a future M4 CSL will take advantage of water injection to boost output up to around 600hp.
///M TOWN20365.50
amdmaxx119.00
      07-16-2019, 11:10 AM   #10
dakine_surf
dakine_surf's Avatar
433
Drives: TiAg e91, r53 Cooper S, e28 M5
Says that it's ULEV 70... don't know how that translates for your country's specific laws... but I know it shows be "greener" than the outgoing model
      07-16-2019, 11:31 AM   #11
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Maximum engine speeds of "the S58 up to 7500rpm." On cars with torque converters, the engine speeds will be limited to 7200rpm. So it seems they at least designed this engine to mate with a manual transmission. Hopefully...
clee1982797.50
F85MTuNED1622.00
      07-16-2019, 11:39 AM   #12
Brake_Late
Brake_Late's Avatar
Norway
1938
Drives: 2015 F82 M4 FIREORANGE2
This is so lit ����
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams,
CarbonStrucktureAnthracite, CF_Everything
BMWPhotoVin, 01of01, GTS DCT, EPS, MDM,
CS EDC,Analog Dip ,GTS parts.
Euro Vin e30 M3, FIA cage / 14.7 p / w ratio.
Euro E30 touring G30 MSport i3s LBB X5M
3.2carrera
https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA
      07-16-2019, 11:39 AM   #13
Brake_Late
Brake_Late's Avatar
Norway
1938
And an AC electric high power motor to boot ...
This truly ' hybrid ' or mix
3.2carrera
      07-16-2019, 11:50 AM   #14
mxchris727
mxchris727's Avatar
Drives: '03 M5, '06 325i, '12 M3
Looks like a solid engine. However, disabling piston oiling in favor for fuel efficiency worries me a little. The dual HPFPs and mechanical water pump are huge plusses in my book!
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
Brake_Late1937.50
      07-16-2019, 12:02 PM   #15
DrifterX
DrifterX's Avatar
Drives: 2016 340i M Sport 6MT+RWD
Pretty cool they had the room to fit the intake box on top of the engine, although it makes me wonder if any additional turbo lag is noticed with the amount of intake piping for this engine (vs. the B58).
Seems they also moved the powerband up in the RPM range a bit vs. the S55; about ~500-700 RPM. I wonder how that'll make it "feel" below 2500 RPM vs. the outgoing M3/M4.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch
Brake_Late1937.50
      07-16-2019, 12:16 PM   #16
kylejdavidson
Drives: 2016 M2 - LBB, DCT
Drove the X3m Competition yesterday back to back after the new m340i. Noticeably more lag in the X3M comp from a standing start/at very low rpms, but obviously pulled way harder as the rpm's rose. Would probably be negated completely with launch control/from a roll.
      07-16-2019, 12:22 PM   #17
upsidedownfunnel
Drives: 2014 335i
I doubt the intake piping is why the powerband is shifted to the right. It's still a more efficient design than using an FMIC and piping it all around the engine bay.
It's probably because they are using larger turbochargers for more power. There's no way of getting around bigger turbos for more power leading to turbo lag. That's why something like a McLaren has a lot of turbo lag and a car like the BMW 330i does not.
dezzracer1184.00
      07-16-2019, 01:13 PM   #18
DrifterX
DrifterX's Avatar
Yeah, the power difference in the mid-higher RPM range will definitely be more noticeable than in the low RPM range. Regarding the lag, I realized the S55/S58 have two mono-scroll turbos whereas the B58 has one twin-scroll turbo; not a very apples-to-apples comparison as the two types of turbos spool differently.
Intake piping is definitely not the cause of any change powerband; it's just how they designed/tuned it.
Good point on the bigger turbo vs lag but according to the document: "The S58 engine has a twin-turbocharger system using mono-scroll turbochargers as also used on the S55 engine." (pg 69). Leads me to think the turbos aren't too different between S55 & S58.
      07-16-2019, 01:14 PM   #19
Raven340i
Drives: bmw 340i
B58 don't have crank hub issue so i think yes they did
      07-16-2019, 01:20 PM   #20
Alessandro
Alessandro's Avatar
Serbia
111
Drives: Audi RS5
2011 335is  [9.50]
What does the lower compression ratio tell us?
19 Audi RS5
15 Audi S5 GIAC Stage 2 white
11 E92 335is DCT FBO 441 whp silver
08 E92 335i FBO 6MT 427 whp space grey
05 E46 M3 red
      07-16-2019, 01:32 PM   #21
brad850csi
Drives: 16 F13 M6 Comp
More lag and less power off-boost, but potential for higher boost levels
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
      07-16-2019, 01:53 PM   #22
Teutonic
Teutonic's Avatar
Are the chain guide rails still plastic?
g80
