07-17-2019, 07:23 PM | #1 |
Rep 116
M2C (2NH) Brake Pad Change
I've read that the M2C calipers (2NH) are the same as the F10 M5 and the M3/M4 CCB.
F10 CALIPER The newtis manual for the F10 that shows that to remove the caliper, the 2 nuts on studs are to be removed, and the caliper slides out. https://www.newtis.info/tisv2/a/en/f...rakes/HjngWJKa F80 CCB CALIPER However, the newtis manual for the F80 CCB shows that to remove the caliper, the 2 bolts on the inside / hub section of the caliper are to be removed instead. Also, instead of the 2 nuts on studs, there are what appears to be hex screws which are not to be removed. https://www.newtis.info/tisv2/a/en/f...kes/1VnXuUMXEx the 2 screws labelled as #1 are not to be removed the 2 bolts labelled as #1 are to be removed QUESTION Looking at my calipers, I see they are the same as the F80 CCB - there are 2 hex screws, and not 2 nuts like the F10. Can someone confirm that the caliper removal procedure on the M2C 2NH is the same as the F80 CCB? Thanks! |
07-17-2019, 07:31 PM | #2 |
Rep 3,009
Should be the bolts in the last picture.
Bolt 8 https://www.realoem.com/bmw/enUS/sho...diagId=34_2674 |
07-19-2019, 10:53 PM | #3 |
Rep 281
I agree. I took mine off. Bolts (#1) in last picture are to be removed and the caliper slides right off. It's heavy so have something to lay it on so it doesn't put stress on the brake hose.
07-20-2019, 07:52 PM | #4 |
Rep 923
Is it a time consuming procedure? Changing the pads on the blue calipers is extremely easy and fast...
07-20-2019, 11:20 PM | #5 |
Rep 281
07-23-2019, 11:37 PM | #6 |
BimmerPost Supporting Vendor
3893
Rep 54,605
Drives: F80 M3
