07-29-2019, 12:58 PM | #1 |
Rep 109
help building a intercooler sprayer
Hello everyone, I've been back on the stock tune for my car as my fuel pump failed and out here in California we've had a major heatwave and my car heatsoaks horribly. I'm thinking of creating a intercooler sprayer out of this https://www.amazon.com/Audew-Univers...%2C198&sr=8-13 and I need help in terms of wiring up the pump as what connector could I use? please let me know
07-29-2019, 02:32 PM | #2 |
Car Hypochondriac
336
Rep 904
Drives: 2014 335i M-Sport Estoril Blue
I've been considering a sprayer as well, i was planning on just running my own wiring to the positive terminal under the hood, or something similar, then possibly using an Arduino or something to run the pump every X seconds when i flip the switch in the cabin.
07-29-2019, 05:00 PM | #3 |
Rep 16,200
You'd use spade connectors of the correct size. From the pictures 1/4" and 1/8", but to be sure take the tank and switch to a hardware store to find the right sizes.
08-01-2019, 08:54 AM | #4 |
Rep 742
Pretty funny I just came across this because I built one two days ago out of boredom haha.
I had some stuff laying around so I used those parts as proof of concept/test it out. Here is what I used... -12v diaphragm pump, 1gpm with 30psi auto cutoff. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 -adjustable spray nozzle https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 -around a gallon water container, flexible https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 -1/4" water line (same as ice maker water line) with push connect fittings. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I have everything running into the front passenger side since I know I can run the 1/4" tube into the cabin easily. Currently running on 4 sprayer jets but I think the issues is too much water causing saturation and not enough evaporation. I did get IAT to ambient temperature of 90 degrees. I'm going to try one or two sprayer jets and see if that is better.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
