08-01-2019, 09:41 PM | #2 | |
Rep 341
If my post was informative or helpful, please click the appreciate button. Thank you.
ERC429.50 |
08-02-2019, 01:52 PM | #4 |
///M SubDriver
1848
Rep 2,788
Drives: 2017 M3, 2020 X7 40i
The best alternative, IMHO, I have seen for BMW is the Stealth Hitch:
https://stealthhitches.com/products/...7-2019-present Admittedly though, I would prefer the OEM solution over this or any other aftermarket solution for the X7 (even though this looks better cosmetically since the receiver is hidden). Mechanically, this aftermarket solution should be just as capable and safe as the factory solution as this one appears to attach to the X7 at the same attachment points. However, the factory solution also includes some additional towing electronic modules (and buttons) that interface with the rest of the car (like iDrive, the air suspension, etc) - a much more seamless and complete integration with the X7 IMHO. I am sure that some coding could "turn on" some of the trailer functionality in iDrive. But adding the other trailer hitch electronic interfaces to the SUV may not be as easy without additional wiring harnesses and/or the trailer hitch module. It would require a bit more research to confirm if the factory trailer wiring is pre-installed so that adding an aftermarket trailer hitch solution is a bit more plug an play. If you are curious, the factory trailer hitch removal/installation procedure can be seen here: https://www.newtis.info/tisv2/a/en/g...ies/1Vne7hY0CR And according to RealOEM, there appears to be a possible factory trailer hitch retrofit out there based on the info comment in the parts list below (but I don't know if this retrofit is available at US dealers yet or if at all): https://www.realoem.com/bmw/enUS/sho...diagId=71_1119
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
Darz3.00 |
08-02-2019, 03:26 PM | #6 |
Rep 1,088
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
I keep waiting to hear the reason why the hitch they get on the Euro models isnt offered here.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
08-02-2019, 03:32 PM | #7 |
Rep 57
Do you lose Comfort Access opening just when you're using the trailer hitch (which seems obvious) or do you lose it just by ordering a vehicle with the trailer hitch option? The vehicle ordering guide says that by ordering the trailer hitch you "delete the 8SL trailer hitch prewire". It doesn't mention anything about Comfort Access. Thanks in advance.
CruiseControl216.50 |
08-02-2019, 05:51 PM | #8 |
Rep 3,479
08-02-2019, 08:33 PM | #9 |
///M SubDriver
1848
Rep 2,788
It has to do with the differences between US vs Europe vehicle safety certification standards (most likely some type of crash safety certification requirement). Not the first time different vehicle options/configurations are required in different countries due to different safety standards.
08-03-2019, 10:32 AM | #11 | |
Rep 161
08-03-2019, 12:10 PM | #12 | |
Rep 1,237
With OEM Trailer Hitch, you get Trailer Stabilization Control to stop trailer swinging. I think this safety feature alone is worth getting the OEM hitch over 3rd party ones. I personally don't care about the comfort access (kick open) feature of the tailgate. It's never worked well in my previous BMWs - I have to keep kicking in different directions and different speed to get it to open, making me look like fool |
MystroX56319.00 |
