BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Who uses NOCO battery chargers?
      08-06-2019, 06:07 PM   #1
avocet
Drives: 2007 328i 2011 X5d
My NOCO G750 charger/tender started to melt and was too hot to touch. Manufacture date 2013... So it's around 5 years old. I really think this is a safety issue and if you use one keep this in mind. I contacted customer support and described my issues with pictures. This is their response to the pictures I sent in:
"No, they do not worry us as our units are working as designed if that happens. The fire suppressants and non combustable housing are made to melt like that if there is an issue with them. If they are getting hot to the point of "melting", there is an issue with the charger, but that reaction is exactly as designed to meet the safety regulations we have for our products."
I don't consider a 5 year old charger too old.
      08-06-2019, 06:31 PM   #2
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
I use them, no problems here. I think it's safe to assume that any battery charger that is melting the housing, it's time to replace it.
      08-06-2019, 06:37 PM   #3
avocet
Melting is the failure mode. This is what concerns me. Just sharing my experience. I no longer have any trust in this manufacturer.
Just out of curiosity .. do you leave your charger unattended? And a melting charger in your garage doesn't concern you?
This unit charges just fine. Obviously I have replaced it!
      08-08-2019, 03:18 PM   #4
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
CTEK is the official BMW charger and are supposed to be the best chargers. They have desulfication mode.
      08-09-2019, 08:35 PM   #5
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
I am confused by the manufacturers response. If it’s melting “as designed” to prevent a fire, it’s still considered a failure due to overheating
I don’t leave mine plugged in any more than needed.
      08-09-2019, 09:29 PM   #6
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
73193
Spot on !
      08-09-2019, 11:09 PM   #7
GuidoK
#buildnotbought
GuidoK's Avatar
14474
Drives: Z4 3.0i ESS TS2+
Yeah cteks are great.
Apart from battery diagnostics, switchable desulfication they also have switchable AGM/normal battery mode (AGM requires slightly different voltages).
At least mine has.
and they are supposed to be very safe. Fire due to battery charging is probably the #1 cause of fire in garages, and other companies that do automotive work.
Although I have a ctek, I'm still reluctant to leave my car with the charger hooked on when it sits in my companies building. (when it sits in the garage, it just burns the car and garage down, when it burns my company building down its another matter, even when its insured)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
      08-10-2019, 02:14 PM   #8
///M Power-Belgium
Belgium
73193
At least mine has.
My (great) CTEK in action . Use my CTEK central connector and charge starts in 2 sec.
