08-13-2019, 11:00 PM | #1 |
Rep 2,115
Who is using iphone as second phone only to get carplay on the screen?
Well, did more searching and sure enough BMW only supports carplay through wireless, no usb method of connecting iphone to get carplay. Which means, as others already said, BT and wireless are tied up for carplay. Hence phone carrier is needed to get the internet to the phone. Urgh... Just so happened that my i'm freeing up daughter's T-Mobile iphone SE, thought (initially) i would hold on to that iphone SE as dedicated carplay, keep it in the car. Primary phone is android (no plan to switch to iphone at the moment).
So, anyone so dead set on using carplay from a "second" phone, dedicated for this purpose? Or, is this a stupid idea? Yeah, it is... Prepaid is probably what i would consider, if at all... Hrm... |
08-14-2019, 08:30 AM | #2 |
Rep 228
Drives: 2018 X3 M40i
Unless there is a way to do it, you won’t be able to connect your primary phone via Bluetooth if the other phone is using CarPlay.
This is a big downside to CarPlay. |
08-14-2019, 11:03 AM | #3 |
Rep 2,046
Drives: X3 G01 30i xDrive
I didn't have luck connecting iPhone SE to X3's CarPlay. If you have enhanced bluetooth, you afoul be able to connect 2 phones to your car. Although I don't know whether it's true, if using CarPlay.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
08-14-2019, 11:21 AM | #4 |
Rep 228
I have enhanced Bluetooth and can connect two phones....or, use CarPlay for one phone only.
If there’s a way to use CarPlay on one phone plus connect another phone I’d like to do that! |
08-14-2019, 12:49 PM | #5 | |
Rep 2,115
Kicks out P2 and P2 is no longer BT'ed with the car and is no longer used to make and receive calls? |
ocdx30.00 gofastbmw5100.00 |
08-15-2019, 12:08 AM | #7 | |
Rep 2,115
Let's see if i can cancel and swap the original order of Verizon Note10+ 5G for iphone. |
08-15-2019, 12:39 PM | #8 | |
Rep 228
Is anyone else's experience different? |
08-16-2019, 01:35 AM | #9 |
Rep 2,046
I can't elaborate since I don't have EHB, but CarPlay is using WiFi no? Even if BT and WiFi at the same time, the second phone should still be able to connect. From my view at least, don't now the technical specifications/limitations. If you turn off CarPlay, are you able to connect 2 phones through BT?
08-16-2019, 08:23 AM | #11 | |
Rep 228
It was such a p.i.t.a. to get CarPlay to work to begin with and then to re-establish that I stopped experimenting with it and leaving it for the one CarPlay phone only. If people have a solution I'd like to hear it. Thanks. |
08-16-2019, 02:52 PM | #12 |
Rep 2,115
Okay, thanks all for the feedback's.
So, decided to also not muck with it any further, after all it's not even my daily drive (wife's daily), i just thought i could make easier for her. What i'm learning, it's not a smooth sail. I'll ask her if she's up for swapping out her Note10+ 5G with iphone. Thanks. Now, allow me to get on my soapbox: I drive "older" daily bmw's, 2003 and 2004 MY's. No fancy in-car electronics. Dinosaur stuffs. I guess back then (and perhaps still do now), BMW was more of "driving experience", less on "fussing with" in-car electronics. Certainly the level of in-car electronics "convenience" has improved drastically since 2004, but seems to me that BMW's focus on "driving" versus in-car electronics are on a different planet altogether, i.e. former is world class, whereas latter, BMW seems to lead the pack in implementation that is not so main stream fashion. |
11-14-2019, 04:04 PM | #13 |
Rep 26
Thats not silly. Ive got an Android as my primary phone (I dont like iphone) but had to buy an iPhone to use Carplay. I want to use my Android for calls and iphone carplay for navigation and music but havent been able to achieve it.
When I have Android via Bluetooth synched to receive calls and then connect the iphone to use Carplay, it automatically disconnects my Samsung from calls and only leaves music available. Theres actually a message that pops up saying that the current phone will disconnect phone calls to let the other receive them. But this only happens with carplay. When I dont open carplay, I can use either phone for calls and the other for music. Maybe there is not support to disable calls in carplay and let the other phone receive them. |
01-27-2020, 08:41 PM | #14 | |
Rep 2,115
I guess i'm little excited to try this what everyone calls CarPlay, tomorrow. But then again, i guess mine with ID6, i missed by one generation to get the (finally) the Android Auto on ID7... |
01-28-2020, 11:17 AM | #15 |
Rep 746
I have a 2020 model with iDrive 7 and tested today.
My primary phone is a Samsung Galaxy S9+ running Android 9. Secondary Phone is an iPhone 8 with iOS 13.3. Both are paired and are shown to be connected to the car. While Carplay was active i initiated a call from my Android phone. The carplay app stopped, iPhone got disconnected and the call was shown on the normal iDrive screen. After the call on the Android phone ended, the iPhone reconnected again and the Carplay screen activated automatically. |
01-29-2020, 12:20 AM | #16 | |
Rep 2,115
I had to take the x3 back to dealership today to go back for round 2 of ambient light strip repairs, fix and didn't get to play with carplay this morning. Still, looking forward to getting my hands on with carplay, ... whenever that maybe... |
01-29-2020, 01:49 AM | #17 |
Rep 746
Make sure you have the latest 11-19 update for the iDrive 7 installed by the dealer. Otherwise there are some intermittent problems with pairing phones and carplay.
01-30-2020, 12:08 AM | #18 |
Rep 2,115
06-22-2020, 03:01 PM | #19 |
Rep 8
I'm using my main Android phone for calls only and an old iPhone 6S for CarPlay in my 2015 435i w/ enhanced Bluetooth and retrofitted NBT Evo (i.e. ID6).
Both devices are connected at the same time, I'm able to make and receive calls on my Android phone through iDrive, while using CarPlay to play music (Spotify). All you need to do is mark the Android phone as an "Additonal telephone" in the "Manage mobile devices" iDrive settings menu. This will reduce it to basic phone functionality, i.e. you will only be able to use it for calls (and texts, I suppose). If you want to use it for Bluetooth audio, the active CarPlay connection would still have to be disconnected first. |
06-22-2020, 03:09 PM | #20 | |
Rep 483
12-09-2020, 07:37 PM | #21 |
Rep 32
Carplay MMI and phone BT
I have a carplay MMI and working great except one item.
When MMI was installed, I deleted all of my IPhone BT connections and set up in carplay. Works great. However, the steering wheel phone button does not work. I tried to set up my IPhone in IDrive again but it still does not work. Does this mean I cannot use the steering wheel phone button while I am in Carplay? |
05-11-2022, 11:32 PM | #22 | |
Rep 110
