Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Photos / Videos / Journals Spare tire option pics
      08-19-2019, 08:13 PM   #1
Transfer
Transfer's Avatar
5260
Drives: Bronco Wildtrak, Tesla MYP
Just want to post up pics of my M340i spare tire option. I ordered it because I wanted PS4S and I don't really need much trunk space. Basically just groceries or two flat suitcases will ever go in there. Grocery bags standing upright barely fit. There is a small amount of storage on both sides of tire and under the rear portion of the cover. I will say though that there is quite a massive reduction in trunk space with the spare, so don't choose this option without thinking about it.
Hysnbrg193.50
      08-19-2019, 09:22 PM   #2
x986
Drives: '16 340, ex e92 335, ex e46 M3
Thanx, that is the first time I have seen how it will look. Would you be kind enough to shoot a couple of pics with the tire and cover removed? Does the cover fit lower in the trunk w/o the spare in place, or do you just get a bigger, but lumpier space?
      08-19-2019, 09:29 PM   #3
Hysnbrg
Drives: 2024 X3 30;2020 M340;2016 340
I have the same configuration with the spare tire. Definitely have some regrets with the limited storage space.
      08-19-2019, 09:41 PM   #4
pneumodoc
pneumodoc's Avatar
235
Drives: G20, G01
Hmm, I was wondering if I can retrofit putting a spare tire in. I have the Pirelli run flat summer tires, and given the sort of rough ride, was hoping to switch to PS4S tires when these wear out.
      08-19-2019, 10:31 PM   #5
TheObviousChild
TheObviousChild's Avatar
323
Drives: '23 M3 Comp xDrive - '21 X3M40
What are thoughts on just buying your own third party spare and keeping it in there and not taking up all the extra room with the cover? I wanted the spare since I have the performance tires and will be getting a dedicated set of winters that won't be runflat either. I like the peace of mind of a spare, but hate losing so much space. I've been lucky with my tire punctures in that the leak was slow enough for me to get to a shop, but my luck is due to run out.
Anyway, I just put my order in on Saturday and production doesn't start until September 1st, so I have time to make changes.
Do you think you could get a mountain bike back there with the seats down and the front wheel popped off? I can in my F30.
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      08-20-2019, 05:21 AM   #6
BigWagonFan
Drives: G21 330i xDrive
Some threads related to the spare wheel + photos from others users:
      08-22-2019, 03:35 PM   #7
PARTS@STBMW
PARTS@STBMW's Avatar
2711
Still a lot of room left, love it!
      09-11-2019, 01:41 PM   #8
TTG
TTG's Avatar
Drives: M340
For $150 its no brainer and 90% of the time my trunk is empty anyway.
It would be much cheaper to remove the spare (If more room is needed) vs trying to get an after market kit.
Also, one can order a replacement trunk floor / carpet from a car that is not equipped with spare. Part #: 51-47-7-438-290
I am really looking fw to having non-RFTs with a spare tire.
Whats next, optional dip stick?
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      09-11-2019, 07:39 PM   #9
Transfer
Transfer's Avatar
5260
Dream on! I can barely reset my trip odometer on this G20. Still love it though.
TTG936.00
      09-10-2023, 01:49 PM   #10
TheSurlyDwarf
Drives: G21 M340i
Hello,
I'm currently thinking about ditching the Pirelli RFT that my M340i came with, in favour of some Michelin Nono RFTs.
Did BMW need to make any adjustments to your M340 suspension to cater for the softer side walled non RFT or did you just retrofit the spare tyre kit in the trunk and swap to non RFT ?
I'm getting some feedback that the suspension will be designed for RFT but given spare tyre kits are (were?) an option on G21, I'm trying to understand whether this is true and whether an adjustment is required to swap to/from RFT.
Thanks
      09-21-2023, 08:25 AM   #11
softtop
Drives: M440i Cab
Originally Posted by TheSurlyDwarf View Post
Hello,
Thanks
Sorry can't answer that question but I would be interested to know as well.
g20
