BIMMERPOST Universal Forums Off-Topic Discussions Board Video + PC Gaming / Computing Need help with triple monitor setup (SOLVED)
      08-23-2019, 02:47 PM   #1
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
959
Drives: '13 328i Msport 6MT
Hey guys. I'm trying to finally get 144hz on all three of my Asus VG248QE monitors paired with my PNY GTX1060 6GB XLR8 card. I tried different cable combinations and it won't allow the last monitor to stay at 144hz. I tried 3x DP, 2x DP 1X DVI+, 2x DP 1X DPtoDVI, 1x DP 1x DVI 1x DPtoDVI.. you get the gist. All drivers up to date.
Any advice to get that third running 144hz would be great. Thanks.
https://www.pny.com/geforce-gtx-1060-xlr8-gaming-oc
https://www.asus.com/us/Monitors/VG248QE/
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      08-23-2019, 02:58 PM   #2
ntg44
ntg44's Avatar
Drives: R8 4.2 Spyder
If you unplug one of the 144hz monitors, can the 60hz monitor reach 144hz? Trying to eliminate sources of the problem I can think of.
      08-23-2019, 10:18 PM   #3
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
959
I tried and it did not work. I forgot to mention that the DP on the third monitor is not working for some reason... So when I used DP (on the gpu) to DVI on that monitor the monitor does turn on and work capped to 60hz but plugging in DP-DP it has no signal. I might have to borrow my friends monitor and see if it's the monitor. ffs
      08-23-2019, 10:28 PM   #4
Banana Hammock
Beefcake
Banana Hammock's Avatar
3738
Drives: R32 GTR
You might be hitting the Maximum Digital Resolution of the card. Try setting all of the panels to 120hz or lower.
      08-23-2019, 11:05 PM   #5
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
959
Tried that. Set the other two lower and the third is still capped to 60hz. It won't even give me any other option than 60hz.
      08-24-2019, 01:31 AM   #6
yco
i'm just saying
yco's Avatar
6049
Drives: E71 X6M '10 (sold)
when they re all double linked, and when you lower the resolution if it still doesnt give you higher hz.. then its probably the limit of the card or the combination limit.. to verify you might contact Asus..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
      08-24-2019, 11:47 AM   #7
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
A similar problem, but he has a 1080 and solved it by windows update.
https://www.nvidia.com/en-us/geforce...tors-at-144hz/
      08-24-2019, 10:18 PM   #8
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
959
Thanks for the help. I did some digging online and for some reason Asus monitors have an issue where they lose the DP signal/connection and need to have the power cable disconnected. I did that and it worked perfectly. All three running at 144hz.
