09-04-2019, 01:23 PM | #1 |
Rep 112
Drives: G30/M550ix 2019
Cargo Net for 2019 M550ix
I have been looking online and I can’t find a cargo net for the truck that says it’s fits in the 2019 G30s. Is anyone using one and if so do you know the part number? Thanks in advance.
09-04-2019, 01:38 PM | #2 | |
Rep 7,584
I'm not sure if you're familiar with the online part databases (or even if any where used in your search)....but I just did a generic search on the www.realoem.com website and they show a net for the 2019 550ix. Here's a direct link to the net where you can get its part nbr and either order it from your local dealership's parts dept or shop online to see if a vendor or BMW dealership with online presence sells it. If you click on the part nbr (when you go to the site)...you'll see that this net is used on multiple BMW models that range from the 1/2/3/4/5/6/7/x1/x3/x4/Z4 models used from 1997-to present: https://www.realoem.com/bmw/enUS/sho...diagId=03_0269 EDIT: I just did a generic google search...I typed "BMW xx xx x xxx xxx" (x = the bmw part nbr) into the search box and got lots of hits from multiple vendors.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-04-2019 at 01:51 PM.. |
09-05-2019, 09:59 PM | #3 |
Rep 7,584
Where you able to find the net using the 11 digit BMW part number?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
09-06-2019, 12:12 PM | #4 |
Rep 112
09-06-2019, 05:35 PM | #5 |
Rep 7,584
I wonder what would make it not fit...are the tie down loops different than other BMWs which would make the net incapable of being secured to the trunk?
Plus, if you enter your VIN (or model/model year/etc) into the BMW part database...you get that part nbr? So I wonder what would make it not fit...its a net with 4 tie-down hooks on each corner? Hmmm, perhaps BMW is going to make a trunk net specifically for the g30 5 series. Again, when you enter info for th eG30 5 series...that is the part nbr that comes up for the trunk net...and if you click on the BMW 11 digit BMW part nbr...the G30 5 series is listed along with the other BMW models that it is compatible with. Here's a direct link to that info on two different BMW online part database sited...click links below then scroll down to the g30 5 series models that use this net. If you need another verification...call your local BMW dealership's parts department and give them the same 11 digit BMW part nbr and ask them if it fits the g30 5 series.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-06-2019 at 05:46 PM.. |
