09-08-2019, 08:29 AM | #1 |
Rep 17
External SSD and G05
Hello,
I did some tests at the dealership with a 2TB SSD disk. It is formatted in FAT-32 and contains a folder with MP3s and a folder with FLACs. On an X3 G01, the SSD connected in USB-A was immediately recognized, but only the MP3 files were visible and readable. On an 8 Series (and according to the seller, the same multimedia system as the X5 G05), the SSD disk was not seen by the multimedia system, neither in USB-A, nor in USB-C. However, the disc was powered by the two USB sockets. How surprising that the G01 can power and read this SSD and not the G05, does anyone have an explanation? Should the disk be formatted in XFAT or other for the G05? The seller asked the importer the question but received no answer. Thank you in advance for your help. |
09-08-2019, 09:52 AM | #2 |
Rep 3,546
You said you tried both USB ports, does the SSD have an adapter or did you use a different cord for each? If so it could be the way the wire is made if not to spec.... Power is the same for any and all USB connections model so you will always have power.
Mine reads a USB micro stick just fine for MP3s, I have not tried FLACs. Maybe those who have tried will provide more input on this.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0 2019 718 Cayman Base 2015 M235 Manual On the list for the M2 CS |
09-08-2019, 10:33 AM | #3 | |
Rep 17
no need for an adapter no need for power supply The SSD disk behaves like a USB stick. Once again, no problem to read it on a G03! |
09-08-2019, 02:09 PM | #4 |
Rep 3,546
Yeah that is strange I know 2tb isn't to big my stick is bigger than that...
09-08-2019, 04:19 PM | #5 |
Rep 2,610
So we're "disk waving" around here now.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
