Which one is Bank 2 Sensor 2
09-16-2019, 02:39 PM | #1 |
Rep 1,268
I think I know the answer but want to check with everyone to make sure.
I believe Bank 2 is the rear exhaust down pipe and sensor 2 is after the CAT so it is item 5 in the drawing. I got a P0056 code so I want to make sure I replace the correct sensor, I may end up changing both post CAT sensor anyway. |
09-17-2019, 06:49 AM | #4 |
Rep 18,822
I second the answer. Bank 2 is the rear three cylinders: 4, 5, 6. Sensor 2 is always post cat.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
