09-26-2019, 11:37 AM | #1 |
Rep 905
tire options for 21"
Looking for options available for 21" tires. RF or AS. not concern with performance or type at the moment, just want to generate a list of tires to select from. Tirerack was a bit confusing from me
Front: 9.5Jx21” 275/40 R21 Rear: 10.0Jx21” 315/35 R21 Currently can only find these: Pirelli P Zero- summer RF Pirelli Scorpion Verde - all season RF |
09-28-2019, 12:31 PM | #2 |
Rep 4,530
Drives: 2022 iX xDrive50, DGM
AFAIK, Pirelli (or anyone else) doesn't make an AS RF 21" tire. At least I could never find them for my Audi.
dream54ing486.50 |
10-03-2019, 09:56 PM | #4 |
Rep 27
Discount Tire has some options
https://www.discounttiredirect.com/f...size/275-40-21 https://www.discounttiredirect.com/f...size/315-35-21 |
11-05-2019, 02:11 PM | #5 |
Rep 128
I can't seem to find any all season sets for the 21's. There are plenty of 275/40/21s and 315/40/21s but no 315/35/21. Just summers. Getting concerned that I might have to by a set of 20" rims with a square setup and toss the 21" with summer rubber in the garage for the winter.
11-07-2019, 08:21 AM | #6 | |
Rep 40
Drives: 2017 BMW X4 M40i
I just ordered a G06 and I love the 741M wheel, but I didn't order it because I'm in upstate NY and need all seasons for sure. My order hasn't started production yet so I can still add them if I find an appropriate all season tire, but I'm trying to avoid two sets of wheels. |
11-07-2019, 05:54 PM | #7 |
Rep 128
The ONLY option that I've seen are the Scorpion Verde's AS and they are not cheap...reviews are mixed on them but they really are the only All Season you can buy in 315/35/21s. If you want to stretch 295s to fit, there are a lot of options. I saw somewhere else in the site that someone stretched a 275 and said it worked but I'm not sure I want to do that. You can find the Verdes if you search around - Tire Rack has them for $600 for the rears!
By the time I buy 4 Verdes and have them mounted with TPMS it will cost me $2000. I think I may just buy 20" BMW 740M wheels and put on winters or good all seasons and swap the rims with the 21's each season. It might actually be cheaper in the long run. |
01-22-2020, 08:28 PM | #8 |
Rep 4
Just replaced the worn out pirellis on the staggered 21" setup. Had to improvise not willing to pay the price for a brand new set, so got a set of barely used Michelin pilot sport 4s.
Went with 265 40 21 in the front and got lucky with the same place having 295 35 21 in stock...so downsized in diameter a little bit but kept the rotational difference within spec. Just a heads up that you dont have to limit yourself so much to the stock sizing on the staggered setups. Have seen many more winter and AS options in the above sizes too. Dont need them in FL. Btw total cost for a set of 4 was <500 with 7-8" of thread depth. To each his own I guess. |
dream54ing486.50 |
01-22-2020, 09:36 PM | #9 |
Rep 303
+5 Aspect Ratio?
Wondering if anyone has tried, or considered going up 5 on the tire aspect ratio for the 21” wheels as a way to ditch factory run-flats. Looks like Tirerack has some decent non run-flat tire options at 275/45R21 (Front) & 315/40R21 (Rear).
01-23-2020, 08:15 AM | #10 | |
Rep 905
Unless someone says non RF's comfort is worth the risk (extra work if theres an issue) |
01-23-2020, 08:16 AM | #11 | |
Rep 905
Can you confirm those sizes fit? TireRack dont recommend it. Last edited by dream54ing; 01-23-2020 at 09:26 AM.. |
01-23-2020, 09:03 AM | #12 |
Rep 905
List for staggered 21" updated
OEM size Conti Premium Contact 6 S Run Flats Front: 275/40 R21 Rear: 315/35 R21 Pirelli P Zero- summer Run Flats Front: 275/40 R21 Rear: 315/35 R21 Pirelli Scorpion Verde - all season Run Flats Front: 275/40 R21 Rear: 315/35 R21 Other Options Michelin Pilot Sport 4 summer Run Flats Front: 265/40 R21 Rear: 295/35 R21 Michelin Primacy Tour all season non RF??? **TireRack said it might not fit Front: 275/45 R21 Rear: 315/40 R21 Michelin Latitude Sport 3 summer non RF???**TireRack said it might not fit Front: 275/45 R21 Rear: 315/40 R21 Conti Premium Contact 6 all season non RF???**TireRack said it might not fit Front: 275/45 R21 Rear: 315/40 R21 Pirelli Scorpion Zero all season non RF???**TireRack said it might not fit Front: 275/45 R21 Rear: 315/40 R21 Last edited by dream54ing; 01-23-2020 at 09:21 AM.. |
01-27-2020, 03:20 PM | #13 | |
Rep 198
So I am exactly in the same boat.
I prefer the 21" style (S01XD) style 744 instead of 20" style 738. I worked with a discount tire nearby my home today to get a quote for Pirelli Scorpion Verde A/S RFTs for the staggered wheels. The technician there suggested to buy the TPMS sensors($60 x4) in addition to the below highlighted tires. The total cost for tires+TPMS+tax = $2100. If I get the TPMS sensors, he mentioned the swapping of tires two times per year will be free of cost. Otherwise if they need to work with TPMS sensor during swapping, it will be $160 for labor for every appointment for swapping the tires. Quote:
01-29-2020, 12:10 PM | #14 | |
Rep 4,530
01-29-2020, 04:36 PM | #15 | ||
Rep 198
If you don't give your vehicle detail on the website, the rear tire shows up in pirelli brand in A/S option. The rear tires have VO in the end and that's why it filters it out if you put in your BMW details. The discount tyre representative on his console showed me these tires both front and back sizes and his system shows compatibility with 2020 BMW X5 compatibility. |
01-29-2020, 06:32 PM | #16 | |
Rep 4,530
https://www.discounttire.com/buy-tir...-verde/p/28795 https://tires.tirerack.com/search?as...w=21"+run+flat And these are all season tires, none of which are available as 21" run flats: https://www.discounttire.com/search?text=21"+all+season https://tires.tirerack.com/search?as...21"+all+season Last edited by Paladin1; 01-29-2020 at 07:10 PM.. |
01-30-2020, 09:39 AM | #17 |
Rep 905
List for staggered 21" updated - error corrected
OEM size Conti Premium Contact 6 S Run Flats Front: 275/40 R21 Rear: 315/35 R21 Pirelli P Zero- summer Run Flats Front: 275/40 R21 Rear: 315/35 R21 Pirelli Scorpion Verde - all season NON Run Flats Front: 275/40 R21 Rear: 315/35 R21 Other Options Michelin Pilot Sport 4 summer Run Flats Front: 265/40 R21 Rear: 295/35 R21 Michelin Primacy Tour all season non RF??? **TireRack said it might not fit Front: 275/45 R21 Rear: 315/40 R21 Michelin Latitude Sport 3 summer non RF???**TireRack said it might not fit Front: 275/45 R21 Rear: 315/40 R21 Conti Premium Contact 6 all season non RF???**TireRack said it might not fit Front: 275/45 R21 Rear: 315/40 R21 Pirelli Scorpion Zero all season non RF???**TireRack said it might not fit Front: 275/45 R21 Rear: 315/40 R21 |
01-30-2020, 11:54 AM | #18 | ||
Rep 198
Phew. That was close. Thank you very much. |
01-30-2020, 01:55 PM | #19 |
Rep 4,530
You're welcome! I was on the hunt for a long time with my previous Audi Q7 for 21" AS run flats with no success (no option for a spare even available in the Audi - just a tire repair kit). Pirelli didn't even have 21" all seasons for some time, so maybe there's hope in the future for run flat AS.
01-30-2020, 08:42 PM | #20 | |
Rep 198
I think I saw some RF options for front wheels and (now I stand corrected) not for the rears. |
01-31-2020, 10:46 AM | #21 |
Rep 198
Okay. So I am in a little bit of a pickle.
Yesterday when I realized that the Scorpion Verde are not RF, I scrambled to add the spare tire to my build. My AS called me today to tell me that my order already entered 150 state and is in production queue. So now I cant add the space saver tire for doing the A/S Scorpion Verde 21". What are my options? The way I see it I will have to keep a donut in my trunk, not great but I can live with it. Before I start researching, does anybody have any pointers? I hope I am not hijacking this thread. I feel its still in the context of 21" setups. |
01-31-2020, 10:55 AM | #22 | |
Rep 905
