10-02-2019, 12:36 AM | #1 |
Rep 17
Hey guys,
So I a struggled for months trying to find a mid-range/entry level suspension setup in my budget and with the adjustability I wanted. KW V3's are amazing but more than I wanted to pay and offer some adjustability i would never use. And the few other options I looked at were H&R coilovers and KW HAS. H&R are apparently a great setup but don't offer any dampening adjustment and that kind of turned me off. KW HAS seems like a solid way to go but I had heard many stories of them feeling a little bouncy over time. I ended up pulling the trigger on the BC BR series and I must say. I'm very impressed with what you get for what you pay. If you only plan on doing some spirited street driving/autocross. This suspension is perfect. The install was very simple( I had a hoist ) and the ability to adjust the dampening made these ride better than stock. My car is still sitting a little too low in the front. But aside from that I'm very happy with this product for an "entry level" Coilover. I'll attach some pics for motivation if you plan on lowering your f87, Cheers! |
10-02-2019, 10:18 AM | #2 |
Rep 103
Thanks for your opinion, I would also like this suspension, I do not run on the circuit, just some mountain road and some 1/4 mile pulls but I want the lowest car. I had this suspension in my previous 135i and it worked very well for years. Can you put pictures? Thank you!
10-02-2019, 10:28 AM | #3 |
Rep 103
10-02-2019, 11:12 AM | #4 | |
Rep 17
10-13-2019, 11:05 PM | #10 |
Rep 23
Wow this looks amazing (love the photography as well). The BC coils are very popular in the japanese car community so I'm happy someone decided to try them out for the m2, I have a set of KW HAS that I haven't mounted yet but if I absolutely hate them I'll probably switch to these. How does the ride compare to stock?
Also, do you rub at all with 12mm spacers all around? I've noticed people often do 12 in the front and 10 in the rear |
10-14-2019, 12:15 AM | #11 | |
Rep 17
As for rubbing. It rubs slightly in the front where the fender meets the front bumper. But I'm a little lower than I should be. If I went a little higher in the front it wouldn't rub at all. |
10-21-2019, 12:33 PM | #14 |
Rep 17
10-26-2019, 07:22 PM | #15 |
Rep 245
Drives: F10 M5, E36 M3
OP any updates on your thoughts on these? Did you get the extenders? The available Swift springs?
11-01-2019, 11:02 AM | #16 |
Rep 17
Still loving them, and I did not get the extenders. They are kind of useless on the m2 because of the way the top mount in the rear works. It's easier to just make adjustments by jacking up the car. And I did not go with swift springs. These are great. I assume swift are even better.
11-08-2019, 08:17 AM | #18 |
Rep 128
Amazing photos. My car is lowered on Ohlins, has 10mm spacers, yet doesn't look anywhere as good and I wish I knew why
Maybe it's all in my head
2016 Grand Cherokee Ecodiesel - 2012 1M - 2003 E55 AMG - 2005 Nissan 350z 35th anniversary - 1998 BMW 530D - 2003 Alfa Romeo 147 GTA - 1992 Mercedes W124 500E - 1992 Ford Escort Cosworth - 1989 BMW E30 325IX - 1988 Peugeot 405 Mi16 - 1963 Chevy Impala SS 2dr hardtop
11-24-2019, 10:46 PM | #19 |
Rep 2,142
Nice photos!
How much drop was yours set at? I’m trying to achieve maybe 3/4 - 1” drop from stock height. Do you think this is possible with the setting at Max. height? Thanks! |
11-25-2019, 12:14 AM | #20 |
Rep 17
I've adjusted the height multiple times to get it to where it is. I'm not too sure how much of a drop im at in comparison to stock. But if I wanted to raise it close to stock I would have enough threads to do so
11-27-2019, 07:59 AM | #21 |
Rep 2,142
06-20-2022, 04:27 AM | #22 |
Rep 4
Here to revive the post. OP, thank you for posting your pics. I am on the same boat debating the KW HAS or the BC BR series. I've ran BC BR series on all my other builds and after reading through here, I'll be pulling the trigger with BC again. Thanks again for posting!
