Torture test: VK Motorwerks oil cooler
08-23-2008, 05:43 PM | #1 |
Rep 1,714
I had the opportunity to test out the VK Motorwerks oil cooler on a road course recently.
In the past, I was able to consistently get my oil temps to 285-300 degrees (never to 304 limp) within a few laps. The 285 would be achieved in 50-60degree ambients and 300 achieved in 95+ ambients. This is with the factory oil cooler. I've tried various oil brands, viscosities, etc and nothing made much of a difference. Needless to say, those temps concerned me. After a few manufacturing delays, which were nothing compared to other vendors , I got my oil cooler from Vince. Armed with the DIY guide, I attempted to install it myself. I consider myself fairly technical, so I didn't think it would be too challenging. While I did finally get it done, after two consecutive evenings working on it, I would not recommend this DIY for a novice. Save yourself a lot of pain and get a shop to install it. If you're handy and have 7/10 skill level, give it a go. On the drive to the track, I was getting consistent 230 degree oil temps. Nothing extraordinary, but then again, I never get high temps during street driving. But I also drive like a housewife on the street. So how did perform on track? Keep in mind that this is a track I've been to 25+ times and know exactly how hot I can get the oil. FWIW - I am an instructor level driver. Through the course of four hours of testing, the oil never exceeded 275 degrees. The amazing part is that the 275 was only achieved after a 40 minute hot lap session, a session length you would never see during normal track events. During any given 20 minute session, I could only get 265 oil temps! If I had been running the stock oil cooler, I would EASILY been at 285-290 after a 20 minute session. So we're talking a 20-25 degree reduction in oil temps from the VK cooler, given equal conditions. If you're driving your car hard or god help you, you take your car to the track, I highly recommend this cooler. It may not produce much more power (maybe it increases power since the engine runs cooler and is less likely to dial back timing?), but it will certainly save your engine in the long run. Something about 300 degree oil temps on a stock oil cooler doesn't sit right with me. |
08-23-2008, 08:55 PM | #3 |
Rep 263
VK Motorwerks OC
Great Review. Good job Vince! cant wait to get mine installed soon.
335i coupe Procede
700 HP EPL Tuned Porsche 911 Turbo E46 M3 SMG BMW X5 4.8 is |
08-24-2008, 04:38 AM | #4 |
Rep 1,575
Thats good news...My temps are getting above 120 Celcius (250 degrees) just in a single WOT from 2nd to 5th gear. This is really annoying.
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
08-24-2008, 07:48 AM | #7 |
Rep 2,989
08-24-2008, 11:38 AM | #8 |
Rep 1,738
Great review! Im glad to hear that your enjoying your OC and your car.
As for the full kit, we havent released it because we feel that the demand is not strong enough. Most people are able to plead their case with BMW and obtain a OEM OC. If your able to obtain it from BMW and have them do the install, it should save you a good amount of money. |
08-24-2008, 12:09 PM | #9 |
Rep 1,714
Ambients got up into the 80s. With stock cooler, I'd easily be at 285-290. With the VK, the damn needle wouldn't move past 265 on a regular 20 minute session.
08-24-2008, 12:40 PM | #12 |
Rep 1,738
08-24-2008, 12:46 PM | #13 |
Rep 525
actually, a oil cooler does help our N54 engines provide more power.
i raced my friend 335i sport without a oil cooler to mine, he lost by at least a length and the beating became worse after each run!!!!!!! cooler oil temps def help. just to add: my friend got this barbones e92 335xi yesterday, he has no oil cooler and of course the XI drag, no sport suspension and higher level of gravity, the car felt like a pig!! after a short burst on the highway it became evident, that there was a good amount of power lost, via extra heat from no oil cooler. |
08-24-2008, 01:25 PM | #14 |
Rep 4,445
LCM, nice review, nothing wrong with driving like a housewife on the street. Those track days do make you conscious of those "other" drivers on the road.
08-24-2008, 04:25 PM | #16 | |
Rep 83
I sent you two e-mails but never heard back from you. I was asking the same question.
Stanley
TiSi E90 335i |
08-24-2008, 09:26 PM | #18 |
Rep 1,738
08-25-2008, 08:04 AM | #20 |
v81 user
Rep 174
you guys do understand that there is an optimal operating temp range for oil, right?
160 = bad, 180 = good, 220-265 = best there is nothing wrong with 285deg oil in a track environment |
08-25-2008, 10:55 AM | #21 | |
Rep 1,714
Additionally, even at 285 oil temps, the coolant temps are nearly 240, which means that the ECU starts cutting boost completely. Any of the heavy track users will attest to losing boost with high temps. With my cooler oil temps, the coolant temps were lower also. Makes sense even though they cool different parts of the engine. There is a finite amount of engine heat to be carried away. |
