PROcede V3 / DCI & 7.11 stage1 beta map - call a spade a spade
08-24-2008, 03:40 PM | #1 |
Rep 4,481
Hi,
Not a fanboy of Vishnu and installed a PnP PROcede V3 today together with the Vishnu DCI on an e93 manual of a friend of mine ( MSD80 pre-29.2 ). Loaded 7-11 firmware and the non-doomsday beta stage1 map. The install has been easy, the PnP harness is huge. However, the harness and the remote switch receiver fitted pretty good in the ECU-box. Damn, the car is fast. Stock UT settings, 93 octane gas. Everything else is stock, power-wise. No boost gauge on this car . IMO big improvements compared to V2. Nice tune . Someone knows how much power it should provide ? - Eugen |
08-24-2008, 03:45 PM | #2 |
Rep 5,389
What's the "DCI?"
btw -- glad you finally like the PROcede (v3 PnP)! It's a great tune.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
08-24-2008, 03:52 PM | #5 |
Rep 5,389
Got 'ya. Yeah, Shiv has always said the stock airbox is the main power restriction of the 335i. So, I guess one of these DCIs would help to increase HP/TQ even more when combined with an ECU tune.
08-24-2008, 04:14 PM | #8 |
Rep 10,858
So you guys going to compare them (Noelle & V3)?
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
08-24-2008, 04:21 PM | #9 |
Rep 4,481
Yes. He has a manual and will get my current Turbonetics / Spearco FMIC. I will install the Code3 / Spearco for steptronics and the BMW performance intake, once it's out. We also will install the latest Vishnu firmware and maps.
Then it's time to compare . The Noelle tune together with the Spearco makes 14.8 psi and spikes during WOT step shifting up to 15.5 psi ( very short spike and rarely ). In case this turns out to be reliable on the long term it's simply great ! |
08-24-2008, 05:40 PM | #10 |
Several N54 cars, V1,3, V2.0.2, and V3.1
12
Rep 778
V2 should make the same power as V3 and even more than V3 in hot conditions. At the moment the V2 support is slightly behind and the UT settings need to be adjusted slightly up at high revs for having the equivalent of the V3 intake map. Easy to do.
V2 allows for short term overboost similarly to e.g. 911 turbo and is the professional (pinout) style. |
08-24-2008, 09:36 PM | #12 |
Rep 1,310
08-25-2008, 09:39 AM | #13 |
Rep 467
I AM the friend.
I wished to thank again Eugen for the perfect install of V3 harness and Cone intakes. Actually Eugen's car feels fast. Very fast. My one felt ok, then I realized I should push the on button on the remote controller to have the aggressive map on, then I did it and Whoaa!!! I also have a sprint booster sport accelerator bypass in my car and I suggest everybody to get one! After the Spearco install, we will compare the two cars! stay tuned!
Current: e93 335 Msport, black sapphire on sanbeige, MT, 19" rims 225m, satnav, usb, CA, voice control, HBA, windstop, heated seats.
08-25-2008, 10:37 AM | #14 |
Rep 4,484
Since Eugen has an auto and you a manual, it will be hard to "compare" the tunes.
As he'd have a bit of an advantage with the auto as it is and there is no "shifting" speed from driver to contend with. I will say this though, if the manual car outruns Eugen in the auto by ar CL or so, it would be safe to say the V3 is clearly faster. But if it's vice versa it could just be the auto's advantage and/or a slow shifting manual driver. |
08-25-2008, 10:53 AM | #16 | |
Rep 467
08-25-2008, 10:54 AM | #17 |
Vishnu Powered
69
Rep 2,205
Congrats on the tune! Glad you finally were able try out V3 eugen.
Wha wha what?
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3 |
08-25-2008, 10:54 AM | #18 |
Rep 467
Ok then, we will arrange an autobahn challenge, starting at 155 mph. Please look after our children if we do not come back ....
08-25-2008, 11:29 AM | #19 |
Rep 4,484
Have you tested that??? I've ran several MT's in my AT car up to 120 mph (even when stock) and each time I was still creeping away. AT may have more drivetrain loss, but it's VERY minimal according to BMW and from dynos I've seen. (5-8 rwhp) But the AT has a shorter gearing ratio (for better acceleration) and has shift speeds faster than 99% of manual drivers, so those two things more than make up for the few extra hp lossed due to drivetrain of the AT. I would do a 3rd gear start of 60 mph and go to 120 or so in this comparison. This way there is only 1 shift involved for both cars. |
08-25-2008, 11:59 AM | #20 | |
12
Rep 778
08-25-2008, 12:05 PM | #21 |
Rep 4,481
Looks like Stefano and me have to test at the Nardo track . Both cars should exceed 300 kph. I assume we will be pretty close ...
Nardo: http://www.silhouet.com/motorsport/tracks/nardo.html However, lets start to dyno in 5th gear. This will give us accurate crank hp / tq numbers ( the only numbers that count, whp is depending on the gear you dyno, to be politically correct ). V3 customers can do this. |
08-25-2008, 12:31 PM | #22 |
Rep 10,858
Woohoo, what a party! Eugen and Stefano got it together with tunes! This is going to rock!!! Wish I was over in Euro for a roadtrip.
Have fun and be safe.
