10-16-2019, 06:22 PM | #1 |
Rep 660
M Perf Coilover Front Compression Wheel Fell Off?
Hey all,
Wondering if anyone else has experienced this situation? I recently went to adjust my suspension settings, and was shocked to find both front compression adjustment wheels were straight up missing. These are the adjustment wheels that are at the bottom of the front struts. I figured they would be held more securely in place, but seems like it was just adhesive? (I did some some spirited driving recently ). I did some searching online and haven't really ever heard of this happening. I couldn't even find a part number. I'll be seeing my dealership in a few weeks for my regular service so I'll bring it up then since they installed it and it should be covered, but it's kind of annoying in the meantime. |
10-16-2019, 07:48 PM | #2 |
Rep 2,526
Haven't heard of that. Your dealership should cover it.
Hell, I went in for a tech inspection and mentioned an annoying exhaust rattle on my MPE. The MPE was purchased from a 3rd party and installed in someone's garage. They said the muffler itself had something rattling inside and ordered a replacement for me, installed free of charge. As long as you have a decent dealership I do not see a problem with them fixing it for you. |
10-17-2019, 12:22 PM | #3 | |
Rep 660
10-18-2019, 05:08 AM | #4 |
Rep 1,962
Mine were seized after a winter of road salt. Noting that I used a spanner to un-seize them (along with some Teflon lube), mine appear to be firmly attached to the adjuster mechanism.
How much of the adjuster is left in place on yours? |
10-20-2019, 12:56 AM | #5 |
Rep 660
I just see the metal shaft that the compression adjustment wheel was attached to.
10-20-2019, 04:23 AM | #6 |
Rep 4,529
I spray release agent/water repellent and mobilise comp adjusters on front struts every 6-8weeks to ensure the adjustment shaft doesn't sieze
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
10-31-2019, 02:14 PM | #7 |
Rep 660
A quick update:
The car is at the dealership, and they said they're looking at it. My service advisor said the techs are saying that the adjustment wheel should actually be in the coilover adjustment kit, NOT attached to the bottom. This is odd because when the coilovers arrived, and when they were installed, the front compression wheels were definitely attached, and I don't think I could have removed them if I tried. Can anyone with M Perf or KW V2/3 (forget which ones are equivalent) verify that the compression wheels for the front shocks are permanently attached? They said they are looking for the part (compression adjustment wheel) but aren't having much luck. EDIT: Looking at several pictures (i.e. https://www.bimmerworld.com/Suspensi...nsion-Kit.html), it does looks like the compression adjustment wheels come mounted onto the shocks. |
10-31-2019, 02:32 PM | #8 |
Rep 1,962
There is an adjuster 'wheel' (an Allen Key with a fancy handle) that comes in the case, but that's for the top of the front shocks, not the bottom.
So, your dealership is 'improvising'... |
10-31-2019, 02:52 PM | #9 | |
Rep 660
For sure haha, they're definitely known to do that. As long as they can find replacement compression adjustment wheels I'm happy. It's actually sort of interesting how hard it is to find this part - I could not find mention of it online at all (although I won't claim to be savvy about finding BMW parts). |
11-03-2019, 08:11 AM | #10 |
Rep 4,529
That's the front Rebound adjuster
11-03-2019, 10:55 AM | #12 | |
Rep 650
11-04-2019, 02:01 PM | #13 | |
Rep 660
Unfortunately for me they both fell off at the same time I will call my dealership to see if they have found the part yet, although I'm not too hopeful at this point. |
01-09-2020, 01:44 PM | #14 |
Rep 660
Just wanted to update this thread:
Roughly 1 month after I started talking to my SA, he said they could not find the replacement knobs, and would replace both my front shocks. I provide my receipt of purchase for the coilovers and he tells me it's on it's way from Germany. Nearly 3 months later (after multiple attempts to get in contact with my SA - I think he's avoiding me now), I finally get a call with him, only to hear they have NOT ordered the parts yet. This time they need the actual invoice - so I call the business I bought it from and get that and emailed it to him. Still waiting for a response on that. Due to my frustration, I called up KW and asked if they had the part number. KW doesn't list this particular part for sale on their site, but if you call them, they will give you the part number (#68525011) and you can order it directly, so they were extremely helpful and I appreciate that. However, the color scheme is off (the wheel is purple) vs. black on the M Perf Coilovers, so I would rather have BMW source it (how is it this difficult???). Anyways, we'll see what happens. |
01-14-2020, 03:27 AM | #16 |
Rep 660
True, it's more of "the principle" sort of thing. And potentially resale value. And those adjustment wheels are surprisingly expensive for little pieces of metal (I think it was ~$30 each).
Anyhow, I paid extra to get the coilovers installed at the dealership (to satisfy the conditions of the warranty). Otherwise, I would have bought those damned wheels already lol. |
