11-09-2019, 02:25 PM | #1 |
Rep 5,741
Drives: '24 iX50; '23 i4 M50
17mm Lug Bolts, Correct?
I can still use my 17mm socket for the G05? The lug bolts look different than my F80 M3. I thought I read somewhere that the G chassis not only changed bolt pattern but lug bolts? However, according to wheel-size.com, both the G05 and F80 have the same M14 x 1.25
arciga18??
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
11-12-2019, 10:33 PM | #2 | |
Rep 18,751
Kief4462.00 |
01-03-2020, 01:05 PM | #4 | |
Rep 18,751
They are the same cone shape and degree.
arciga181731.00 |
01-03-2020, 01:13 PM | #5 |
Rep 3,654
Here are some crude before and after.
15mm h and r from our good friend r33_RGSport |
r33_RGSport13045.50 |
01-03-2020, 01:26 PM | #6 |
Rep 3,654
To clarify 15mm on all four corners .
Here is the rear . |
01-03-2020, 03:05 PM | #8 |
Rep 18,751
I put 110lbs-ft when using spacers.
JoeAyalaM165.00 |
01-03-2020, 03:18 PM | #9 |
Rep 3,654
