BIMMERPOST Universal Forums Off-Topic Discussions Board What's the best way to apply contact lenses?
      11-11-2019, 05:44 PM   #1
WTF??? Is there anything on earth more frustrating than trying to get a tiny piece of silicone into your eye?
Who has the secret of getting the damn things to not stick to your finger?
      11-11-2019, 05:50 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I learned that don't allow your finger to touch the eyeball. I just started wearing contacts and the trick I learned at least for me is once the contact makes contact with your eye it should take. Almost like a suction. If you press and your finger makes contact with your eyeball I notice it sticks to your finger tip
Another pointer is make sure your fingertip that holds the contact is somewhat dry and not wet
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      11-11-2019, 05:55 PM   #3
EyeGuy
Drives: 08 335xi coupe, 17 nx200t, 23
Make sure your finger is dry under the contact lens, and place it on your finger tip. It must look like a bowl on your finger tip with out any of the edge folded over. Hold both lids open so you can’t blink. It’s best to hold along with the eye lash. Insert lens making sure to clear eye lashes. It should suction once close enough.
Once in don’t blink right away. Look up, down, left and right before you blink to make sure lens is seated correctly.
      11-11-2019, 06:03 PM   #4
2000cs
Drives: Potato
Lasik
hubbahubba12374.50
c1pher5135.00
      11-11-2019, 06:10 PM   #5
JP10
JP10's Avatar
Drives: M3
Open your eye, stick that little bitch right on your pupil. Done. Lol kidding but that's atleast what it seems like for me after wearing them for a decade.
Like others mentioned keep the finger that you're using to put the contact in dry. Have it barely touching and place it in. Should take. If your eyes are dry prior to putting them in throw a pop of solution in them.
Considered lasik for a while now. Would love not to have to fiddle with contacts and glasses. I just got daily contacts though and they're amazing can't even tell that they're in
      11-11-2019, 06:16 PM   #6
Thanks. Same advice Wifey keeps giving me. I seem to have a hard time with the dry finger part. I mean you have to take the lens out of a solution, so your finger is going to be wet. I may be pushing a bit too much trying to get it into my eye, though. I'll try a little more finesse.
I mainly wanted these so I could stop paying big bucks for prescription sunglasses and riding glasses. Not sure I'm coordinated enough to do this, though. I don't chew gum because I *have* to walk. Sometimes you gotta make sacrifices to get the important stuff done.
      11-11-2019, 06:22 PM   #7
Originally Posted by 2000cs View Post
Lasik
Not an option for me, I think. Not sure I'd want to go that route anyway. Sticking a piece of silicone in my eye was hard enough to talk myself into.
      11-11-2019, 06:52 PM   #8
JP10
JP10's Avatar
Drives: M3
I take it out of the case with my pointer finger and thumb, then grab it with my left hand and put it on my right middle finger (that's dry).
      11-11-2019, 07:00 PM   #9
2000cs
Drives: Potato
I did it almost 20 years ago and have never looked back (figuratively). Not a fan of glasses, contacts, etc so finally screwed up my courage to get lasik done - was a piece of cake (as is cataract surgery I hear, a similar process). If you look into it, be sure you go to someone with the best equipment and lots of experience to be sure.
      11-11-2019, 07:00 PM   #10
Mason Hatcher
Drives: BMW X3
I have worn lenses for over 30 years. I just pop them in and don't even think about it, but finger dry and hold eyelid open with other hand.
Rmtt8201.00
      11-11-2019, 07:31 PM   #11
pennsiveguy
pennsiveguy's Avatar
Drives: F15 xDrive50i M-sport
Getting 2 500cc sacks of it into your mouth isn't easy either. More fun, though!
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
Rmtt8201.00
UncleWede18691.00
      11-11-2019, 07:39 PM   #12
Rmtt
Rmtt's Avatar
Drives: 2011 BMW 128i, 2008 LS3 C6
Same here....when I started....it was hard lenses. Those were a PITA.
Everybody has a gameplan....until they get punched in the mouth.
      11-11-2019, 07:39 PM   #13
Rmtt
Rmtt's Avatar
Practice..Practice....Practice! Works for me.
King Rudi13071.00
      11-11-2019, 07:57 PM   #14
lsturbointeg
I will say since switching from glasses to contacts my head doesn't feel like I have it in a fish bowl
also, for those with contacts what are your recommendations for rewetting/lubricating drops? the equate brand sux but there's so many out there I wanted to know which one's you guys like best after trial and error...thanks!
      11-11-2019, 08:05 PM   #15
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
I’ve been wearing contacts for forty years. Make sure the lens is a little wet, too dry and it will stick to your finger. Put lens on pointer finger, use middle finger on the same hand and put it on the lower lid. Looking up a little bring the lens to your eye. It simply takes practice.
      11-11-2019, 08:22 PM   #16
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
Lasik
PRK. What a blessing. I was fortunate that the Navy did this for me, but I was also shopping to get it done. After reading all the research the military did, I felt PRK was the way to go since a blow to the face or eye wouldn’t cause a flap to reopen since it’s surface ablation and leaves the eye in tact. Unfortunately PRK isn’t possible for severe myopia (I think).
2000cs4103.00
      11-11-2019, 08:57 PM   #17
No one
Drives: F21 118i
Have your finger clean. I don't even wipe hands for that. Dry or wet doesn't really matter.
      11-12-2019, 04:04 AM   #18
cmyx6go
cmyx6go's Avatar
17262
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
Agree with everyone on finger needs to be dry. Lens and eye need to be wet. If your eye is dry you will struggle. Grab the lens with the other hand and transfer to finger you will use once finger is dry. Position it center of fingertip. Add a drop of saline solution. This will help it adhere to your eye.
I use my middle finger to put lens in, my ring finger to pull down lower eye lid and a finger from other hand to lift upper eye lid. If your eyes are dry, use some eye drops before you put lens in. You’ll get the hang of it. Now picture me doing it with long nails.
Rmtt8201.00
      11-12-2019, 04:31 AM   #19
cmyx6go
cmyx6go's Avatar
17262
I really like Blink Contacts. Been using it a few years.
      11-12-2019, 04:35 AM   #20
Ivan Ivanov
Ivan Ivanov's Avatar
Russian Federation
1772
Drives: X1, X3
I use contact lenses only if I go hunting. And I use my wife to put them on - it's very convenient )))
      11-12-2019, 10:30 AM   #21
Practice touching your eyeball first, no lens. Desensitizes yourself to blinking as the lens comes in.
Decades ago my eye Dr. quit even trying to insert them for me. I stick out my index finger and she drops in on. Sometimes, I still take it int he other hand and wipe that index finger dry.
      11-12-2019, 11:45 AM   #22
Matt@EuroJerks
Drives: 2021 Jeep Cherokee
I use this technique. I also use my other hand to hold my top lid up by reaching over my head from behind. Right hand goes to my left eye.
