slippery slope....more power!
11-15-2019, 01:20 PM | #1 |
Rep 21
So im about 6 months into my new to me ride...2011 335i e90 m sport w/ PPK. Im coming from the Jeep world so the performance was night and day as you can imagine. but now im use to it and want more! my goal initially was to get a more baby friendly ride and its primarily used as a daily commuter...short ride to and from work.
after some research(this site mostly - https://bmwtuning.co/build-400whp-n55/ ), I wanted to get the community's opinion on if this is worth the investment and potential aggravation. Here is what i plan to install and comments/concerns about it. JB4 tune - as i have the PPK, is it still plug and play or do i have to deactivate it somehow and if I want to go back to PPK is that a PIA? BMS intake - mostly to hear that turbo! 5" FMIC - worth the $$$ over stock and this setup? One thing im 99% sure i dont want is the catless downpipe. mostly due to noise and PIA DIY. I guess my main questions are: without the catless downpipe, am i really handcuffing my goal? would this setup only be a marginal bump in power compared to what i have? fyi - i have the bmw m sport mufflers. |
11-15-2019, 01:30 PM | #2 |
Rep 1,025
Just the JB4 will get you what you're looking for, I think. There are additional gains to be had with the downpipe and FMIC (I would do them in that order), but they are small compared to the initial tune, so go ahead and do that, and go from there. No changes to the PPK required - the JB4 is fully piggy-back, so the car doesn't even know it's there.
I wouldn't do the BMS intake, personally. I installed one in my 2011 and it was just annoying noises, so I removed it. I think I still have it sitting in a box somewhere, actually, if you want one for super-cheap. Speaking from my experience with an N55 with JB4 and catless DP, as well as an N54 with pretty much everything done to it except meth and upgraded turbos.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
NRainbolt0.00 |
11-15-2019, 01:40 PM | #3 |
Rep 1,420
I am N54 but I would do MHD over JB4. It's a true flash tune and does loads more then JB4 but this is just my opinion. Also I would do Downpipes if you don't have to mess with emissions. That is going to give you the biggest bolt on power. Then FMIC. I have a 5" ETS for sale I can throw you a good price. PM me if you want. And as said before, DCI is more useful of you are always wrenching so you don't have to remove the box but it's not that important.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
11-15-2019, 02:03 PM | #4 | |
Rep 3,732
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
ReForMatt2.00 |
11-17-2019, 07:24 PM | #5 |
Rep 1,080
You can probably do almost as much for performance by staying in a lower gear. Also, increasing hp does not increase performance by as much as you think, as doubling hp might decrease 0-60 times by 0.707. Now, removing weight is directly proportional to reducing 0-60 times.
11-17-2019, 08:01 PM | #6 | |
Rep 3,732
11-18-2019, 07:01 AM | #7 | |
Rep 1,893
OP - JB4 can only regulate boost - it cannot affect ignition timing and fueling. Thus, the standalone JB4 depends on the ability of the DME to adjust those critical parameters within its modest ability to do so. You leave a ton of power on the table if you do not flash a tune that sets timing and fuel delivery parameters appropriately. True, Burger makes freely available what they call "back-end" flashes that provide the missing functionality but you'll need to buy the MHD anyway to flash them! That said, JB4 has some nice features, for example, the ability to rapidly adjust boost parameters, set custom parameters for meth injection and "hijack" dash gauges for other purposes like real-time boost readout. Also, to echo NoGurus assertion, removing the cat is the single most effective hardware modification of the FBO variety you can make. You'll get far more out of that then from intake or muffler mods. And in the N55, it's a very pleasant DIY. And finally, to address your concern about noise, removing the cat has relatively little impact on idle and part-throttle sound levels as long as you delete or minimize cold start enrichment (a routine put in place to warm up the cats). That's easy done by checking a box in the MHD app. You'll make noise when you floor it but you're not going to attract any attention otherwise. Last edited by dpaul; 11-18-2019 at 09:11 AM.. |
relative4612.00 |
11-18-2019, 08:36 AM | #8 |
Rep 1,080
For lqrace, from the basic laws of physics, as force = mass x acceleration, with an increase in acceleration being directly proportional to a reduction in mass, assuming force stays the same.
11-18-2019, 08:45 AM | #9 |
Rep 1,080
Also, if you look at cars such as the 328 and 335, the increase or decrease in acceleration times is approximately equal to the square root of the ratio of the change in horsepower.
Of note, braking distances go up by the square of the change in speed, such that a doubling in speed, say from 30 to 60 mph, causes the stopping distance to go up by a factor of 4. |
11-18-2019, 08:59 AM | #10 |
Rep 3,732
Did you factor in wheel hop (or lack of), weight transfer, gear ratios, torque curves, at or Mt transmission, hp curves, etc, etc ...
It's not as easy as a simple physics equation..... You lost all credibility when you said "You can probably do almost as much for performance by staying in a lower gear" in your post above. Try telling that to a guy in a stock 335i that just got outran by a FBO 335i......"you should have just stayed in a lower gear". What are you talking about.?? Haha...... whatever you say. Last edited by iqraceworks; 11-18-2019 at 09:05 AM.. |
11-18-2019, 09:40 AM | #11 |
Rep 595
Go with a flash tune like MHD and buy the monitor logging feature while your at it. Then you can have live gauges and readouts (boost psi, inlet air temps, coolant temp, transmission temp, fuel pressure readout etc. Tons of stuff!) With MHD you'll have tunes with the mods you have listed beginning with stage 1 all the way to stage 2 + and e85 mix tunes. So for example, lets say you stay stock you can safely run the stage 1 tune and notice a nice bump. Decide to get catless downpipes couple months later now you can enjoy stage 1+. Each stage has description of what mods are recommended to properly use the tune. Initial flash takes about 40-50 minutes and then any other flash or changes in between takes 2 mins or less. You also have the ability to delete cold starts, play with the burble settings, and other small customize able options.
All you'll need is an android tablet or phone that supports OTG and a pre-tested cable. And also, as a bonus MHD is a great check engine light reader for advanced BMW and generic codes. |
11-18-2019, 11:50 AM | #13 |
Rep 1,080
Also, are we talking around town power, race course power, or stoplight grand prix power.
And again, for around town, it most certainly does depend on where you are on the torque and power curve, which is why I suggested saving the money and staying in a lower gear. Even my Honda Ody van feels peppy when I stay in third gear! |
11-18-2019, 12:35 PM | #14 | |
Rep 1,420
Doesn't matter where or how you use it.
11-18-2019, 01:06 PM | #15 | |
Rep 3,732
Your Honda van seems "peppy"? Now you've really lost me.... Have you ever driven a stock (or modded) 335i ???
11-18-2019, 01:47 PM | #16 |
Rep 1,080
LQ, my previous driver was a '98 M3, which I just gave to my son. My current car is 2011 328i, with both cars having plenty of power for me.
That said, when I lived in NYC as a kid, I did stop light Grand Prix's, with my father's 6 cylinder, 1963, Ford Galaxie 500. Never won though! Again, the best, most efficient, and easiest way to increase performance is to lose weight. In conclusion, I'll keep my reality, and you certainly are entitled to your reality. |
11-18-2019, 02:13 PM | #17 | |
Rep 3,732
Lets say you have a 300hp car that weights 3,500lbs (a stock 355i)...that's 11.6 lbs per hp). You can do a stage1 MHD flash tune, and gain 80hp roughly. So now you have a 380hp car that's 3,500lbs (9.2 lbs per hp).....and it cost around $200 and took 40min. If you had the 300hp and wanted to gain the same advantage by only reducing weight to obtain the 9.2 lbs per hp.....you would need to lose 720lbs. 300hp in a 2,780lb car is 9.2 lb per hp. So tell me how you are going to lose 720lbs faster than 40min, and cheaper than $200..... But maybe I'm doing the math wrong here.....
11-18-2019, 02:49 PM | #18 |
Rep 1,080
Well, I may have to say 'uncle', as I did some calcs for 0 - 60 times, using this website:
https://www.carspecs.us/calculator/0-60 And you're right, all things being equal, I would have to lose about 700 lbs. |
NoGuru772.00 |
11-19-2019, 06:34 PM | #19 |
Rep 4,330
MHD as stated.
is you car auto? XHP will make a profound difference in driveability without adding any horsepower. and yes, you will be seriously handicapping your power gains if you stay with the catted downpipes. a lot of the factory conservativeness in the tune is to keep the cats from melting down. |
11-19-2019, 07:37 PM | #21 |
Old Guy
133
Rep 305
Drives: 335is DCT
Maintenance before mods or you'll most likely be chasing problems. Go MHD and be done with it. Use common sense. If a map in MHD says you should have certain things, then don't use that map until you have those things. There is a reason for those lists even if you have someone telling you that don't follow them. Use the search function here. These cars are 10+ years old. Any question you have will not be first time it's been asked.
NoGuru772.00 |
11-19-2019, 07:45 PM | #22 | |
Rep 3,732
