11-16-2019, 05:31 AM | #1 |
Rep 5,741
Drives: '24 iX50; '23 i4 M50
22" PSI?
What's everyone setting their 22" psi at? I think 39/45 (as per USA manual & door jam) is too high, no? 39/45 is for under 100mph but with the car loaded with passengers and/or luggage.
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
11-16-2019, 08:04 AM | #2 |
Rep 1,077
The door jam sticker is for full load. 5 passengers and cargo. If you drive alone or with 2, I would keep the preassures in the 30s. Will be more cmfortable and with spirited driving they will warm up. Your target preassures will be high 30s or 40
Start with 35 front 38 rear -cold. See how it feels I think bmw is cautious too because they are low profile tires on a heavy car. So if you drive over curbs or big potholes there is a possibility of pussing through to the rim |
11-16-2019, 08:18 AM | #3 | |
Rep 5,741
You would think lower psi would provide more cushion for the wheel? I'm going to try 3 psi lower all around 36/42
dubsesd6343.50 |
11-16-2019, 04:08 PM | #5 |
Rep 236
Interestingly in the uk/European market the 22 run at 32psi front 35 psi rear. That’s for all models which obviously weigh different due to engine sizes. That’s the lower settings for up to 5 pax . Can be much higher loaded.
11-16-2019, 08:19 PM | #6 | |
Member
902
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
https://www.bimmerpost.com/forums/sh...php?p=25467846
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
11-17-2019, 03:06 AM | #7 | ||
Rep 5,741
11-17-2019, 07:25 AM | #8 |
Rep 1,077
35 is not underinflated by any means. Its 35 cold. This preassure will go up and be closer to 38 drivimg.
If younare aggressive. 40-42 Its tafget preassure one should monitor. Tafget preassure depends on your driving style and outside temp. You want your preassure not too much higher than 40 at highest High presuure is worse. - tire will cup. and only have middle touching the road thus reducing the contact patch and sliding more and increasing preaasure more and cupping even more You cans see that by tire wearing in the middle. Most cars now have it because tires are overinflated |
11-17-2019, 08:40 AM | #9 | |||
Member
902
Rep 2,032
