11-22-2019, 10:17 AM | #1 |
Rep 267
Brake Difference M2 / M240i
They both have 4 piston in front and 2 in the back right? M2 has perforated rotors, which is basically cosmetic on modern brakes from what I understand.
What are major differences? |
11-22-2019, 10:56 AM | #2 | |
Rep 744
M cars have more aggressive M pads and the M cars have "M compound discs" (as in in two part discs). Basically the discs are a bit bigger than the non - M car's discs and have an aluminium center hat like racing brake discs. This hat is pinned to the cast iron rotor to allow for differential heat expansion of the 2 materials. If you track the car you will hear tinging when you park the car and let it cool down. https://www.bmwblog.com/2014/04/13/n...-brake-system/ As far as I know the calipers are the same, a common upgrade it to get the M pads. Discs probably cant be swapped unless you do the M knuckles too.
AX 1.1 --> AX GTI --> NA Roadster 1.8 --> E39 528i --> Xsara VTS --> Volvo 940 LPT --> Focus RS MK3 --> M2C + NA Miata 1.8
11-25-2019, 12:19 PM | #3 | |
Rep 267
