11-25-2019, 12:33 PM | #1 | |
Rep 11,785
Why does the BMW M2 CS weigh the same as the M2 Competition?
https://www.bmwblog.com/2019/11/23/b...2-competition/
"The M2 Clubsport is shaping up to be the darling of the BMW community, so naturally, it’s a hot topic today. And nothing gets people going more than the weight of new cars. When asked whether the BMW M2 CS weighs the same as the M2 Competition, Herr Flasch said the following: They weigh about the same, all things considered, unless you equip the M2 CS with the carbon ceramic brakes which save about 25 kilograms (55 lbs),” Flasch told us. “The reason for being the same weight as the M2 Competition, is the additional things we put in.” When unveiled, BMW communicated a curb weight of the M2 CS at 3,417 lbs. (1,551 kg). Compared to the M2 Competition, the BMW M2 CS does get additional weight savings from the carbon fiber hood and carbon fiber roof, but it gets the Adaptive M Suspension as standard which likely adds some kilos to the car. Quote:
it sure seems interesting , perplexing, and downright disappointing that all of the item added/deleted items simply cancelled each other out when it comes to saving weight. Looking at the list of parts that are swapped out.... it sort of begs the question.. what items ADDED weight... and why were they necessary to be included instead of offering some weight savings? Last edited by M3 Adjuster; 11-25-2019 at 12:52 PM.. |
11-25-2019, 01:11 PM | #2 |
Rep 1,061
Agreed 1000%
I'm somewhat unsatisfied that the weight between the 2 are very similar. I understand that certain items weigh more ect...but, you would of thought that there would still be at least a 70-90 pound weight savings at a minimum. The car looks fantastic and great ect. However, I can't stop thinking that for the $25k premium there just isn't enough there to make it special enough to take the plunge. At a lower price point maybe yes....however, low to mid 80's I just don't think so. |
M3 Adjuster7909.00 A6bullet337.00 |
11-25-2019, 01:14 PM | #3 |
Luxury at the redline :)
9106
Rep 7,563
I'm not faulting BMW for the lack of weight reduction on the CS and I'm sure there is a reasonable rhyme behind the reason.
I mean, I'm sure they're not trying to spite anyone but there are only so many meaningful ways to reduce mass and not change the profile or its overall targeted price.. Same as with the M340i, as it claimed a weight reduction in comparison to the prior model because it was built on the lightweight CLAR platform but all the new ancillary equipment bought the weight back up. M340i Weight Increase https://g20.bimmerpost.com/forums/sh....php?t=1599263 I've accepted that this is just the way the game goes, even when they switch over to EVs, the battery would weight down the body, so the lard-laced built vehicles are here to stay. |
11-25-2019, 01:22 PM | #4 | |
Rep 433
In addition to the M adaptive suspension, the article does mention that there are a few things which could add some weight "Three radiators, an oil cooler, two pumps in the oil pan, and an oil sump baffle are some of the mechanical upgrades of the M2 CS." However, I wouldn't be at all surprised if most if not all of these "upgrades" end up being about as true as the N55 in the M2 having a closed deck Another thing that is unclear is which spec of M2 C Herr Flasch was referring to in relation to the M2 CS A "base" spec M2 C in many markets is considerably lighter than a USA spec car which comes standard with the 2NH brake package and power seats that add a considerable amount of weight |
11-25-2019, 01:28 PM | #5 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
So, it must be that the adaptive suspension and the enhanced cooling system weight about as much as the savings from the CFRP hood/roof and the CF center console, etc.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
11-25-2019, 04:40 PM | #6 | |
Rep 11,785
I'm already making the point that there is NOT rhyme or reason I can see or understand or even weigh..... so ..do me a favor and THINK for a sec and Tell me what pieces that they installed are heavier .. Or.. provide a reasonable rhyme behind the reason aside from simply suggesting there is one. |
11-25-2019, 04:46 PM | #7 | ||
Rep 11,785
All cooling items quoted are in the M2C as well as the M2 CS. The M2 CS press literature also quoted solid subframe mounts but those were on the OG M2. So let's not take all of the press literature as being new info. |
chris7197356.00 |
11-25-2019, 04:50 PM | #8 |
Rep 2,505
The aluminum hood and roof are very lightweight already so you do not get much benefit going to carbon fiber. The only benefit is bragging rights and exclusivity, and of course the extra $$$.
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
M3 Adjuster7909.00 |
11-25-2019, 04:56 PM | #9 |
Rep 1,027
I think if anything, you're mentally overstating how much weight savings any of the CS options actually provide
Lot of people want to perceive the M2 CS as an M3 CSL just because we compare the M2 with the E46 M3 and the CS is the best of the generation like the CSL and it comes in a similar limited edition number. CS = Competition Sport CSL = Coupe Sports Lightweight |
11-25-2019, 05:10 PM | #10 |
Rep 2,505
Also, the M2 CS has slightly better lap times than the M2c is because of the cup 2 tires and tune.
Slap on cup 2 tires and get a BM3 CS+ tune on the M2c and times will be equal around the track. |
11-25-2019, 05:25 PM | #11 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
Yeah, I remember back in '16 when a 3450 lb curb weight was considered fat. It still may be. But then I look at the current offerings.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
11-25-2019, 05:34 PM | #12 | ||
Rep 13,138
Most high performance car manufacturers made a sport of it to list the lowest weight possible with car configurations that almost no customer chose, for low weight bragging rights purposes. For a good example, see here: Quote:
///M is art ↔ Artemis
11-25-2019, 05:38 PM | #13 | |
Rep 13,138
See here:
Dav3948.50 |
11-25-2019, 05:47 PM | #14 | |
Rep 13,138
Poochie9106.00 |
11-25-2019, 06:01 PM | #15 | ||
9106
Rep 7,563
I guess I just took it up on faith that BMW has our best interest at heart and if there was a meaningful way to reduce the heft, they would of.. But what do I know, I'm just assuming.. : |
11-25-2019, 06:04 PM | #16 |
20192
Rep 8,573
They are both complete fat asses
M2 Chubby & M2 Chubby 2.0
///MPhatic13994.50 |
11-25-2019, 06:19 PM | #17 |
Rep 8,639
If you'd been even remotely paying attention for the last 10+ years, you'd quickly realize BMW has not been honest about a single weight figure... and when they mention weight savings there is a huge asterisks.
11-25-2019, 06:22 PM | #19 |
Rep 825
Here's what I don't understand: if weight is truly of utmost importance, why don't folks just buy Lotuses? Not trying to be a pain in the butt. Honestly asking for real. My understanding is that Lotus makes incredibly light weight, pure, stripped down driver's cars, with great performance. But, by the same token, my understanding is that they're perpetually on the verge of bankruptcy.
So, I don't get that. If weight is truly so crucial in a performance car, I would have thought that Lotus sales would be through the roof. And, yet, they seem always to be one foot in the grave. What gives? |
11-25-2019, 06:47 PM | #21 | |
Rep 2,577
Lemania 2320
cptobvious2531.50 |
