11-25-2019, 08:27 PM | #1 |
Rep 204
how much camber to run
I just got a set of Ohlins R&T coilovers and GC camber plates, how much camber should i be running now that im sitting lower than stock? I know that the oem camber setting tends to destroy the front tires and i want to stop that. Any advice helps!
11-25-2019, 08:42 PM | #2 |
Rep 396
Depends entirely on your driving habits. It could be anything between OEM -1.5 to aggressive -3.++
Also depends on whether you want to set and forget or if you’re prepared to make changes between street and track days. Pick a number and monitor your tyre wear. Adjust as needed. Perhaps -2.0? |
11-26-2019, 04:38 AM | #3 |
Rep 1,094
The tire wear doesn't come from just camber, toe plays a big role. If you run 0 toe in the front the car will turn in better and wear the tires less. The downside is that on a highway the car needs more steering corrections to keep going straight.
Once I get camber plates I'll take it to an alignment machine and mark the plates for 1.5 and 3 degrees |
11-28-2019, 12:11 AM | #4 | |
Rep 204
11-28-2019, 12:46 AM | #5 | |
Rep 1,094
What I meant by marking the camber plates is just in the front for quick changing between street and track. So my street setup will be 1.5 front 2.0 rear and the track setup will be 3.0 front 2.0 rear. |
11-28-2019, 08:27 AM | #6 | |
Rep 4,529
My DD car fast road/TD set up with MPerf suspension as follows Front - C is -2.25deg & T set to <0.05 deg per side Rear - C is -1.5deg & T set to 0.05deg per side. Car is stable, great traction and steering. Tyre wear is even
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
11-30-2019, 09:23 AM | #7 | |
Rep 385
Bee Pee1787.50 |
12-03-2019, 11:08 AM | #8 |
Smooth is fast
Rep 40
I plan to run the same setup as you. I will likely try 3.0 F and 2.0 R right off the bat. If you don't mind me asking, what did this set up cost you? I need to set up an Ohlin and CG fund for when its spring LOL.
Track Days > Everything
12-03-2019, 09:44 PM | #9 |
Rep 204
I got my ohlins for 2400 and the ground camber plates for 490ish. The ohlins i bought new from someone who sold their car and i got the ground control camber plates during IND's black friday sale
12-04-2019, 02:51 AM | #10 |
Smooth is fast
Rep 40
Awesome. You got a killer price on the ohlins. I'm not too far from IND in Chicagoland. Used to live right by them.
