12-01-2019, 01:15 PM | #1 |
Rep 78
Shift settings
New X3M Comp arriving this week and I’m in the position of never having had an automatic car before. However, I’ve had loads of BMWs with adaptive suspension and M Cars with adjustable steering, dampers and throttle response. Just so I’m clear, in the X3, the only thing that adjusts shift speed is the button on the gear selector lever, so effectively there are 4 settings:
1 for shift (on lever) Then Separate buttons for 2 engine map 3 suspension 4 steering My confusion is surely the shift is affected by engine map... or maybe not? Is the ONLY thing that affects shifting the button with 3 settings on the lever...? And - what settings to most people have all 4 separate items most of the time? Many thanks from an auto newbie. |
12-01-2019, 01:22 PM | #2 | |
Rep 4,607
12-01-2019, 01:49 PM | #3 | |
Barge driver
8712
Rep 12,452
As has been said find your two favourite settings and put them on the M1/2 red levers. Although I've always found myself playing endlessly with everything all the time with my previous M cars this new one will be no different.
730d/Z4C
12-01-2019, 01:59 PM | #4 |
Rep 4,703
You will need to play with the settings until you find what you like just as the above posts said. You asked about shifts, for example in efficient mode you can have the shifts be soft to the point where you don't feel it changing gears or you can have instant changes where you feel it all while in efficient puttering around a parking lot.
The level of customization is quite incredible. Here is a sample of the option per mode... Engine x3 Suspension x3 Steering x3 DSC x3 Drivetrain x2 Exhaust x2 Transmission Shift Speed x3 Transmission Mode x2 Lots to tinker with and just when you figure it out you will find you like something better as you get familiar with the vehicle. |
12-01-2019, 03:55 PM | #5 |
Rep 2,495
I personally don't understand the inbetween settings.
I use default Efficient / Comfort / Comfort / D1 when pootling around. M1 is set for needing power quick so Sport+ / Comfort / Comfort / S3 and M Sport HUD on M2 is set for Sport+ / Sport / Sport / S3 / 4WD Sport and M Sport HUD on. Easy to switch traction all the way of too if needed. So D2 and S2 and Sport for engine are pointless for me.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
12-01-2019, 03:56 PM | #6 |
Rep 2,495
I'll also add that S3 is a bit lame. I expected more aggressive shifts, but hard to do with the ZF gearbox apparently.
12-01-2019, 05:05 PM | #7 |
207
Rep 668
I have M1 for a more responsive comfort mode. Sport Engine, D2, Comfort steering and suspension. I have M2 being more aggressive with Sport Plus engine, S3, sport steering and suspension. Both modes keep DSC in regular 4WD. I've not felt the need to make the suspension harder or the steering heavier with plus options.
12-01-2019, 05:37 PM | #8 | |
Rep 38
Your Left Leg!
when you want to speed up, you will be tempted to put de clutch pedal down (to shift the gear) but your left foot will find the break pedal ... Imagine the result! Ref. shift speed: You will probable use a lot the shifting pedals behind the wheel because you are used to change gear by yourself. It will be very pleasant for a period of time. After that you will become lazy and you will let the automatic gearbox to do the job! (Personal experience) |
12-01-2019, 05:38 PM | #9 | |
Barge driver
8712
Rep 12,452
730d/Z4C
12-01-2019, 09:48 PM | #10 | |
Rep 4,607
D1 feels like Nissan’s CVT to me. The shifts are too soft. D2 shifts are a bit harder and the transmission shifts at higher rpms. D3 is pretty darn good. |
12-02-2019, 03:24 AM | #11 | |
Rep 2,495
Prefer the old school way - my C63 had only a few options - Comfort, Sport, Sport+ and Race. Standard non adaptive suspension that was both comfortable and sporty. An epic exhaust sound whatever the mode. Similarly in my 440i it was a little easier with Comfort, Sport and Sport+ - there weren't too many button presses to get things right. I'll get used to it, but I never really seem to have the perfect combo. Also the exhaust option in Efficient, I may be going mad but it sounds the same turned off or turned on???
Wills28711.50 |
12-02-2019, 03:49 AM | #12 | |
207
Rep 668
I love that I can tailor M1 and M2 to exactly how I want them. Default for pooling in traffic, M1 for a bit more responsiveness when out with family, M2 for on my own. M1 is that middle ground. And once set, it's a simple 2 button affair. |
moff1364.00 |
12-02-2019, 09:05 AM | #13 | |
Rep 1,221
12-02-2019, 09:34 AM | #14 | |
Barge driver
8712
Rep 12,452
I used sport mode as my default setting on my F80 M3 F10 M5, programmed M1 with sport/sport/sport/normal HUD/MDM so it was just one press as I got in the car, M2 was everything turned up to 11, I'd then mess about as the mood took me on a long run I'd turn it all down and get 38mpg in the M3. It was like having 3 cars in one and I'd say that sport is the goldilocks setting between them all.
730d/Z4C
