12-04-2019, 08:51 PM | #1 |
F80_F85_F90_F98
73
Rep 126
Drives: Current: F90|F98 Past: F80|F85
I see Eisenmann is almost complete with there exhaust system.
But so far I've found just two full systems which include downpipe and mid/center pipes. 1. Manhart 2. Supersprint. Both reputable but I have never had any hands on real world experience with either company. I've never even seen one in person. The Manhart one looks enticing though. Here's a couple pics. Thoughts? I already ordered the SuperSprint DP they Turner MS. The last two pics is the Manhart system. The first few are SuperSprint system piece by piece.
on1ybluu
12-04-2019, 09:36 PM | #2 |
Rep 18,793
I would do Supersprint.
It has been around longer and known brand, some other company uses them to manufacture. The only thing I don't like: - Their clamping design - Price point for its quality
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
12-04-2019, 09:38 PM | #3 |
Rep 253
Well I got word that AWE is not in the works yet for an exhaust and it might change in the future. Bmw might reveal an M performance one next year. Akrapovic is working on one according to other members on this forum. I heard glimpses of the supersprint and it sounds promising. Eisenmann sounds fantastic and might be to loud for me. I think I'm pulling the trigger on akra or super. I guess whichever is available first in the US. For me the valve control is vital. I need to control the sound.
12-04-2019, 11:19 PM | #5 |
F80_F85_F90_F98
73
Rep 126
Nice thanks for the update fellas. @r33_RGSport clamping design? Meaning a clamp connects the two pipes which are the same diameter? They dont slide into each other like a Male/Female sleeve? Or am I totally off?
r33_RGSport13119.50 |
12-04-2019, 11:59 PM | #6 |
Rep 1,221
I spent the better part of a day at the supersprint headquarters last Friday and got a tour of their factory from the owner. I did not go with their cat-less downpipe but chose their high flow stainless steel catalytic converter downpipe. Stock primary cat on this car is ceramic 600 cells per inch: their's is 200 cells per inch stainless manufactured by a company called HJS in Germany. Their solution did not require me to have the catalytic converter alarms coded out of the engine like you have to do with downpipes. Their cat works well enough to not trigger the errors. And it still frees up the exhaust significantly. The owner is really honest. In the end he reccomended I only change that primary cat and leave everything else stock. He gave bmw credit for a well built exhaust, and this one exhaust mod I did has resulted in a louder, deeper, and better performing exhaust. He also said changing additional components wouldn't really improve performance but would just result it it being louder with a change in pitch. My tuner said the exact same thing. It is my theory that our stock resonator is responsible for significantly lowering the tone of our engine. Acce98 in the forum here introduced me to SuperSprint after he had deleted his secondary cat/opf(they're housed in a single unit in Europe, whereas that same sized unit had only a secondary cat in us spec cars) and resonator (via H-pipe) leaving his primary cat and tailpipes stock. The result is a car that's louder than mine overall (and mine is by no means quiet with the valves open) but higher pitched and much more metallic sounding. You've got to be careful with this six cylinder's sound. I was going to delete my secondary cat and resonator next but called them back and canceled the order. For me, it's perfect now as-is with just the primary cat swap.And the performance? Well, see my other post here about the 612hp beast.......
12-05-2019, 07:04 AM | #8 | |
Rep 253
12-05-2019, 09:53 AM | #9 | |
Rep 1,221
12-05-2019, 11:25 AM | #10 | ||
Rep 253
12-05-2019, 11:41 AM | #11 | |
Rep 18,793
So far I haven't seen any fail yet, but it doesn't close out the gap as much as a clamp band. If you see in the picture, I circled them out. They uses a welded ring where the bolt goes through to tighten the slitted pipe.
12-05-2019, 11:43 AM | #12 | |
Rep 18,793
Last time I heard, it take almost a year to take delivery. AC Schnitzer, most likely either SuperSprint or Remus with AC Schnitzer tips on them.
12-05-2019, 12:56 PM | #13 |
Rep 581
From what I remember, AC Schnitzer uses Remus, never heard that they use SuperSprint.
12-05-2019, 12:59 PM | #14 | |
Rep 18,793
I noticed that for F15/F16 X5/X6, they were using SuperSprint. For G30 5-series and F90 M5, they are using Remus.
12-05-2019, 01:16 PM | #15 | |
Rep 1,221
12-06-2019, 07:21 AM | #16 | ||
Rep 253
12-06-2019, 08:47 AM | #17 |
Rep 1,221
I was going to delete secondary cat (straight pipe) and resonator ( H pipe) like ace, but I've gotten to hear my car more now from outside with just the stainless primary cat swap, and it's actually where I need it to be for a daily driver. I've reached personal exhaust nirvana for my DD with this setup. Now, if it were just a weekend. car.......... But seriously, some may want it louder than mine. If you do, I would still reccomend the stainless cat primary like mine with a SS resonator midpipe (not a straight pipe) and their H pipe and leave the factory tailpipes. That would be my louder reccomendation, although I'm sure other brands will also offer good solutions depending on your individual taste.
02-04-2021, 08:29 PM | #18 | |
Rep 405
ando2006.00 |
02-04-2021, 08:44 PM | #19 |
Rep 581
He doesn't have the X3M anymore so I don't know if he'll see this or reply, I'll answer for him though. No, he wasn't on stock tune. He had a tune in Italy, it got wiped at the dealer here in the States, then got another tune here.
2005 Estoril Blue M3 ZCP, OEM CSL bootlid, AC Schnitzer everything else
2020 Phytonic Blue X3M Competition, Remus Race exhaust, AC Schnitzer everything else |
02-04-2021, 08:49 PM | #20 |
Rep 405
Great, thanks, I appreciate the reply
