09-01-2008, 01:11 AM | #1 |
Rep 7,719
Need help on internet networking.
Here's the situation. The main desktop computer that's hardwired into the WiFi router and cable box is located on floor 1. There are 2 computers on floor 3 that are connected via WiFi, but the signal is pretty weak.
Would placing a signal booster on floor 2 or floor 3 help out the signal strength? |
09-01-2008, 01:14 AM | #2 | |
Rep 3,807
Drives: Retired 2017 F87 M2
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue| |
09-01-2008, 01:17 AM | #3 |
Rep 7,719
What exactly is a repeater? I just went down to check our connection and it seems that my step dad no longer uses the Linksys WiFi router we previously used. There's now a cable box that also doubles as a WiFi router.
09-01-2008, 01:29 AM | #4 | |
Rep 3,807
example: http://www.linksys.com/servlet/Satel...VisitorWrapper The other solution you have is to replace your router, with a router that uses MIMO technology. A router with MIMO technology, has the ability to create multiple signals so that the signal travels farther than the usual. This is usually offered on Wireless-N routers.
09-01-2008, 01:31 AM | #5 |
Rep 3,807
i also believe that D-link offers a similar repeater product that you plug on your wall socket, and it acts as a access point that amplifies your wifi signal.
09-01-2008, 01:31 AM | #6 |
S65B40 FTMFW
66
Rep 224
You could run a ethernet cable to the second floor which you could connect to a linksys router. Then, connect to your network via the second floor router by finding out its network name and then press connect and (if applicable) enter either your WEP or WPA key.
09-01-2008, 01:34 AM | #8 |
Rep 7,719
09-01-2008, 01:34 AM | #9 | |
Rep 3,807
09-01-2008, 01:36 AM | #10 | |
Rep 7,719
I don't really wanna wire an Ethernet cable to the 2nd floor. I'd prefer the solution to be as clean cut as possible. |
09-01-2008, 01:37 AM | #11 |
S65B40 FTMFW
66
Rep 224
09-01-2008, 01:46 AM | #12 | |
Rep 3,807
so I just got rid of it. My friend has the D-link repeater that you plug to the wall of his living room and it works fine for him.
09-01-2008, 01:47 AM | #13 |
Stackin' Chips
174
Rep 608
You could try flashing your router with the DD-WRT firmware IF your router is on this list...
http://www.dd-wrt.com/wiki/index.php/Supported_Devices Also, read this article... http://lifehacker.com/software/route...ter-178132.php Pay particular attention to the part about changing the value of the "Xmit Power" field to boost the wireless signal of your router. If this doesn't work for you then check out the Apple Airport Extreme router (also PC compatible). Apple routers have excellent signal strength and you can always add another Airport Extreme and run it in bridge-mode if one isn't enough. Good luck.
09-01-2008, 01:50 AM | #14 | |
Rep 3,807
09-01-2008, 01:59 AM | #15 |
Stackin' Chips
174
Rep 608
NICE! Can't wait till Time Capsule with a Solid State HD becomes an affordable reality.
