01-14-2020, 10:32 AM | #1 |
Rep 393
Automatic Climate Control
Can anyone tell me what the “auto” button activates when enabled? I know what it does in maintaining the set temperature, but reason I ask is when I activate auto, I get a distinct faint squeal that is not there when I disable it. I currently have a loaner X3 and it is nice and quiet when I enable the auto button so I’m just trying to determine what’s creating the squeal in mine. It’s not the fan as I’ve tried ramping it up and down when auto is off and on with no change to the intensity of the squeal. It only lasts until the car heats up and then disappears, but for the first 10 minutes or so, it’s annoying and I don’t know enough about the various components that the auto feature enables that might cause the squeal. Hoping one of you guys know.
01-14-2020, 01:00 PM | #2 |
Fridge Doctor
17
Rep 19
Could be air con compressor cutting in, if the drive belt is not tensioned correctly, when the drive clutch is energized it can cause a squeal until the compressor runs up.The a/cwill still run on heating dependent on humidity.
01-14-2020, 01:08 PM | #3 |
Rep 393
Thanks, I wondered that myself, but wouldn’t turning the AC button off confirm this? My AC button could be off and the Auto button on and I still get the squeal.
01-14-2020, 01:21 PM | #4 | |
Rep 15,858
It could simply be where the internal flaps are set, during the Auto program warm up cycle. Does it change when you change the 'intensity' setting, when in the Auto mode? |
01-14-2020, 01:28 PM | #5 | |
Rep 393
Regarding your comment on the intensity setting, I’m not sure if you mean intensity of the fan or temperature, but regardless, neither setting seems to change the squeal. |
01-19-2020, 06:10 AM | #6 |
Rep 393
Got my X3 back and apparently they replaced the blower box located beneath the glove box. This is certainly where the chirping noise seemed to be coming from, but the unit they put in either has the same issue or it’s not coming from the unit they replaced. It sounds as though a dab of lubrication is all that would be required if I knew how to access it.
02-03-2020, 08:32 PM | #7 | |
Rep 393
