Oil temp lower than usual
01-19-2020, 08:57 PM | #1 |
Rep 2,049
Hey guys,
So few weeks ago I got a code for "improper thermostat function", I was about to go ahead and replace it along with the WP but decided to clear the code and see what happens. That day it was pretty cold so I thought of it possibly being a fluke The code Hasn't returned in few weeks of daily driving and car drives fun but I noticed my oil temp won't go past 200f with ambient temps of 60-70f. I'm used to seeing 220-250f range Coolant temps range between 180-220f which seems normal to me. What you guys think? should I just go ahead replace the thermostat/WP? I don't mind waiting and saving up $ lol
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
01-19-2020, 09:03 PM | #2 |
Rep 3,732
So you are getting a fault saying improper thermostat function (thermostat not working right).....and your oil temp is lower that it is supposed to be (thermostat not working right)..........and you are wondering if you should replace your thermostat?
YES.....it's not working right! 👍 I guess you could always just wait until you get the fault again....but I'm guessing that eventually you will need to replace it. |
01-20-2020, 10:26 AM | #4 | ||
Rep 2,049
lol well I was thinking make the code was a fluke because it never came back again
'10 e92 N54
01-20-2020, 10:59 AM | #5 | ||
Rep 2,049
Yeah I'm seeing 180-200 max and it's not that cold out.
'10 e92 N54
01-20-2020, 11:05 AM | #6 |
Rep 2,049
Does the oil cooler send it's own fault? Can't remember if mine said oil or coolant thermostat fault lol
'10 e92 N54
01-20-2020, 11:16 AM | #7 |
Rep 9,209
01-20-2020, 11:18 AM | #8 |
Rep 9,209
01-20-2020, 11:49 AM | #9 |
Rep 1,152
No, I pretty sure I wrote it correctly.. I believe he has the N54 so I could be wrong but the N55 has eco mode at 226f, normal at 219f, sport 203f and hard sport at 194f.
I have heard people hitting 180f running hard but I never have, I actually never been under 200f (warmed up) but I don't drive track. I am not sure what conditions and time frame the coolant temps range from 180 to 220 but I run 215 to 225f on the high way.. Around town about the same. Its not normal for the coolant to have that range when just cruising. Thanks. Last edited by TunafishE93; 01-20-2020 at 11:59 AM.. |
01-20-2020, 07:10 PM | #10 | ||
Rep 2,049
Yeah I have an n54. Today I drove around town and let it idle outside my house for 10 min and oil temp was barely hitting 200f. Still no fault codes. My mechanic thinks it's weather related but it's not that cold, I'll say 60f (cold for California) lol I'll change the tstat/Wp soon but wanted to know if it's a problem to keep driving it
'10 e92 N54
01-20-2020, 07:11 PM | #11 | ||
Rep 2,049
Ohh I see. Yeah my fault code specifically said "thermostat"... but it's weird it hasn't returned since I cleared the code
'10 e92 N54
01-20-2020, 07:21 PM | #12 | |
Rep 9,209
01-20-2020, 07:27 PM | #13 |
Rep 9,209
01-20-2020, 07:39 PM | #14 | |
Rep 6,316
The best way to test let the car heat up the coolant to around 90c. Then hop on the highway. If the temp keeps dipping and dipping then t stat for sure. My temps on highway for coolant would start 80c from the parking lot then drop to 50c. You can also once it heated up, tigger the rad fan and see if the coolant drops by a lot. |
01-20-2020, 08:37 PM | #15 | ||||
Rep 2,049
Oh ok so i gotta log the coolant on MHD because my cluster shows no coolant gauge. I'll test it out. Is it bad if I keep driving it like this ? I seen ppl wanting low coolant temps of 180 by bypassing the oil cooling thermostat..
'10 e92 N54
01-20-2020, 08:38 PM | #16 | ||||
Rep 2,049
I'll try the MHD log, I think I seen coolant as one of the parameters in Fahrenheit
'10 e92 N54
01-20-2020, 11:37 PM | #17 |
Rep 1,152
Guess my car is not logical, these are two pulls I ran back to back. Before starting the pulls car was running 215f coolant. Then during went up to 223f. Then the illogical part it went down to 198f between pulls (about 20 seconds between pulls). The second pull I topped at 219f then went down again after.
This was after running between 215 and 225f for an half hour (cruising). So yes my car went down in temp driving hard. Even my peek temp went down between the first and second pull. https://datazap.me/u/tunafish389/log...=0&data=4-6-15 |
01-21-2020, 08:25 AM | #18 |
Rep 3,732
I'm pretty sure that when the car figures out it's getting driven hard (load, rpm, boost)....it will run the water pump more frequently and/or open the thermostat more. It's not just a straight temp bases system.
01-22-2020, 10:00 AM | #19 |
Rep 47
My N55 335i has also been running a bit cool lately. I used to always be just less than mid point on the oil temp gauge, about 240F. Then a few months ago my coolant expansion tank cracked while driving. Drove home about 2 more miles, parked car, replaced tank, refilled coolant and now the oil is regularly around 220-230F. I think either the coolant T-stat or oil cooler t-stat are stuck partially open. Coolant temps are always steady around 101C and oil gets to about 95% of where it should be so I'm not too worried about it for now. Been driving like this for about 3 months now without any dash warnings.
And FYI, when researching this a few months ago I did read that the N55 is designed to run hotter during highway cruising. It improves fuel economy... Less liquid fuel going into cylinder, hence less cooling from gasoline or something like that. So on the flip side, it will run cooler when being driven hard... for those with oil coolers, that will open up and cool the oil directly. Also the added gas being injected into the cylinder will naturally cool the cylinder walls between combustion cycles. Last edited by JFolt; 01-23-2020 at 03:42 PM.. Reason: clarified what temps I'm talking about |
01-22-2020, 11:14 AM | #20 |
Rep 96
Drives: 2011 BMW E92 335i V. Red/SB
Why are people still confusing coolant temperature with oil temperature?
They obviously are related but are not interchangeable! |
WatchWolf34126.00 |
01-22-2020, 07:23 PM | #21 | |
Rep 3,696
Keep in mind my car is originally from NY/NJ and is no stranger to single digit F or even negative F temps. Cali cold of 60F shouldn't be an issue at all A Tstat that fails open is not really an issue, if it failed closed that would be a problem. I believe these also have a bypass hose too? I was able to see the car reach its normal 235F or 240F oil during a day time run with no codes. |
01-22-2020, 07:36 PM | #22 | ||
Rep 6,196
