01-21-2020, 12:22 PM | #1 |
Rep 1,480
Drives: 2020 M340Xi (G20)
G20 "Easy Access"
Hi,
I have a 20 M340 (G20) and have just started coding some things on it. Because I have a bum knee, I really like the "Easy Access" for the driver's seat -- that is, when you turn off the ignition, the driver's seat automatically slides back and when you press the ignition button, the seat slides to the last position. I got this feature into my 2014 328 (F30) by coding the following in the SM2 ECU: 3000>SM_Global_6>EinAusStiegsHilfe from nicht_aktiv to Modus_FA_SLV 3012>EAH EAH>VerFahrWeg_SLV_Phys from 00, 3C to 00, 37 (hex values in mm) 3012>EAH EAH_SchutzFreiRaum_Hinten_SLV_Phys from 00, 64 to 00, 37 (Saftey stop) (hex values in mm) Now I found these functions in the SM2 ECU of my G20 and coded them like the above except that the EinAusStiegsHilfe menu values were Modus_FA_Logik_FA_Tuer or another. I tried either of these values and can not get it to work the way it did on my F30. Would appreciate any assistance or recommendations! Thanks!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
01-21-2020, 02:59 PM | #2 |
Rep 1,168
Drives: 2020 M340i
Science....woah
2020 M340xi PB (sold)
2020 Ram 1500 Laramie (Daily) 2019 Shelby GT350R (Weekend) |
01-22-2020, 12:01 PM | #3 |
Rep 18
Following.
chunll200175.00 |
01-22-2020, 05:56 PM | #4 |
Luxury at the redline :)
9105
Rep 7,563
This would be nice.
I had a professional coder attempt to activate this feature but they're could figure out how to do so From what I gathered, the parameters and values are different and way more intricate than it was in the older E and F - series BMWs.. |
01-29-2020, 05:50 PM | #5 |
BMW Client Advisor
3459
Rep 2,504
Drives: 2020 M340i
I set seat memory 2 to go as far back as the seat can go and just hit memory 2 before I get out. It is a pain but it is a work around.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
