Yellow Half Engine Warning Light - Engine Malfunction Reduced Power - 335i N55
01-25-2020, 01:06 AM | #1 |
Rep 137
Hi all, need help please.
335i N55 Engine suddenly experiencing the following issue out of the blue
I'm confused because there are no codes thrown, and the half engine warning goes away on it's own if I turn the car off and let it rest for a bit. Could it be HPFP? Pressure Convertor/Boost Solenoid? Vanos Solenoids? It's a bit of a guessing game with no codes thrown. Any suggestions or thoughts? UPDATE: Pulled the following codes:
01-25-2020, 03:38 AM | #2 |
Rep 22
Drives: 2006 Bmw 325i
Does it throw any codes when the car stalls?
01-25-2020, 08:21 AM | #3 |
Rep 1,272
The codes are there. The generic scanner you're using is inadequate to the task. You need a BMW-capable scanner. ISTA, MHD, BimmerGeeks, Foxwell, Launch, Carly.
01-25-2020, 08:49 AM | #4 |
Rep 1,152
You will still get code with a regular scanner, only different is the format the code is presented.
My money is on the battery... They get weak when cold, the hint about only happening when cold.. That's just a guess but could be a million other things. Batteries are a good place to start. Need more info though, does this happen when just starting car? When cars been running warmed up? If you drive car will it happen once you stop? Last edited by TunafishE93; 01-25-2020 at 08:54 AM.. |
01-25-2020, 10:59 AM | #5 | |
Rep 1,272
A bad battery will result in more codes, not fewer. |
01-25-2020, 11:05 AM | #6 | |
Rep 137
When the half engine reduced power malfunction warning comes on I will try scanning for codes. I have been scanning after the warning goes away thinking a code would be stored, so I’ll have to try once the warning is still up. |
01-25-2020, 11:14 AM | #7 | |
Rep 1,272
When the light is still on, a generic scanner will pull SOME of the potentially available codes. It may not give you the whole story. |
01-25-2020, 11:22 AM | #8 |
Rep 1,152
I heard of codes you can't read with a normal scanner. The only ones I haven't seen was were "inactive" codes. Every code that has been active that I have seen could be read with both of my scanners. Granted I haven't had to many codes thrown.
It is a bad assumption to say I replaced battery its good. Brand new batteries have been know to be bad. I would at least test the basics... |
01-25-2020, 03:04 PM | #10 | |
Rep 137
Oddly enough today my car is running fine, I expect tonight when it’s cold outside for the issue to return. |
01-27-2020, 06:24 PM | #12 |
Rep 137
Pending Code P0087
The yellow Half Engine Malfunction warning came on again, this time I decided to use my generic Torque Pro app to see if it would pull any codes, and sure enough it showed a pending code of P0087.
What could be causing a pending P0087? |
01-27-2020, 07:22 PM | #13 | |
Rep 2,973
It's a generic OBDII code that means fuel rail pressure is too low. Do you get the fault under load/acceleration? Sounds like it might be the HPFP.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
01-27-2020, 07:56 PM | #14 | |
Rep 137
So you think it’s the actual HPFP and not just the fuel sensor? |
01-27-2020, 10:39 PM | #16 |
Rep 1,152
Error is the same as 2BF5
The diagnostic function monitors the rail pressure to determine whether it drops too low during operation. the relative rail pressure during engine operation is > 40 bar and a mixture fault or a fuel high-pressure fault is present at the same time. Potential problem source(s): - Defect in wiring harness between DME and rail- pressure sensor - Defective rail-pressure sensor - Defect in high-pressure system So yes high press side issues... Last edited by TunafishE93; 01-27-2020 at 10:47 PM.. |
01-29-2020, 06:08 PM | #17 | |
Rep 137
01-29-2020, 10:49 PM | #18 | |
Rep 137
Error Codes: 2BEE, 2C01, 3876
In addition to the above codes, a standard OBDII code reader pulls pending P0087. Seems like many possible fault causes. What do you all think? Last edited by MyCar; 01-29-2020 at 10:57 PM.. |
01-30-2020, 01:18 PM | #20 | |
Rep 137
How to narrow down between sensor and HPFP?
Anyway to narrow down further? |
01-30-2020, 05:46 PM | #21 | |
Rep 2,973
I had 4-5 pumps before 100K miles. The last one lasted 100K+ and I just swapped it out. I have yet to change that sensor. YMMV
01-31-2020, 09:40 PM | #22 | |
Rep 137
I’m confused. |
