01-25-2020, 08:39 AM | #1 |
Rep 610
Piggyback vs ECU flash if both produce 600hp
What is the point of an ecu flash if a good piggyback like JB4 or expensive Dinan (warranty) if both produce 600hp at the crank? The piggyback will be removable and won't void your warranty.
01-25-2020, 12:37 PM | #2 | |
Rep 1,068
Drives: i5 M60, M5's, 535.335, M550i
I have the Dinan for 2019M550 and it was a great breath of fresh air for my car, a solid 45-55hp over stock. My stock f10 M5 that dyno'd 504 to the wheels would slowly walk away on a 40 roll from the M550 with Dinan. 0-60 there's no competition but it's due to traction. 1/4 M550 probably still beats f10 M5 but due to traction again. Just saying watch out for all the claims of what your reading as advertisements
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M , 2013 M5 , Individual Silver, Bolt ons-Straight piped 2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete 2024 i5 M60 Cape York Green |
01-28-2020, 10:46 AM | #3 |
Joint Chiefs of Staff
24348
Rep 191,145
The biggest advantage for an ECU flash if done right is the power delivery. Its much smoother on an ECU flash vs a piggyback
NHM55022.50 |
07-20-2020, 03:21 PM | #4 | |
Rep 28
On a side note, do you know if there are any differences between the base JB4 and Berger Stage 1 tunes for the car? Is the additional cost only in the added features of the JB4 or are the tunes different as well? I emailed them directly but have not heard back yet. Yes, first time post on this forum as I just became an owner of the M550i, but I have always been an avid reader of this forum. Last edited by drwoodberry; 07-20-2020 at 03:21 PM.. Reason: added remarks |
07-20-2020, 06:14 PM | #6 |
Rep 28
Thanks for the smart answer and providing nothing useful to the post. I’m not a first time forum user and I do know how the search function works. I have done a great bit of searching but you don’t really find tuners sharing the adjustments they make, and yet alone most of the people getting tunes of any sort aren’t versed in every aspect of what is being adjusted. My question wasn’t based around results (HP/ft lbs) and the numbers tuners are getting can be manipulated by adjustments that are not necessarily going to let the engine last, for example excessive boost and lean conditions can make more power but reduce longevity and reliability. I haven’t seen a lot of information regarding how much boost or boost ramp up across the range or even the AFR that’s being targeted. So my question to the vendor is really have they seen the numbers and specifics around some of the tunes.
07-21-2020, 05:44 PM | #7 | |
Rep 183
You will find more information on the N54 forums. Also you're more likely to get a reply from the folks that tune em. Terry helped me get my settings dialed in for boost/afr/ff/pid/duty bias. (for my mods and flash) |
07-22-2020, 08:04 AM | #8 | |
Rep 28
Can I ask how flat your AFR line is and what it is? |
07-22-2020, 06:05 PM | #9 | |
Rep 368
07-24-2020, 05:38 PM | #10 | |
Rep 183
I'm now peaking at 24 psi. |
07-24-2020, 06:16 PM | #11 | |
Rep 28
10 seconds is moving. Really impressive. |
07-25-2020, 02:30 PM | #12 |
Rep 183
Yes. Flash+JB4, Downpipes, Exhaust, straight pipe, 3.5 BAR TMAP Sensors.
08-01-2020, 11:35 AM | #13 | ||
Rep 1,068
Mr.blue239.50 |
08-05-2020, 02:21 PM | #14 | |
Rep 368
How does the tuned M550 feel in comparison to the M5 w tune and DP? Either way sounds like this is the route I am going. Torn between this and the M340, these new B58s seem to reliably hold quite a bit of power. |
08-05-2020, 04:01 PM | #15 | ||
Rep 1,068
M550 with tune feels heavier. 60-100 I feel like it would be neck and neck, I can't say if I would have 2 cars ahead or behind. 0-60 or 0-100 M550 with tune would kill my M5 with exhaust period due to traction all day. It's why I love racing NOT the new vettes. Anything 2 wheel drive from a dig on non prepped track and doesn't have slicks cant compete with all wheel drive. So it's a conundrum. The feeling of the cars are just so different from a full blown M 5 to as we say a half of an M being M550. Tune for sure wakes the car up. The new 3 series isn't a joke either for the money and can be tuned with great results. I will tune any BMW I get due to the increases. I say this now as I haven't blown a motor
08-06-2020, 05:32 PM | #16 | |
Rep 368
Which is what is kind of pushing me to the M340i, the B58's are incredibly solid |
08-21-2020, 10:59 PM | #17 |
Rep 280
Main difference between a JB4 and a tune is the JB4 can only affect boost in a semi direct manner and a/f ratios / ignition timing in an extremely indirect manner (no matter what the dealers tell you).
A real tune can change everything that is "changeable" by an ecu (ignition timing, boost, a/f ratio, vanos which is cam timing and lift, throttle opening... all vanos engines still have a physical butterfly valve throttle, exhaust butterfly valves if you have it, etc.) it doesn't mean that you NEED to change these things and if you have a bad tune it can be worse than stock but assuming everything is done properly, you would rather have the ability to change these things than not, the stock ecu tune was optimized for a certain set of conditions that by definition you are stealing away from when you modify the car. What any ecu does is take a bunch of inputs of sensors, compare them against a table of (what should I do if I see air temps here, rpm here, engine load here, driver pedal position here, etc ....) then do some things it looks up from a table "the tune " ( command a certain level of boost via the electronic waste gate, inject this much fuel, change ignition timing to this, use this vanos setting) while observing from other sensors whether things are safe and ok (measured air fuel ratio, exhaust temperature, boost measured, knock sensors, etc) What the jb4 does is intercept the manifold air pressure and boost pressure sensor inputs into the ecu and tell them they are lower than they actually are so the stock ecu does not send a command to the waste gate to back off on the boost until much later than it otherwise would normally. That's it. That's how the jb4 makes power, full stop. The problem is that ignition timing settings and to a certain extent vanos settings used by the ecu are now the settings that were optimized from the factory for 10psi of boost but in reality the boost level is 16psi or something. In the bad case scenario this is going to lead to knock (which the STOCK ECU will detect and retard timing). The best case scenario is you simply run suboptimal ignition timing and vanos which could be either (both) less smooth, less efficient (less power). Air fuel ratio is a bit of a special case which I didn't include in the above because most modern engines run on closed loop cycle nearly all the time (it aims for 14.7 AFR nearly all the time and constantly checks the oxygen sensor to adjust the fueling to attain this) even when under load in high horsepower /throttle scenarios. In the old days turbo engines would just run rich in high throttle high boost situations (by operating open loop and commanding AFR of 9 or something) as the extra fuel being atomized in the intake charge would cool the intake charge and help prevent knocking. There's nothing about modern engines that would make this strategy not work, it's just bad for the environment so OEMs are highly disincentivized to go down this road in tuning strategy (something an aftermarket tuner has no issue with) The JB4 hooks up to the obd2 and canbus so it had the ability to (listen) to the same sensors that the ecu is listening to but the jb4 has no way of actually changing AFR or ignition timing or vanos settings directly. In the above example of jb4 adding 6psi, let's say the ignition timing should be retarded 3 degrees or something compared to the stock timing in the same scenario the jb4 can't do this. It simply can't. The JB4 IS safer than other boost controllers that don't observe these settings because the JB4 can observe when things go wrong (it sees the stock ecu and "undo/back off" it's adjustments to the TMAP and boost sensors so the engine returns to "stock" conditions. This is a REACTIVE system not a PROTECTIVE one. I would also find it extremely dubious if someone claimed that the JB4 could predict the preconditions to knock occurring better than factory engineers (this would be the holy grail of tuning, to predict knock before it occurs, you wouldn't need a knock sensor now would u). One might then ask, if the JB4 doesn't actually back off its adjustments until something bad actually occurs, and relies on the stock ecu to do so, how is it better than something like race chip which doesn't have this obd2/CANBUS listening system. Well consider the scenario where both systems are running the same setting (eg 6psi above stock boost) setting. When knock is detected the ecu will immediately back off timing for both cars. But it doesn't do it forever, knock is a rare thing for stock engines. The ecu will after a set amount of time return to its original programming. But we know the precursor to knock is highly likely to be because of the uprated boost conditions (in conjunctions with environmental factors that day, let's say it is really hot and dry day). As soon as the factory ecu returns to initial settings, knock occurs again. The jb4 can see (oh shit, knock is happening a lot in a short interval, maybe we should back off a bit, save this data in the logging file and let our user know, maybe only command +4psi instead), while the race chip will be happilly unaware and continue chugging along ignorantly. That's the reason why race chip doesn't add as much boost as jb4, racechip and jb4 does the same thing (manipulate what TMAP and boost sensor data the ecu "sees") but the jb4 is able to check its work whereas racechip cannot, so racechip engineers must specify a lower amount of excess boost it's system can "safely" provide. An aftermarket tune is both better and worse than the jb4 in that factory engineers coded for a lot of those corner cases that took millions of dollars of development to find (those 1/100,000 scenarios). A JB4 "keeps" these settings intact but a custom tune wipes it out. At the end of the day, what's more important to you, that's something only you can decide for yourself. Last edited by Knifeedge2k1; 08-21-2020 at 11:01 PM.. Reason: Spelling |
