So what if you don't care if the piggyback is detected...
09-06-2008, 05:13 PM | #1 |
Rep 1,467
Imagine that you just want big power, and you are willing to throw away your warranty and pay for any repairs...
Will "detectable" high power configurations cause the ECU to simply set a notification code so the dealer knows? or will the ECU actually disable the engine? I've heard about this 'limp mode', but I've heard people talk about it in various contexts. Some with mods, some with failing fuel pumps, etc. So I don't know if it's detection related, or if it's failure related. If it's only a matter of the ECU telling on you to the dealer, then I couldn't care less if the dealer knows I modded the car. Alternatively, is there any source of v80 ECUs so I could just swap for an old ECU? -scheherazade |
09-06-2008, 06:06 PM | #2 |
Rep 577
If you don't care about a warranty then of course you can do whatever you want. Limp mode is a result of the ecu trying to protect the engine from damage. It's not a proactive attempt to stop modding. I suppose you could buy an ecu - getting hold of the firmware is the problem. Perhaps eventually the direct ecu flashing mods will come to fruition.
09-06-2008, 10:37 PM | #4 | ||
Rep 1,467
I do most my own repairs. What I can't do I would take to a family friend's shop where he does bmw and benz work (specialist). I don't particularly want to throw away money (read : for the cost of dinan with what I want to do, I can do my own work on the car for the life of the car). A shop would charge thousands for work that cost me 'tens or hundreds' in parts. Last edited by scheherazade; 09-06-2008 at 11:03 PM.. |
09-06-2008, 11:03 PM | #5 |
Rep 1,664
Changing the ECU isn't easy...
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
09-06-2008, 11:31 PM | #6 |
Rep 1,467
Eh? That's literally one of the simplest things you can do.
The old ecu and the new ecu are physically identical. Only the embedded software version is different. It's a direct swap. Unplug one plug in the other. Worst case is you have to de-solder, label, and re-solder some wires. Which is time consuming, but you could train a monkey to do it. -scheherazade |
09-06-2008, 11:45 PM | #7 | |
Rep 1,954
Drives: 2020 X3M Competition
2020 F97 X3M Competition (current) - 2018 F80 M3 Competition - 2015 F82 M4 - 2012 E82 135i - 2010 E92 335i - 2007 E92 335i
09-06-2008, 11:54 PM | #8 | |
Rep 1,467
What modules are you referring to? (some sensor controller hubs?) I presume keys are the actual ignition keys that you use in the cab to start the car. -scheherazade |
09-07-2008, 12:03 AM | #9 | |
135
Rep 1,825
Its almost impossiable to swap out an ecu unless you wanna spend a ton of money.... |
09-07-2008, 12:10 AM | #10 |
Rep 1,467
09-07-2008, 01:09 AM | #11 |
Rep 117
v80 is the hardware(ecu), v29.2 is the software. Since your car is on order it will have v81 ecu and at least v29.2 progman software. Replacing the ecu would be almost impossible since it is registered to specific car. I don't think you would be able to find the older v80 ecu. Also, your car with v81 ecu would not be able to be flashed to a version of software prior to v29.2. All you really need to do is get a Procede V3 or JB3. The Procede "doomsday" map makes almost as much power as the "non-doomsday" map and Shiv said the eventually they will be even closer in power. If you are not concerned about the possibility of your tune being detected and your warranty being voided then just run the full power maps for V3 or JB3.
09-07-2008, 02:01 AM | #12 | |
135
Rep 1,825
ditto the jb3 is only about 5-10 more midrange torque for the older software |
09-08-2008, 10:39 AM | #13 | |
Rep 1,467
-scheherazade |
09-08-2008, 10:56 AM | #14 |
Rep 577
Limp mode has nothing to do with being detected - I tried to make that point in my first post. Limp mode is caused by an actual problem like the engine overheating. It's not a result of bmw trying to stop you from modding.
09-08-2008, 11:49 AM | #15 | |
Rep 5,946
Limp modes or CELs usually occur when the engine reaches a threshold temp, and the ECU basically chokes the engine to perform at half or less than half operating power. The Limp modes are there just to prevent damage. |
09-08-2008, 11:51 AM | #16 |
Perf BMW mag issue 147, 159
415
Rep 6,803
if you have the money, anything is possible... (full standalone)
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
09-08-2008, 10:28 PM | #17 |
Rep 117
09-08-2008, 10:51 PM | #19 |
Olimpiakos
91
Rep 1,426
I sent this PM to Terry on N54 tech.
Originally Posted by Ggreek5 Whats up Terry. Quick question, if someone threw the hidden code on the v81, would they know?? Is it actually hidden or is it a cel? Also what kind of computer is needed to reset it? Thanks Ari Would show up as a limp. You need the BMW scanning computer to reset it, some high end shops have them. T |
09-08-2008, 11:55 PM | #20 | |||||
Rep 1,467
Is it : 1) [practical] In all terms, unequivocally, you can install any piggyback and not go limp mode unless literally something breaks. *or* 2) [ideological] You will go limp mode because of 'problems', not mods. Now whether or not the effects of mods are interpreted as problems by the ECU is another issue that you're not commenting on. Quote:
I read a thread where someone said that the down pipes they put on triggered limp mode. Quote:
And, so this "hidden code" is another cause for limp mode. Quote:
If this is the case, is there an 'ignore' option somewhere that would let you cross a threshold without intervention? So the running total for what causes limp mode is : 1) Run the car WOT for a long time (overheat) 2) Don't follow instructions when installing the piggyback 3) ECU detects malfunctions/problems 4) "hidden code" 5) Too much of something? (#3 basically?) -scheherazade p.s. Sorry if i'm beating a dead horse here. I'm just trying to get a feel for what sort of modding I can expect. Looking forward to having a bit of a project car out of this one. |
09-13-2008, 08:45 AM | #22 |
Olimpiakos
91
Rep 1,426
