E92 328 shifter recall
09-07-2008, 05:09 AM | #1 |
Rep 103
I just took in my E92 328 for service (on board computer requested it) and my SA told me there is a recall on the shifter so I need to come back and leave it for the day. He couldn't give me any additional detail. The invoice states:
SIB #25-01-07 LBL 482 REPL GEARSHIFT LEV CUSTOMER WILL RESCHEDULE FOR RECALL I'm guessing it is something new, because I have not received any communication from BMWNA. Does anybody have more details on this? |
09-07-2008, 10:06 AM | #3 |
Rep 367
he wants you to leave the vehicle for the day?!?!
Its a campaign in which your gear shift knob gets replaced, it shouldnt take any more than 3 minutes to do.
08 Z4 3.0SI Black Sapphire/Black Int, 6sp, Sport/Premium --- retired --- 2010 BMW 650GS -- Z4 replacement Working with the most talented people on the most technically advanced automobiles.... |
09-07-2008, 11:23 AM | #4 |
Rep 103
Thank you for the explanation. The funny thing is I already replaced the stock knob with the OEM leather wrapped knob. Little chance the chrome coating will peel.
09-07-2008, 02:57 PM | #6 |
Rep 367
dont bring it in then, if they get a nimrod working on it, he'll probably replace your shift knob with the updated stock knob
09-09-2008, 03:32 PM | #8 |
Rep 3,431
took my SA 3 minutes for that recall, b/c the silver was scratched off
Current: 09' E90 335d - Titanium Silver/Black Leatherette/Sports Package/6AT Paddle Shift/USB Integration/19" Staggered Breyton GT Gloss Black
Retired: 07' E92 328i (Jet Black) |
09-10-2008, 01:05 PM | #9 |
Rep 4,709
I had the stock shift knob (manual trans) and had it replaced under that service bulletin.
I read somewhere that the shift knobs were flying off when people when people were shifting into 2nd really hard. |
09-13-2008, 10:30 AM | #10 |
Rep 3,415
That only happens when the knob breaks inside and doesn't hold the shaft anymore.
09-13-2008, 09:53 PM | #11 |
Rep 374
Drives: '05 645Ci Coupe
You realize this is nearly 2 years old!
SI B25 01 07 Gear Shift Mechanism January 2007....Technical Service PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS OR PRIOR TO RETAIL DELIVERY. SUBJECT Service Action: Gear Shift Knob Replacement MODEL E92 (3 Series Coupe) SITUATION The metallic coating on the gear shift knob may experience premature wear. CAUSE The coating may not adhere adequately to the shift knob, leading to an unfavorable long-term appearance. AFFECTED VEHICLES This Service Action involves 3 Series Coupe vehicles with manual transmissions and produced up to 10/20/2006. In order to determine if a specific vehicle is affected by this Service Action, it will be necessary to utilize the "Service Menu" of DCSnet (Dealer Communication System) or the Key Reader. Based on the response of the system, either proceed with the corrective action or take no further action. The Chassis Number Ranges listed below are only for informational purposes and are not to be considered as the only deciding factor. Model Chassis Number Range 328xi Coupe PC86006 – PC86282 328i Coupe PU87005 – PU87609 335i Coupe PV80025 – PV80999 335i Coupe P021100 – P021649 PROCEDURE Remove the shift knob and install the improved part per repair instruction RA 25 11 071. PARTS INFORMATION Part Number......... Description...........Quantity 25 11 7 576 532....Gear Shift Knob.....1 LABEL INSTRUCTIONS...S0093U02 This Service Action has been assigned code number 482. After the vehicle has been checked, and corrected if necessary, obtain a label (SD 92-320) and: 1. emboss your BMW dealer warranty number in the middle of the label (1); 2. punch out code number 482 printed on the label and, 3. affix the label to the B pillar as shown. If the vehicle already has a label from a previous Service Action/Recall Campaign, affix the new label next to the old one. Do not affix one label on top of another one because a number from an underlying label could appear in the punched-out hole of the new label. WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code..00 25 12 01 00 Labor Operation:..00 57 513..Remove and install gear shift knob Labor Allowance: 3 FRUs
Member - Knights of the Roundel (bimmerdriver s.com)
Over 58 runs of the ToD (or 18,444+ curves) |
