02-07-2020, 07:48 PM | #1 |
Rep 17
Lowering springs noise
Lowered my 340i xdrive last week on h&r sports and noticed some creaking noise kind of like a noisy hardwood floor when im turning the wheel. This only happens when the car is being parked i.e low speeds under 2-3km/h. Here are some photos, anything look out of line?
2016 340i XDrive (Current)
2011 E90 335i XDrive (Sold) |
02-12-2020, 04:21 PM | #3 |
Rep 1,499
I have the same issue. I notice it's worse on colder days. I'm not sure what it is.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
02-12-2020, 06:33 PM | #4 |
Rep 10,322
This is a common problem, especially with coilovers.
As springs are compressed, like any other springs they want to unwind and rotate, creating what's known as twist force. It's difficult for the spring to rotate and when it does creaking sound can be heard. To eliminate this sound, the spring should be allowed to rotate. Thrust sheets solve this problem. |
02-26-2020, 09:59 PM | #5 | |
Rep 17
02-26-2020, 10:58 PM | #6 | ||
Rep 10,322
02-26-2020, 11:33 PM | #7 |
BMW CCA Member
493
Rep 808
Hmmmm... thrust sheets are a great solution for coil-overs... except the OP is running just lowering springs on the OEM struts... a Google search didn't turn up thrust sheet use with OEM struts.
02-27-2020, 01:39 AM | #9 | |
Rep 10,322
Whether coilovers or lowering springs, the problem is the same. |
02-27-2020, 03:07 PM | #10 |
Rep 5,268
are your dampers stock? if yes this combination is a death trap. Get bilstein b8 or other sport damper asap. If your dampers are already non stock and sport ones ignore me.
03-02-2020, 09:18 AM | #12 |
Rep 5,268
i added lowering springs on stock suspension and 6 months later lost all control in a corner and nearly hit a boulder and could have died.
Shocks were bust hence the slide as traction issues secondary to that. Replaced them with sporty shocks to go with lowering springs and what a massive difference. |
03-09-2020, 12:28 PM | #13 | |
Rep 17
03-09-2020, 12:29 PM | #14 |
Rep 17
thanks!
