02-08-2020, 02:32 PM | #1 |
Rep 18
How do I disable Auto Start / Stop on 2020 M340i?
I have been trying everything to turn off the Auto Start / Stop feature of my M340i. My wife has a 2017 X1 which can be easily turned off and the memory keeps it off at all times; even after her car is turned off and on again. When I turn mine off, it stays off until I turn off the car. When I restart the car, the feature is on again. Is there a way to turn it off permanently?
Thanks. |
02-09-2020, 10:54 AM | #4 |
Rep 2,699
Drives: 23 X5MC
I just switch to sport or sport plus every time I drive it. Yes annoying but it's automatic now.
02-12-2020, 06:13 PM | #7 |
BMW Client Advisor
3459
Rep 2,504
Drives: 2020 M340i
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
02-28-2020, 03:09 PM | #8 |
Rep 1,480
Drives: 2020 M340Xi (G20)
ASS Won't Stay Off
Hi,
One of the first things I did on my '14 F30 was to code the ASS Memory so the car wouldn't turn off & on at stop lights. So when I got my '20 M340, that was one of the first things I coded. Of course, it's in the DME_BACK2 module, which means that if you're coding with E-Sys, you have to make sure the engine is off before you actually code; of course, using Bimmercode, you just have to be in the Diagnostic mode (three quick pushes on the engine on button with no pedals touched). Well, I have done it multiple times on my car, using either means of coding and I always get the same result:
Like I said, I have tried coding it many times. I have even VO coded the DME_BACK2 module and then FDL coded TCM_MSA_Memory from NichtAktiv to Aktiv -- all to no avail Appreciate any ideas??
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
02-28-2020, 06:48 PM | #9 | |
Rep 1,264
03-06-2020, 06:02 PM | #11 |
Rep 18
03-06-2020, 06:03 PM | #12 |
Rep 18
03-07-2020, 08:31 AM | #15 |
Rep 2,699
Drives: 23 X5MC
Putting in s or sp automatically turns it off
03-14-2020, 08:08 AM | #16 |
Rep 18
correct. The thing is that I drive to and from work every morning with lots of traffic, so I keep it in comfort, which does not have that automatic function. I put it in Sports mode when there is less traffic and I can step on the gas.
themnmd1691.00 |
02-09-2021, 05:05 AM | #17 |
Rep 1
What adapter did you use to connect to your car using the Bimmer code app? I downloaded the app but it is asking what adapter I am using to connect to the vehicle. Any help you can give me is greatly appreciated.
02-10-2021, 06:54 AM | #18 |
Rep 1,480
BamaBlitz ,
To use Bimmercode, you have two options to connect to your car: * Buy an OBD connector that connects to your phone via Bluetooth -- app provides link to their recommended list. * Buy an EBD cable (OBD plug on one end & LAN plug on other) & a LAN USB-C adapter-- both available on eBay &;Amazon I've used both & prefer cabled solution as it's considerably faster than Bluetooth & you can use cable if you decide to go to E-Sys for more involved coding BTW, there's a thread on this sub-forum on this very topic Hope that helps!
Al
