Oil Pan Gasket
02-18-2020, 01:02 PM | #1 |
Rep 90
Oil Pan Gasket
So like every other E90 owner, it has come time to change my oil pan gasket. Just wondering what prices are normal? I know the job is fairly labour intensive however my local shop quoted $1600+ is this normal?
Anyone done the job themselves? I know dropping the subframe is involved but $1600?! Really?! Any feedback would be greatly appreciated. Mike |
02-18-2020, 01:26 PM | #2 |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
Depends if RWD/AWD. Ive heard 6-800 for RWD ones but the Xi cars are much more involved.
I gotta do the gasket on my XI E60(N52) and I'm not really looking forward to it |
02-18-2020, 01:37 PM | #4 |
Rep 429
Drives: 2011 e92 335xi
You have to unload the front diff to replace the oil pan gasket.
This means you'll be replacing the 3 diff seals as well (Do not reuse them). XI oil pan gasket isn't what you wanna do twice. Do it right the first time. Respect the torquing sequence/pattern from the manual.
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD |
02-18-2020, 01:39 PM | #5 |
Rep 90
Thanks for the heads up? Anything else I should do while I’m down there? I’m thinking this would be a ideal time to do anything turbo related. I’ve just done the water pump and thermostat though.
02-18-2020, 01:40 PM | #6 |
Rep 429
Turbos for sure depending on the mileage and the rod bearings if you wanna keep the car for a long time.
02-18-2020, 01:42 PM | #7 |
Rep 90
I’ve heard about people doing that. I get how they would access the lower part of the bearings but how do they access the top portion. I’m assuming these bearings are two pieces?
02-18-2020, 01:47 PM | #8 | |
Rep 429
This long thread has in-depth information: https://www.e90post.com/forums/showt...php?p=24219253
02-18-2020, 10:54 PM | #10 | |
Rep 274
Drives: 335i, 330i, 335xi, 6MT sport
With the car on a lift and the steering disconnected to allow the subframe to drop out of the way, I estimate it could be done in 6 hours. I asked a mechanic with plenty of BMW experience how much more annoying it was to do the pan gasket on an x-drive, and he said "about 30% more annoying." Nice link to the N55 thread. Pan gasket on my 100k km 335 is weeping a bit. Maybe I'll plan to pull some rods caps for inspection when I do the gasket in a year or two, and order parts depending how it looks. |
02-18-2020, 11:05 PM | #11 |
Rep 1
Had a similar issue with my 335i luckily I bought an external warranty with the car, and they covered the cost, they also did the gearbox gasket as that was also leaking.
02-19-2020, 07:28 AM | #13 |
Rep 6,317
02-19-2020, 07:32 AM | #14 |
Rep 90
02-19-2020, 07:36 AM | #16 |
Rep 90
02-19-2020, 08:02 AM | #17 |
Rep 780
TheMidnightNarwhal2682.00 |
02-19-2020, 10:54 AM | #18 |
Rep 274
02-22-2020, 06:48 AM | #20 |
Rep 44
got a n54 rwd 96k miles. do I need to change the rod bearings if I'm already doing the oil pan gasket. I know they are preventive maintenance on the n55.
do I need new ones if I remove em just to check how they are? doing engine mounts and oil pan gasket sometime next week. tryna cover everything while I'm there |
