HPFP recall and 29.2?
09-09-2008, 09:39 AM | #1 |
Rep 1,714
Just got a call from my SA that I need to get my HPFP replaced under the recall. Do they automatically put 29.2 on my car if I bring it in for a fuel pump?
09-09-2008, 09:45 AM | #2 |
she likes the flavor......
85
Rep 1,622
have they finally started to do a formal recall?
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. |
09-09-2008, 10:00 AM | #4 |
Rep 1,714
I was told that they contacted me because my VIN number showed up in the range specified. If they don't call you, you don't have the magical VIN number. Be happy.
So does anyone know if they update the software when they put in a new HPFP? I really really don't want the mpg/lag/etc. problems associated with the new software. |
09-09-2008, 10:08 AM | #5 | |
Rep 4,445
If this is not a "new recall" your progman is not required to be updated for the fuel pump replacement. However, if your car has other issues stored in memory the DME will be updated.
09-09-2008, 10:13 AM | #6 |
Modder Raider
759
Rep 8,633
Drives: M3
I've never had any issues with my fuel pump so I would be hesitant to go in and get mine replaced.
I could see it now--I'll get the new pump and it will fail in 3000 miles. If you're going in to have the fuel pump replaced, I will guarrantee that you will get the 30.2 program. (I think that's the newest program)
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
09-09-2008, 10:38 AM | #7 | |
Modder Raider
759
Rep 8,633
Drives: M3
I'll bet that BMW will do the update regardless.
09-09-2008, 10:41 AM | #8 |
Rep 4,445
The "old" repair protocol (pre-29.2) did not require a progman update, but you may be right given recent events.
09-09-2008, 10:43 AM | #9 |
Rep 761
What are some signs of fuel pumps going out?
335i coupe Montego Blue Dinan stage 3 tune, Advan RS wheels 350whp/365wtq
1994 Brooklands Green Acura NSX Comptech Supercharged 390whp/300wtq |
09-09-2008, 10:49 AM | #10 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
I got an oil-cooler retrofit at the dealer, and while it was in there they also replaced the HPFP under recall as well. A program update was not needed for either one (10/06 build), the work was done about a month ago.
09-09-2008, 12:54 PM | #12 |
Rep 4
My pump was replaced a few weeks ago, no software update. My SA told me his techs hate running the update if they don't have to. Nevertheless, I made it clear that under no circumstances were they to update it and asked him to tell the tech that specifically.
09-09-2008, 01:34 PM | #15 |
Rep 2,556
Which dealer did you go to?
09-11-2008, 01:57 PM | #16 |
king of the hills
92
Rep 2,915
I did tell them no updates unless they are absolutely required. I also told them to give me a call before hand if they did need to.
09-11-2008, 03:05 PM | #18 |
Rep 5,780
09-11-2008, 03:45 PM | #19 |
Rep 110
What's the production date of your car? I am hoping that my car (prod. date 5/07) will get a new HPFP too, not that there's anything wrong with it right now.
09-11-2008, 03:57 PM | #20 |
Rep 32
I have 16k miles on my '08 (sept/07 build) 335i coupe. The only problem I've had previously is a dead battery cell which was no biggie...dealer replaced the battery.
I chugged into the dealership on 9/6/08 with these symptoms: 1.) long(er) crank 2.) engine malfunction, reduced power 3.) service engine soon 4.) heavy, erratic shaking and shuddering 5.) engine sounded like a union pacific train with loud pumping sound 6.) because of 4 + 5, decide to turn-off the engine or sometimes it just stalls before 7.) after reset, the car becomes drivable but symptoms will reoccur. 8.) able to recreate problem when i mash the gas Pretty sure it's the fuel pump, will see what the dealer says on Monday. Hopefully the new pump is available now since it's September and the '09s should be rolling off the line, if indeed they have redesigned it. Update: ok, picked up the ride last night. they had it for 3 days. they did replace the fuel pump after trying to fix it via a software update (i believe...see invoice below). initial reaction: 1) the car sounds much deeper 2) before i use to be able to hear the turbo spooling around 1500-2200, i have not been able recreate this yet 3) when i floor it, the car does not seem to pick up as fast as before. but all this could just be in my head...also, not sure if i got the lastest and greatest HPFP, no one i talked to could answer if there indeed is a new design (sales or service). |
09-11-2008, 05:46 PM | #21 | |
Rep 4,445
see my post with the part numbers. http://www.e90post.com/forums/showthread.php?t=169874
09-11-2008, 05:50 PM | #22 |
blaupunkt
56
Rep 525
Drives: 2008 335xi 6spman montego
no...you will get the newest version which is 30.02....lag included
BMW ENGINEERS |
