All cylinders failed compression test but pass leakdown test
02-27-2020, 02:56 AM | #1 |
Rep 11
I just got a 2007 328i 6mt that doesn't start. Currently, when attempting to start, it cranks but it sounds like it has no compression.
I did a compression test (took out all spark plugs, screwed in the tester, mash the gas pedal and had it turn over for 5 seconds. no compression. I tried pouring a little oil down the spark plug hole and same thing on all cylinders. So now I moved on to the leakdown test. I set each piston at TDC for the test and they all pass no problem. no leaks on the gauge. 90 PSI. I'm a little stumped as to why the leakdown test passed but the compression isn't there. Any insight? how can all the cylinders have no compression? There are signs of neglect from the previous owner as I see a little bit of sludge. |
07-29-2020, 09:52 AM | #3 |
Rep 2
i have a BMW E90 320i, car has about 240 000km on the clock, car was smoking when the vehicle was standing idle, grey smoke on pull off. i sent the vehicle in and they removed the head and had the head redone , acid bath, new valve stem seals, engine is reassembled. now when the car is started there is no compression, but if you turn the car over manually is builds compression very quick, try start it after that and loosing all compression, car drove in to the workshop. all old oil and sludge has been cleaned, the head has been sent back to for testing and passed. the car has been reset with the computer , any ideas
08-01-2020, 07:45 AM | #5 |
Rep 2
the workshop that is doing the repairs has a time chain kit for a e90, they have reinstalled the timing chain, we have also replaced the vanos, both of them about 10k kms ago, also replaced the valve tronic,
08-01-2020, 08:07 AM | #6 | |
Rep 3,732
Make sure you are doing the test right....... |
