03-07-2020, 02:43 AM | #2 |
Rep 63
M style instrument cluster bmw g20.........They inventer something called Google......https://g20.bimmerpost.com/forums/sh...041.....really took me 2,4 sec..........
Beam33029.00 |
03-09-2020, 01:14 PM | #5 |
Rep 39
03-09-2020, 01:15 PM | #6 |
Petrolhead
1949
Rep 3,521
It's the same as the M340i cluster. This is on a 330i.
Edit - Just saw @Beam330's post. I didn't know the M340i had the ordinary cluster.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
03-11-2020, 08:09 AM | #7 | |
Rep 1,480
Drives: 2020 M340Xi (G20)
Quite honestly, I have an M340 and my car's cluster looks exactly like the pictures VipinLJ posted. Think the only difference maybe when I start up, the cluster shows the tri-color //M and 340 Having said that, however, I did code the //M in car's iDrive and when I shut things down, the tri-color //M shows up Hope that helps!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
VipinLJ1949.00 |
03-12-2020, 07:22 PM | #9 |
Rep 1,496
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i | |
03-12-2020, 09:14 PM | #10 |
Petrolhead
1949
Rep 3,521
The red markings in the places Ive circled in the first pic (a sent in the second pic) is the only differentiating factor between the comfort and sport modes.
Another thing I noticed is that the shift lights disappear in the M cluster. So does the tachometer in the HUD. I miss those. Looks like Ill be going back to the original cluster even though the M cluster is nice.
Current:
Preciseyyc162.00 |
03-25-2020, 11:07 AM | #11 |
Rep 774
2nd one gives some outrun vibes, how do I do this? Have a 2020 m340
Instagram: Bmw_Captivate
2020 Portimao Blue M340 X Drive and adaptive suspension. Mods: custom exhaust, VRSF Catted DP, Injen intake and Chargepipe. |
03-28-2020, 01:16 PM | #12 |
BMW Client Advisor
3459
Rep 2,504
Drives: 2020 M340i
I had it and coded it back to normal, You can never tell what mode you are in and you loose some of the map.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
03-28-2020, 02:50 PM | #13 |
Petrolhead
1949
Rep 3,521
Me too. I missed the shift indicator lights and rev counter in the head up display as well. I think the stock is the best as of now. The M display would have been the best if it showed everything the stock cluster showed (mode, gear number when in S, rev counter and shift indicator lights).
Current:
Preciseyyc162.00 |
03-28-2020, 04:26 PM | #14 | |
Rep 424
03-28-2020, 04:37 PM | #15 | |
Petrolhead
1949
Rep 3,521
Current:
03-28-2020, 10:25 PM | #16 | ||
Rep 328
03-28-2020, 11:17 PM | #17 |
Petrolhead
1949
Rep 3,521
Yup. Which is why, Im guessing, it doesnt show the shift lights in the HUD.
Current:
03-30-2020, 09:56 AM | #18 | |||
Rep 39
03-30-2020, 10:52 AM | #19 |
Petrolhead
1949
Rep 3,521
Nope. Redline starts at 6k rpms and rev limiter at around 6.5k rpms.
Current:
01-28-2021, 11:08 AM | #22 |
936
Rep 4,327
Drives: M340
I was going to mention that. That is the MAIN difference. I would much rather have oil temp than water temp.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW ....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
