03-08-2020, 07:40 PM | #1 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
Anyone with spacers on 20” wheels?
Does anyone have spacers on the 20” wheels?
Dying to see pictures before I buy spacers I’ve seen a lot of pics on 21 and 22” wheels But those have different offsets. The front wheels are 9.5” instead of 9”, the rear wheels are 10.5” instead of 9” According to my calculations I’d need 20mm spacers in the front and 30mm in the rear That would match 15/20 on the 21/22” wheels
03-09-2020, 10:40 AM | #2 | |
Rep 6
bhe104.50 |
03-09-2020, 10:48 PM | #3 | |
Rep 6
03-10-2020, 07:42 PM | #4 | |
Rep 6,845
Looks good But I think I need more aggressive than that Maybe 18F and 25R
03-10-2020, 09:29 PM | #5 |
Rep 6
03-21-2020, 07:11 PM | #6 |
Rep 6,845
I finally installed the spacers
18mm front 25mm rear 1st pic before 2nd rear with 25mm spacers 3rd pic front with 18mm spacers This is with the oem 740m 9” wheels front and rear
matthew_hull65.50 |
04-08-2020, 09:35 AM | #8 |
Rep 58
Spacers
04-08-2020, 09:40 AM | #9 |
Rep 6,845
The 18mm in front front came with extended bolts
The 25 for the back are the ones that come with short bolts You attach spacer to the hub using these And then you use the oem bolts to attach the wheel to the hub I much prefer this kind But the thinnest you can get them is 22.5mm Was worried it would be too much for the front The advantage of this kind ifs you are not using longer (weaker) bolts And to all intents and purposes you treat the wheels the same way as if you didn’t have a spacer You undo bolts, remove wheel Reattach wheel and tighten bolts As opposed to trying to match the whole in the spacer with the hole in the hub when you put in the wheel bolt
04-08-2020, 04:14 PM | #11 |
Rep 5,350
04-11-2020, 01:38 PM | #13 |
Rep 293
Looks nice
Instagram @really_fat_ninja
http://www.instagram.com/really_fat_ninja/ |
04-13-2020, 11:17 AM | #14 |
Rep 270
Nope. Normal, i would say. But really it hasn't rained much around my area lately...
11-25-2020, 04:15 PM | #15 | |
Rep 200
11-26-2020, 12:23 PM | #16 |
Rep 6,845
You mean like a profile pic?
As in facing the side of the car?
11-26-2020, 02:42 PM | #17 |
Rep 117
11-26-2020, 03:16 PM | #18 |
Rep 200
11-26-2020, 10:01 PM | #20 |
Rep 104
11-26-2020, 10:05 PM | #21 |
Rep 6,845
Per wheel
So 18mm per wheel, 36mm per axle
11-26-2020, 10:06 PM | #22 |
Rep 6,845
Sure
Will take some pics tomorrow
