03-10-2020, 03:22 AM | #1 |
Rep 335
Activating SLI related ISA, EDP and VZA Functions
My G30 (ECE) has 5AS so it has KAFAS4, Dynamic Cruise Control (DCC)(no front radar) and we've retrofitted SLI&NPI and they work without any problems. But there are 3 more features that comes with (depends upon) SLI actually:
ISA: updates the adjusted speed of cruise control according to speed signs read by SLI. EDP: updates the adjusted speed of speed limiter according to speed signs read by SLI. VZA (VORAUSSCHAU): warns the driver of an approaching speed limit change along the road to let the gas pedal off. So when the car arrives to the place where the speed limit decreased cars speed will be equal to that limit automatically by deceleration (so you won't use breaks and spend unnecessary gas). Additional Sign:Which signs it refers I don't know but KOMBI should display the upcoming signs (in white color) probably as the part of VZA. Also some cars show stop signs and so on. This also doesn't work at my G30 My car came with 8TD, so to make SLI work it has been removed and I had to modify COUNTRY_SLINPI_MODE in KAFAS because it remained at (---) icon. After that SLI and NPI works flawlessly Even ISA, EDP, VZA related codes seems active on all modules they don't work. So I've generated CAFD files by using Coding Verification by changing my cars VO list (removed 5AS and added 5AT). I've compared all 32 files and found about 90 parameter changes. I've modified ISA, EDP and VZA related ones and I have a "Speed Limit Assistance" Menu added to iDrive settings under vehicle settings as seen below: Last sentence means: "It's only available as a restricted feature in this country". After that casual "Limit" function (which limits your max speed to set value) changed into "Limit Assist" (which asks to update your currently set max speed limit automatically to actual limit on the road +- a buffer value you've selected on the idrive menu). It can be seen below: Problem is Cruise Control icon didn't changed into "Assist + cruise logo" and it doesn't asks to set limit according to SLI No matter which parameters I've changed I couldn't make it work. I've tried every parameter from 5AT option (except iBrake and ACC related ones) but it never activated. I even activated ISA related parameters (which 5AT even left inactive) no change.. Also ISA doesn't seem to be supported by G30 according to E-Sys as seen below but I've also set these to activce: I also changed land restriction parameters into these since their current values doesn't work (which are same for Germany cars): DSC: C_EDP_Land_aktiv Werte=FF, FF, FF, FF DSC: C_vSLI_Land_aktiv Werte=FF, FF, FF, FF DSC: C_SWA_Land_aktiv Werte=FF, FF, FF, FF SAS: C_vSLI_Land_aktiv Werte=FF, FF, FF, FF SAS: C_EDP_Land_aktiv Werte=FF, FF, FF, FF SAS: C_EDP_Vorausschau_aktiv Werte=FF, FF, FF, FF SAS: C_EDP_SLI_aktiv Werte=FF, FF, FF, FF also added Germany car options via FDL coding such as: DSC: C_VFA_Funktion SAS10: C_SWA_Vorhanden KAFAS: VFW_AVAILABLE KAFAS: WWA_ENABLE BDC_BODY2: VCM_COUNTRY (mine was ECE) KOMBI: LAENDERAUSFUEHRUNG (mine was Sonstige) RS: C_SWW_Enable_LaneWidthAdjustmentByKAFAS yet nothing (still says function is limited only in my country). To conclude Limit Assistant has been activated, but cruise control speed "assistant mode" to update CC speed doesn't. Also I've never seen upcoming speed sign icon (white color next to current speed limit in the KOMBI) and anything related with VZA (gas icon, arrows etc.) So I'm about to abandon this project. But I know it must work. I think car sees that it's currently located in Turkey and deactivates Cruise Control Assist. Because I'm sure that I've activated all the parameters required for this function. So I have to find a code to lift restrictions for countries like the COUNTRY_SLINPI_MODE for the SLI activation. I'd appreciate any suggestions
2017 G30 520 (1.6lt)
2016 S1000RR 2014 W205 Last edited by ejlover06; 03-10-2020 at 04:08 AM.. |
03-10-2020, 04:03 AM | #2 | |
Rep 335
Actually this functions are allowed in ECE cars and "Limit Assist" worked easily without any change in the lad restriction parameters Cruise Control Speed Assistant is completely same thing and I don't understand why it doesn't work It only asks to update the limit or not (as same as the max speed limiter) Even we change the region car will see the car in Turkey from the navigation, that will automatically block the feature again just like the SLI. There may be a code like COUNTRY_SLINPI_MODE somewhere I'm missing or there is more to do with C_EDP_Land_aktiv Werte=FF, FF, FF, FF (Why there are only 4 and why FF not 00?) and we've understood it wrong
2016 S1000RR 2014 W205 |
03-14-2020, 10:54 AM | #3 |
Rep 362
So you have Adaptive Cruise Control that is using the KAFAS camera? I would like some more information about that, as my car has the KAFAS cameras but it only uses it for Emergency Braking. I don´t have High Beam Assist, SLI, ACC, Lane Assist or anything else and i would LOVE to have some of these things retrofitted, but I don´t know how or who to contact. The guys here in DK doing coding on BMW´s don´t know anything about ACC using the KAFAS, even though I have pointed out, that it´s an option on the price list.
´22 iX3 M Sport "Charged" - Cashmere Silver
´22 Mini Cooper SE "Yours Trim" - Island Blue |
03-14-2020, 01:18 PM | #4 | |
Rep 335
I ONLY have KAFAS cameras and DCC. Same setup with you I think. But adaptive LEDs has HBA from the factory also VLI (not sure if this is the correct abbreviation). I had SLI retrofitted. Now I'm trying to activate all features that can be used with these setup without front radar sensors
03-15-2020, 01:12 PM | #5 | |
Rep 362
Prazcon0.00 |
03-15-2020, 02:52 PM | #6 |
Rep 1
Hello!
Do You guys know if Speed limit info on Instrument Cluster could be activated via BimmerCode application and Bluetooth connection? I did a lot of things with standard mode but a lot more options are in Expert mode. I manage to get (---) sign with enable speed limit info in Expert mode. Regards, matej |
03-16-2020, 05:29 AM | #8 |
Rep 362
Is there a FSC code for Adaptive Cruise using KAFAS?
03-22-2020, 03:42 AM | #10 | |
Rep 362
"Camerabased driver assist system, that works between 0 and 140 km/h". The option code is possibly 5DF. The radarbased cruise is part of a Drivers Assist pack. It was the camerabased version is was after. Is there a FSC for that?
05-06-2020, 11:10 AM | #11 |
Rep 1,154
So I have been trying to work on adding some of these codes to my 2020 530e with iDrive 7, mainly by doing the same thing, comparing my FDL to one from a Euro Car, and making those changes. So far though, it is not working. I now that the menu for the settings in iDrive, however it will not let me select any of the boxes, and I also get text about Anticipation not being in my country. However, some of the options that worked prior to me adding the codes, such as setting a speed warning, are now also grayed out.
From my X3 though, I could have sworn that some of the codes related to the word Geschwindigkeit had to do with getting the ISA to work. |
05-08-2020, 07:07 PM | #12 |
Rep 1,154
Just an update to this. I was able to go back and review the changes that had been made on my G01 X3 that enabled ISA, and was able to get it working on my G30. Now the Anticipation stuff that was in the greyed out menu is gone, and the only option it gives me is the information about adjusting to the new Speed Limit. I will continue to play around and see if I can find more about getting Anticipation working. Here is what I changed:
BDC_Body2 (5FA9): PIA_Default_Uebernahme_geschwindigkeit: Change to Aktiv Uebernahme_geschwindigkeit: Change to Aktiv DSC: C_EDP_Land_Aktiv: Change Werte to all "FF" C_EDP_vorhanden: Change to Vorhanden Headunit (Either NBT or MGU): Autotempomat: Change to Gen_1 Geschwindigkeit_Assistent: Change to Aktiv SAS: C_EDP_Anziege C_EDP_Land_Aktiv: Change Werte to all "FF" C_EDP_vorhanden: Change to Vorhanden C_EDP_SLI_Aktiv: Change Werte to all "FF" C_ISA_Vorhanden: Change to True C_EDP_Anziege_Zusatztexte: Change to True |
06-01-2020, 10:11 PM | #13 | |
Rep 80
06-02-2020, 04:46 PM | #14 | |
Rep 49
Under HU_MGU, I did not find Geschwindigkeit_Assistent, instead I found GeschwindigkeitAssistent one word and the possible value is nicht_aktiv or gen_1 For C_EDP_Anziege (you didn't specify what to do with it), I didn't find that setting, instead the closest thing I found is C_EDP_Anzeige_Art_Offset. I want to test this but I thought I'd check in first. Thoughts? Thanks. Last edited by Bandoul; 06-02-2020 at 05:40 PM.. |
01-06-2021, 02:42 AM | #16 |
Rep 3
Here in Finland Speed Assistant is enabled, but the speed needs to be adjusted manually in Active Cruise Control. I have been trying to enable ISA by coding my G30 with no luck. I have managed to enable Speed Assistan's Speed limits -menu which shows four options for speed limit info usage, but none of them can be enabled due country restrictions.
I'll post here my environment and all the options, I have already coded or played with. I hope someone can find out what is wrong. In the other hand I haven't found any success story of G30 despite I have googled a lot. Car is BMW G30 530ex build 12/2019. Esys shows in I-Step target S15A-20-11-542. I am not sure if this is the software version of the car, but the software version is updated on BMW dealer to latest version 29.12.2020. The car option list includes for example following possible related options: - S5AL Active Protection - S5DF Active Cruise Control+Stop&Go Function - S5AV Active Guard - S8TF Active Pedestrian Protection First I coded following options (in some posts there was also other parameters to be coded, but they was already on the right value in my car, so here are only changed values) DSC3: C_EDP_Land_Aktiv: All values to FF (was FB, DF, 83, C0) C_EDP_vorhanden: Changed to Vorhanden HU_MGU: GeschwindigkeitAssistent: Changed to aktiv SLAAUTOMATISCH: Changed to gen_1 STRECKENVERLAUF: Changed to gen_1 VORAUSSCHAU: Chaged to gen_1 BDC_BODY2: STRECKEN_VERLAUF: Changed to aktiv With (some of) these options the Speed Assistant's Speed Limits -menu with four options got enabled, but none of the options could not be enabled due the county restrictions. After that I coded following options (I guess there are a lot of irrelevant options too): SAS: C_EDP_Land_Aktiv: All values to FF C_EDP_SLI_Aktiv: All values to FF C_EDP_Vorausschau_aktiv: All values to FF C_ACC_Regelung_Nebenspur_Land_aktiv: All values to FF C_VZA_Funktion_Land_aktiv: All values to FF C_vSLI_Land_aktiv: All values to FF C_EDP_Kopplung_ISA_Degadation: Changed to false C_ISA_Kopplung_EDP_Land: Changed to false C_ISA_Kopplung_EDP_Degradation: Changed to false DSC3: C_vSLI_Land_aktiv: All values to FF C_VZA_Funktion_Land_aktiv: All values to FF C_VZA_Funktion: Changed to true C_ISA_vorhanden: Changed to vorhanden C_SLA_Variante: Changed from keine to ACC_DCC C_vSLI_Funktion: Changed to aktiv C_EDP_Kopplung_ISA_Degradation: Changed to false C_ISA_Kopplung_EDP_Degradation: Changed to false C_ISA_Kopplung_EDP_Land: Changed to false C_VZA_Funktion: Changed true HU_MGI: AUTOLIMITER: Changed to aktiv GUIDING_VORAUSSCHAU_SLI_ENABLE: Changed to aktiv Changed Vorausschau aus Matrix, SLI immer aktiv to Vorausschau immer aktiv, SLI immer aktiv These did not help. After that I played with values in KAFAS4 module: COUNTRY_SLINPI_MODE: Tried to change all values to FF VFW_COUNTRY_VARIANT_MODE: Tried to change all values to FF I have also tested to change all country related FF’s to 00 in all relevant modules. In G05 coding instructions there was some parameters like C_SLA_Streckenregelung_Land_Aktiv, C_SLA_Streckenregelung_vorhanden and C_SLA_aSLA_vorhanden that I could not find from any of my ecus. I als do not have option S5AT. Could the problem be realated to these parameters or this missing option? |
01-06-2021, 10:21 AM | #17 |
Rep 49
@ Larppa
In order to get you current I-Step, in E-Sys go to Expert Mode/VCM/Master/I-Steps and click Read. The fields in the Integration steps box will populate. Look for the value in I-Step (current). I have a USA MY2020 G30 and I can confirm there is no way to activate ISA. However SLA coded properly will allow you to select the check box in Console (HU_MGU) and select the value of the speed to increase or decrease based on the detected speed limit while cruise control is on. I have 5AT which includes ACC+Stop and Go. Last edited by Bandoul; 01-06-2021 at 10:27 AM.. |
01-06-2021, 07:42 PM | #19 |
Rep 231
I'm in the US and have a 2020M550 w/ adaptive cruise. What, if anything, will this coding do for me here? I haven't seen this discussion before.
01-07-2021, 12:05 AM | #20 |
Rep 49
Do you mean what will Speed Limit Assist (SLA) do you for you? While the cruise control is on and the vehicle detects a speed limit change, a symbol will alert you with an arrow down or up in the instrument cluster and HUD. you can then push the increase/decrease speed button on the steering wheel and the cruise control will adjust accordingly. It is a convenience but requires manual intervention whereas Intelligent Speed Assistant does not require your input and will do it automatically based on your settings. I have my SLA set to add +5 MPH to whatever the detected speed limit is when I press the button.
01-07-2021, 09:25 AM | #21 |
Rep 1
01-07-2021, 11:58 AM | #22 | ||
Rep 3
When I did read other discussions, somebody thought that there may be some country restrictions that are managed through Connected Drive in Cloud. Maybe I need to search parameters that are CD-related. I have had that function from the factory, but it needs manual actions when speed changes. I am just frustrated, because even in Scoda Suberb the automatic reducing of speed is working Last edited by Larppa; 01-07-2021 at 12:01 PM.. Reason: fixes |
Tags |
edp, isa, sla, sli, vza |
