03-12-2020, 01:25 AM | #1 |
Rep 1,961
CarBahn tune VS BootMod
https://carbahnautoworks.com/product...x3m40i-x4m40i/
The part I like best: "Philosophy: CarBahn software is designed to deliver the highest safe output possible. Smooth Power means software tuned correctly, not over-tuned. We always try to make a natural torque curve, not excessive torque at low RPM that falls off rapidly at high RPM. Excessive torque will break the tires loose, break the engine and drivetrain. Managed torque with a smooth delivery makes the car easier to drive thereby faster and more reliable. Most if not all our competitor’s tunes attempt to run too much boost, resulting in active knock corrections which causes surging during acceleration. CarBahn software also incorporates torque reduction in 1st and 2nd gears for manageable power delivery. Durability: Most if not all tunes on the market except CarBahn’s reduce safety parameters in the software in an attempt to extract more power. These safety parameters such as knock control sensitivity, super knocking control sensitivity, and catalyst thermal protection are tuned into your OEM software to prevent engine and catalyst failure. When we reduced all the supposed power robbing software protections we lost less than 8 HP and 8 LB/FT Torque. We have seen many damaged engines as result of reducing these safety parameters! It hardly seems worth it for 8HP." I am looking for a SAFE, reliable tune that also improves low-speed drivability and turbo lag. (Stage 1 only) I don't have any reason thus far to doubt BM3, I know they're super popular, just hoping for additional data points. Thoughts on CarBahn? |
03-12-2020, 03:47 AM | #2 |
Rep 223
Drives: X3 M40i (MY19)
If they are true to their philosophy it sure seems the best way to tune. My F25 was tuned using BMW own M-performance chip, becasue i wanted safety and quality.
Jens Ejvinsson, Sweden
BMW X3 M40i (MY19), every option in the book, Pictures BMW X1 20d M-Sport xDrive (MY17), Nav, HUD |
Alias1431799.50 |
03-12-2020, 08:20 AM | #3 |
Cowboy Astronaut Millionaire
2324
Rep 2,893
I would be interested in the information on the 2020 what they have. Seems this is currently information based on the older 2019 B58.
03-12-2020, 08:35 AM | #4 |
Rep 133
Don’t BM3 and MHD tune the transmission too? I wouldn’t hesitate if I had a carbahn dealer nearby. At this point, having now heard about ECU locking via updates, I may just hold out for a re-release of the Dinan box.
03-12-2020, 02:19 PM | #6 |
Rep 327
I wouldn't count on Dinan coming out with a piggyback for the X3 M40i if that's what you are looking for (I have one myself and am considering the Carbahn flash tune). They are focused on a flash tune for the B58 but don't have any ETA for when it will be released. From what I understand Dinan was starting to move away from piggybacks and towards flash tunes but that might change if ECUs start getting locked down with software updates as we are learning.
2019 X3 M40i Alpine White/Black Vernasca stock
2015 435i Alpine White/Black Dakota FTP chargepipe, Dinan intercooler, M Performance exhaust, Carbahn Stage 2 tune |
03-12-2020, 06:29 PM | #7 |
Rep 271
Not for any of the newer trannys mated to any B58s AFAIK.
Alias1431799.50 DoubleZeroNineOneEight109.00 |
03-12-2020, 06:34 PM | #8 |
Rep 271
Never heard of CarBahn. Personally, I'd suggest BM3 due to the speed with which they bring feature updates out to all BMW models they support, not just newer models. BM3 also has a lot of experience doing this. CarBahn sounds like they're just making claims to differentiate themselves just enough for people to question going with more established players like BM3.
03-12-2020, 07:01 PM | #9 |
Rep 312
Drives: 2019 x3 M40i
Dinan already scrapped the piggyback for our car. they had it in the works and dumped it a little over a year ago. no explanation why.
neither MHD or BM3 tune the transmission by themselves, both have tunes for transmissions but neither (and nobody for that matter) for our specific platform. I'd personally would, and have, go with BM3. MHD makes more power from what ive seen, by a small margin but it's there. the real key to BM3 in my opinion is the massive support network in facebook for BM3, and the ultra quick intervention by the developers if you have issues. As far as blown engines, I have yet to hear of someone wrecking their motor on the standard OTS tunes. 2 big turbos have eaten engines, and one guy running a meth system that screwed up are the only major failures i've come across and both in the 340 platform. One 340 also torched his transmission. that's 3 total major losses from the time the B58 came out in the 3 series up through the b58 hitting every platform BMW uses..... lots of tunes by MHD, BM3, Dinan (supports b58 on other cars), as well as custom variants which include meth, port injection, larger turbos, etc, etc, etc. The fear is always great, but the failure rates are so so so low in the grand scheme of things. Go with a company that supports you and is KNOWN by others. even if not BM3, go mhd at least... but choose someone that's quality and keeps revising the tunes to give both more power and better usability. for me that was BM3 |
03-12-2020, 10:58 PM | #10 |
Rep 1,961
Do they really revise their tunes? That doesn't make sense to me. You would think they would achieve peak results for a given powertrain, then release that tune. To suggest otherwise hints at incompetence. To be clear, I am not suggesting BM3 isn't good at what they do, I'm sure they are, it's just that your phrasing gives me pause. Can you elaborate?
03-12-2020, 11:37 PM | #11 | |
Rep 327
03-13-2020, 02:05 AM | #12 | |
Rep 1,961
03-13-2020, 04:01 AM | #13 | |
Rep 133
03-13-2020, 07:24 AM | #14 | ||
Rep 327
Manual/DCT - 12% Rear wheel drive - 15% xDrive - 17% For the flash tune for the X3 M40i, Carbahn's dyno measured 366 hp and 407 lb-ft torque at the wheels which translates to the 441 hp and 490 lb-ft torque crank numbers they state.
Alias1431799.50 |
03-13-2020, 07:29 AM | #15 | ||
Rep 327
03-13-2020, 08:34 AM | #16 | |
Rep 133
03-13-2020, 09:05 AM | #17 | ||
Rep 327
03-13-2020, 01:21 PM | #18 | |
Rep 1,961
03-13-2020, 01:52 PM | #19 | |
Rep 312
03-13-2020, 02:36 PM | #20 | |
Rep 1,961
What are tables? |
03-13-2020, 03:23 PM | #21 | |
Rep 312
every single tuning platform operates essentially as a massive stack of spreadsheets. each individual one is called a table (at least on the platforms I've used). like any table (spreadsheet) it has an X and Y axis that works like a giant game of operational battleship. for target boost as an example, the Y axis would be throttle angle, while the X would be RPM, and the combo would tell the car what the desired boost to target. low throttle angle and low RPM, probably have a value for very low boost, 90%+ throttle angle and 5000 rpm? possibly something like 18psi. How do you get this to happen, enter WGDC table (wastegate duty cycle) or how hard the electrical solonoid works to keep the wastegate closed. This is repeated with things like global timing, AFR, additional timing, and when you stack all the tables on top of one another you get how your car performs. tweak things as needed to change how it currently behaves into how you want it to behave. the below link is to a sample timing table from my old subaru tuning platform i used, RomRaider https://lh3.googleusercontent.com/pr...YENBe81HcCodrm |
03-13-2020, 03:23 PM | #22 | |||
Rep 271
And I'd think you're more apt to have problems with warranty with a piggyback than a flash. Piggy's just obfuscate numbers to make the computer think it's experiencing a condition it really isn't, whereas flash tunes have more more control and parameterizarion, and are thus inherently safer. Additionally, they can tell whether you put a piggy on the car just as easily as a flash tune if there is a warranty claim, so you're really not safe either way, and should just go with a flash. I've seen people flash their leases and return them when the lease is up, and the dealer sells the car as a CPO, so as long as you're looking for more power, might as well go the safer route and just flash it. If you're afraid you're gonna blow your engine and your warranty, save your money and remain stock. I personally know that if I blow the motor, I'll just buy a new one. |
