03-12-2020, 08:41 PM | #1 |
///M
6648
Rep 3,683
Toyota invents new way to paint with 95% efficiency
Japanese automaker has turned to an innovative new paint atomizer as another way to reduce CO2 emissions. The airless paint atomizer makes use of static electricity instead of air and, as a result, achieves a coating efficiency of 95 percent instead of the usual 60-70 percent.
What exactly is coating efficiency? It applies to the volume of paint sprayed relative to the amount of paint that ends up sticking to the vehicle's body. With a loss of only five percent from spraying to adhesion, Toyota claims that the new technique achieves the highest coating efficiency in the world. Using the new painting process will reduce the Toyota Group's CO2 emissions by approximately seven percent, no mean feat for one of the largest automobile manufacturers globally. Unlike conventional air paint atomizers using aerodynamic force - a process that causes paint particles to ricochet off of the surface it is applied to - Toyota's new process sees statically charged particles gravitating to the surface (the vehicle body). In this way, far fewer atomized particles are scattered, so wastage is dramatically reduced. The diagram below shows the tip of the airless paint atomizer. Cylindrical in shape, the tip has 600 grooves and, upon rotation, the paint flows through the grooves. Using static electricity, the paint is atomized.
Life is too short...enjoy your life
///M |
03-12-2020, 09:10 PM | #3 |
Primo Generalissimo
5073
Rep 4,221
Drives: All of them
Garage List 2024 Ford Bronco Ra ... [10.00]
2018 Porsche 911 GTS [10.00] 2023 BMW M2 [9.25] 2022 Ford F-250 Tremor [8.50] |
03-13-2020, 12:05 AM | #6 |
Rep 2,759
I mean you technically could if you were spraying in a clean room, or had a super clean floor or something to catch the extra powder on. I wouldn't want any bit of dust or dirt particles in my powder.
03-13-2020, 12:09 AM | #7 | |
Rep 2,476
Besides, it was a theoretical comment/question. Last edited by Emilime75; 03-13-2020 at 07:07 AM.. |
03-13-2020, 11:19 AM | #9 |
Rep 3,255
Yet, Toyota can't figure out how to produce a proper Infotainment system and can't figure out how to add Android Auto into pre 2020 Entune 3.0 head units. SMH.
03-13-2020, 12:44 PM | #10 |
Rep 407
Drives: Miss Daisy
03-13-2020, 01:06 PM | #11 | |
Rep 9,135
03-13-2020, 02:07 PM | #12 |
Rep 407
Drives: Miss Daisy
03-13-2020, 05:30 PM | #15 |
Rep 953
Drives: e92 335i, f22 m235i, e30 325is
Isn't this the general idea behind powdercoating?
03-14-2020, 01:24 PM | #16 | |
Rep 75
Our facilities have been doing this longer than I've been here (>8 years), changed to water based paint about 6~7 years ago for environmental reasons as you mentioned |
03-16-2020, 11:51 AM | #19 | |
Rep 9,135
Anyone can color sand too, it just obviously adds expense, which explains why Bentley and Rolls are some of the few doing it. But Lexus and Mercedes can manage to paint a car with a fraction of the orange peel of BMW. |
03-16-2020, 12:35 PM | #20 |
Rep 11,670
I thought that was for anti-theft reasons.
'21 M2C Hockenheim Silver
03-16-2020, 12:43 PM | #22 |
Rep 2,498
Drives: 9Y0 Cayenne S
Static electricity in paint processes is not new, rather it has been around for quite some time, maybe as long as 20 years.
Automotive exterior “Class A surface” paint is not powder, it is liquid. Good move by Toyota to improve operational effectiveness. The actions are not new or novel. |
JTO245934.50 |
